[GeoNode-users] Recurring User 'None' Error Geofence/Geoserver
Paolo Corti
pcorti at gmail.com
Fri Oct 12 12:12:12 PDT 2018
I am getting exactly the same error, using master and GeoServer 2.13-SNAPSHOT
In the stack I also see "Could not retrieve GeoFence Rules count."
best
Paolo
On Fri, Oct 12, 2018 at 1:11 PM Michael Fedak <mikefedak at gmail.com> wrote:
> I am using the latest 2.8.x branch with Geoserver 2.12.2 and I keep receiving the following error when attempting to run the updatelayers command (Below).
> I am also having trouble with users not being sync'd with geoserver. I have gone through the documentation for security configuration, and checked that the geonode role/user apis are accessible to geoserver. As far as I can tell, nothing is blocking either geonode from reaching geofence or vice-versa.
> Traceback (most recent call last):
> File "manage.py", line 29, in <module>
> execute_from_command_line(sys.argv)
> File "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 354, in execute_from_command_line
> utility.execute()
> File "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 346, in execute
> self.fetch_command(subcommand).run_from_argv(self.argv)
> File "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/base.py", line 394, in run_from_argv
> self.execute(*args, **cmd_options)
> File "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/base.py", line 445, in execute
> output = self.handle(*args, **options)
> File "/home/gnode/geonode_dev/geonode/geonode/geoserver/management/commands/updatelayers.py", line 124, in handle
> execute_signals=True)
> File "/home/gnode/geonode_dev/geonode/geonode/geoserver/helpers.py", line 636, in gs_slurp
> layer.set_permissions(perm_spec)
> File "/home/gnode/geonode_dev/geonode/geonode/security/models.py", line 216, in set_permissions
> sync_geofence_with_guardian(self.layer, perms, group=group)
> File "/home/gnode/geonode_dev/geonode/geonode/decorators.py", line 44, in wrapper
> return func(*args, **kwargs)
> File "/home/gnode/geonode_dev/geonode/geonode/security/utils.py", line 393, in sync_geofence_with_guardian
> _update_geofence_rule(layer.name, layer.workspace, service)
> File "/home/gnode/geonode_dev/geonode/geonode/security/utils.py", line 564, in _update_geofence_rule
> raise RuntimeError(msg)
> Exception: ('Failed to process lprca_ws_boundarywgs84', RuntimeError("Could not ADD GeoServer User None Rule for Layer u'lprca_ws_boundarywgs84'",))
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-users
