[GeoNode-users] How do I install Geonode 2.6.3 on Ubuntu 16.04 or 18.04?
Kelvin Gnash gnashkelvin at gmail.com
Thu Oct 11 10:08:54 PDT 2018
I'm running into a quite similar issue here - tying to install Geonode 2.8
on Ubuntu 16.04 - following the online tutorial. It could be the provided
URL is not reachable or incorrect configs in local_settings.py file.
---> pavement.setup
---> pavement.setup_geoserver
Downloading geoserver binary
Captured Task Output:
---> pavement.setup
  File
"/home/test/Envs/geonode/local/lib/python2.7/site-packages/paver/tasks.py",
line 196, in _run_task
    return do_task()
  File
line 192, in do_task
    task()
  File
line 321, in __call__
    retval = environment._run_task(self.name, self.needs, self.func)
  File
line 214, in _run_task
    return do_task()
  File
line 193, in do_task
    return func(**kw)
  File "pavement.py", line 130, in setup_geoserver
    "geoserver binary")
  File "pavement.py", line 81, in grab
    r = requests.get(str(src), stream=True, timeout=10)
  File
"/home/test/Envs/geonode/local/lib/python2.7/site-packages/requests/api.py",
line 72, in get
    return request('get', url, params=params, **kwargs)
  File
line 58, in request
    return session.request(method=method, url=url, **kwargs)
  File
"/home/test/Envs/geonode/local/lib/python2.7/site-packages/requests/sessions.py",
line 508, in request
    resp = self.send(prep, **send_kwargs)
  File
line 618, in send
    r = adapter.send(request, **kwargs)
  File
"/home/test/Envs/geonode/local/lib/python2.7/site-packages/requests/adapters.py",
line 496, in send
    raise ConnectTimeout(e, request=request)
ConnectTimeout: HTTPConnectionPool(host='build.geonode.org', port=80): Max
retries exceeded with url: /geoserver/latest/geoserver-2.13.x.war (Caused
by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at
0x7fd051099b50>, 'Connection to build.geonode.org timed out. (connect
timeout=10)'))
On Thu, Oct 11, 2018 at 7:58 PM Simon Lee <simon.lee at null.net> wrote:
> I tried to use the manual install method, cloning the 2.6.x branch from
> GitHub, but when I run paver setup it outputs an error. I tried both "paver
> setup" and "sudo paver setup" with the same effect.
> I guess that's because http://build.geonode.org/geoserver/latest/ is not
> reachable. I downloaded the official geoserver.war but it doesn't work
> because of auth. Any help? :)
> Here's the output:
> simon at ubuntu:~/geonode$ sudo paver setup
> ---> pavement.setup
> ---> pavement.setup
>   File "/home/simon/.local/lib/python2.7/site-packages/paver/tasks.py",
> line 201, in _run_task
>     return do_task()
> line 197, in do_task
>     task()
> line 333, in __call__
> line 219, in _run_task
>     return do_task()
> line 198, in do_task
>     return func(**kw)
>   File "pavement.py", line 106, in setup_geoserver
>     "geoserver binary")
>   File "pavement.py", line 74, in grab
>     urllib.urlretrieve(str(src), str(dest))
>   File "/usr/lib/python2.7/urllib.py", line 98, in urlretrieve
>     return opener.retrieve(url, filename, reporthook, data)
>   File "/usr/lib/python2.7/urllib.py", line 245, in retrieve
>     fp = self.open(url, data)
>   File "/usr/lib/python2.7/urllib.py", line 213, in open
>     return getattr(self, name)(url)
>   File "/usr/lib/python2.7/urllib.py", line 350, in open_http
>     h.endheaders(data)
>   File "/usr/lib/python2.7/httplib.py", line 1038, in endheaders
>     self._send_output(message_body)
>   File "/usr/lib/python2.7/httplib.py", line 882, in _send_output
>     self.send(msg)
>   File "/usr/lib/python2.7/httplib.py", line 844, in send
>     self.connect()
>   File "/usr/lib/python2.7/httplib.py", line 821, in connect
>     self.timeout, self.source_address)
>   File "/usr/lib/python2.7/socket.py", line 575, in create_connection
>     raise err
> IOError: [Errno socket error] [Errno 110] Connection timed out
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181011/6d417d7a/attachment.html>
More information about the geonode-users mailing list
