[GeoNode-users] Recurring User 'None' Error Geofence/Geoserver
Michael Fedak mikefedak at gmail.com
Mon Oct 15 07:12:33 PDT 2018
Thank Alessio,
This fixes the problem with documents. However I am still experiencing the
same problems with layers, I have commented on the pull request. I am also
having the same issue with superusers not being automatically logged into
geoserver.
On Mon, Oct 15, 2018 at 4:39 AM Alessio Fabiani <alessio.fabiani at gmail.com>
wrote:
> Hi Michael,
> thanks very much for helping on test.
> I've finally figured out where the problem was. Fix available here
> https://github.com/GeoNode/geonode/pull/3985
> I'll merge it as soon as the Travis checks pass. I'll also try to add some
> specific test cases for this particular issue.
> Il giorno dom 14 ott 2018 alle ore 21:08 Alessio Fabiani <
> alessio.fabiani at gmail.com> ha scritto:
>> Uhm very strange. Tomorrow will do some specific tests on this. Currently
>> I cannot figure out what the problem could be.
>> Il dom 14 ott 2018, 21:03 Michael Fedak <mikefedak at gmail.com> ha scritto:
>>> Ok, fixed; I had my JAVA_OPTS entered incorrectly. Now geoserver starts.
>>> However, I am experiencing the same issues as before.
>>> On Sun, Oct 14, 2018 at 2:10 PM Michael Fedak <mikefedak at gmail.com>
>>> wrote:
>>>> Traced it back some more, it seems to be an issue with GWC:
>>>> Cannot resolve reference to bean 'gwcXmlConfigResourceProvider' while
>>>> setting constructor argument; nested exception is
>>>> org.springframework.beans.factory.BeanCreationException: Error creating
>>>> bean with name 'gwcXmlConfigResourceProvider' defined in URL
>>>> [jar:file:/opt/apache-tomcat-9.0.1/webapps/geoserver/WEB-INF/lib/gs-gwc-2.13-20181005.133101-833.jar!/geowebcache-core-context.xml]:
>>>> Bean instantiation via constructor failed; nested exception is
>>>> org.springframework.beans.BeanInstantiationException: Failed to instantiate
>>>> [org.geoserver.gwc.config.GeoserverXMLResourceProvider]: Constructor threw
>>>> exception; nested exception is java.lang.IllegalStateException: Could not
>>>> create directory.
>>>> On Sun, Oct 14, 2018 at 1:42 PM Michael Fedak <mikefedak at gmail.com>
>>>> wrote:
>>>>> Ok, got the war and attempted to deploy it. Tomcat is unable to deploy
>>>>> it due to an error associated with geotools:
>>>>> Geoserver log:
>>>>> 2018-10-14 10:24:59,152 TRACE [geotools.factory] - ENTRY
>>>>> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
>>>>> 2018-10-14 10:24:59,152 TRACE [geotools.factory] - CHECK
>>>>> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
>>>>> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last]
>>>>> AbstractEpsgMediator.
>>>>> 2018-10-14 10:24:59,152 TRACE [geotools.factory] - THROW
>>>>> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
>>>>> 2018-10-14 10:24:59,152 INFO [geotools.util] - Weak collection cleaner
>>>>> stopped
>>>>> Catalina log:
>>>>> 14-Oct-2018 17:21:40.658 SEVERE [http-nio-8080-exec-13]
>>>>> org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks
>>>>> The web application [geoserver-2.13.x] created a ThreadLocal with key of
>>>>> type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal at 454bb710])
>>>>> and a value of type
>>>>> [org.geotools.referencing.operation.projection.TransverseMercator.Provider]
>>>>> (value [PROJECTION["Transverse_Mercator"]]) but failed to remove it when
>>>>> the web application was stopped. Threads are going to be renewed over time
>>>>> to try and avoid a probable memory leak.
>>>>> type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal at 86e380d])
>>>>> and a value of type [org.geotools.referencing.wkt.Formatter] (value []) but
>>>>> failed to remove it when the web application was stopped. Threads are going
>>>>> to be renewed over time to try and avoid a probable memory leak.
>>>>> I will keep trying to troubleshoot this.
>>>>> On Sun, Oct 14, 2018 at 10:02 AM Michael Fedak <mikefedak at gmail.com>
>>>>> wrote:
>>>>>> Never mind, found your build server:
>>>>>> https://build.geo-solutions.it/geonode/geoserver/latest/
>>>>>> On Sun, Oct 14, 2018 at 10:00 AM Michael Fedak <mikefedak at gmail.com>
>>>>>> wrote:
>>>>>>> Ok, I can do that. Is there a place to download the build with the
>>>>>>> extension since build.geonode.org is down? Or shall I just download
>>>>>>> vanilla 2.13 and apply the extension myself?
>>>>>>> On Sun, Oct 14, 2018 at 9:56 AM Alessio Fabiani <
>>>>>>> alessio.fabiani at gmail.com> wrote:
>>>>>>>> Uhm, most probably a Geoserver issue. From. Geoserver 2.13+ there's
>>>>>>>> a fix to threat void users as * users.
>>>>>>>> Any chance to try out updating to Geoserver 2.13.x?
>>>>>>>> You won't have to change anything on the data dir.
>>>>>>>> Il ven 12 ott 2018, 19:11 Michael Fedak <mikefedak at gmail.com> ha
>>>>>>>> scritto:
>>>>>>>>> I am using the latest 2.8.x branch with Geoserver 2.12.2 and I
>>>>>>>>> keep receiving the following error when attempting to run the updatelayers
>>>>>>>>> command (Below).
>>>>>>>>> I am also having trouble with users not being sync'd with
>>>>>>>>> geoserver. I have gone through the documentation for security
>>>>>>>>> configuration, and checked that the geonode role/user apis are accessible
>>>>>>>>> to geoserver. As far as I can tell, nothing is blocking either geonode from
>>>>>>>>> reaching geofence or vice-versa.
>>>>>>>>> Traceback (most recent call last):
>>>>>>>>>   File "manage.py", line 29, in <module>
>>>>>>>>>     execute_from_command_line(sys.argv)
>>>>>>>>>   File
>>>>>>>>> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/__init__.py",
>>>>>>>>> line 354, in execute_from_command_line
>>>>>>>>>     utility.execute()
>>>>>>>>>   File
>>>>>>>>> line 346, in execute
>>>>>>>>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>>>>>>   File
>>>>>>>>> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/base.py",
>>>>>>>>> line 394, in run_from_argv
>>>>>>>>>     self.execute(*args, **cmd_options)
>>>>>>>>>   File
>>>>>>>>> line 445, in execute
>>>>>>>>>     output = self.handle(*args, **options)
>>>>>>>>>   File
>>>>>>>>> "/home/gnode/geonode_dev/geonode/geonode/geoserver/management/commands/updatelayers.py",
>>>>>>>>> line 124, in handle
>>>>>>>>>     execute_signals=True)
>>>>>>>>>   File
>>>>>>>>> "/home/gnode/geonode_dev/geonode/geonode/geoserver/helpers.py", line 636,
>>>>>>>>> in gs_slurp
>>>>>>>>>     layer.set_permissions(perm_spec)
>>>>>>>>>   File
>>>>>>>>> "/home/gnode/geonode_dev/geonode/geonode/security/models.py", line 216, in
>>>>>>>>> set_permissions
>>>>>>>>>     sync_geofence_with_guardian(self.layer, perms, group=group)
>>>>>>>>>   File "/home/gnode/geonode_dev/geonode/geonode/decorators.py",
>>>>>>>>> line 44, in wrapper
>>>>>>>>>     return func(*args, **kwargs)
>>>>>>>>>   File
>>>>>>>>> "/home/gnode/geonode_dev/geonode/geonode/security/utils.py", line 393, in
>>>>>>>>>     _update_geofence_rule(layer.name, layer.workspace, service)
>>>>>>>>>   File
>>>>>>>>> "/home/gnode/geonode_dev/geonode/geonode/security/utils.py", line 564, in
>>>>>>>>>     raise RuntimeError(msg)
>>>>>>>>> Exception: ('Failed to process lprca_ws_boundarywgs84',
>>>>>>>>> RuntimeError("Could not ADD GeoServer User None Rule for Layer
>>>>>>>>> u'lprca_ws_boundarywgs84'",))
>>>>>>>>> _______________________________________________
>>>>>>>>> geonode-users mailing list
>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181015/1816fd35/attachment.html>
More information about the geonode-users mailing list
