[GeoNode-users] Recurring User 'None' Error Geofence/Geoserver
Michael Fedak mikefedak at gmail.com
Mon Oct 15 07:54:04 PDT 2018
I confirm that this fixes the management commands.
On Mon, Oct 15, 2018 at 10:41 AM Alessio Fabiani <alessio.fabiani at gmail.com>
wrote:
> This should fix the duplicated rules issue when running the management
> commands
> https://github.com/GeoNode/geonode/pull/3988/files
> Il giorno lun 15 ott 2018 alle ore 16:13 Michael Fedak <
> mikefedak at gmail.com> ha scritto:
>> Thank Alessio,
>> This fixes the problem with documents. However I am still experiencing
>> the same problems with layers, I have commented on the pull request. I am
>> also having the same issue with superusers not being automatically logged
>> into geoserver.
>> On Mon, Oct 15, 2018 at 4:39 AM Alessio Fabiani <
>> alessio.fabiani at gmail.com> wrote:
>>> Hi Michael,
>>> thanks very much for helping on test.
>>> I've finally figured out where the problem was. Fix available here
>>> https://github.com/GeoNode/geonode/pull/3985
>>> I'll merge it as soon as the Travis checks pass. I'll also try to add
>>> some specific test cases for this particular issue.
>>> Il giorno dom 14 ott 2018 alle ore 21:08 Alessio Fabiani <
>>> alessio.fabiani at gmail.com> ha scritto:
>>>> Uhm very strange. Tomorrow will do some specific tests on this.
>>>> Currently I cannot figure out what the problem could be.
>>>> Il dom 14 ott 2018, 21:03 Michael Fedak <mikefedak at gmail.com> ha
>>>> scritto:
>>>>> Ok, fixed; I had my JAVA_OPTS entered incorrectly. Now geoserver
>>>>> starts. However, I am experiencing the same issues as before.
>>>>> On Sun, Oct 14, 2018 at 2:10 PM Michael Fedak <mikefedak at gmail.com>
>>>>> wrote:
>>>>>> Traced it back some more, it seems to be an issue with GWC:
>>>>>> Cannot resolve reference to bean 'gwcXmlConfigResourceProvider' while
>>>>>> setting constructor argument; nested exception is
>>>>>> org.springframework.beans.factory.BeanCreationException: Error creating
>>>>>> bean with name 'gwcXmlConfigResourceProvider' defined in URL
>>>>>> [jar:file:/opt/apache-tomcat-9.0.1/webapps/geoserver/WEB-INF/lib/gs-gwc-2.13-20181005.133101-833.jar!/geowebcache-core-context.xml]:
>>>>>> Bean instantiation via constructor failed; nested exception is
>>>>>> org.springframework.beans.BeanInstantiationException: Failed to instantiate
>>>>>> [org.geoserver.gwc.config.GeoserverXMLResourceProvider]: Constructor threw
>>>>>> exception; nested exception is java.lang.IllegalStateException: Could not
>>>>>> create directory.
>>>>>> On Sun, Oct 14, 2018 at 1:42 PM Michael Fedak <mikefedak at gmail.com>
>>>>>> wrote:
>>>>>>> Ok, got the war and attempted to deploy it. Tomcat is unable to
>>>>>>> deploy it due to an error associated with geotools:
>>>>>>> Geoserver log:
>>>>>>> 2018-10-14 10:24:59,152 TRACE [geotools.factory] - ENTRY
>>>>>>> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY)
>>>>>>> 2018-10-14 10:24:59,152 TRACE [geotools.factory] - CHECK
>>>>>>> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): user provided a Class.
>>>>>>> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): consider hint[last]
>>>>>>> AbstractEpsgMediator.
>>>>>>> 2018-10-14 10:24:59,152 TRACE [geotools.factory] - THROW
>>>>>>> (CRSAuthorityFactory, CRS_AUTHORITY_FACTORY): could not find implementation.
>>>>>>> 2018-10-14 10:24:59,152 INFO [geotools.util] - Weak collection
>>>>>>> cleaner stopped
>>>>>>> Catalina log:
>>>>>>> 14-Oct-2018 17:21:40.658 SEVERE [http-nio-8080-exec-13]
>>>>>>> org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks
>>>>>>> The web application [geoserver-2.13.x] created a ThreadLocal with key of
>>>>>>> type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal at 454bb710])
>>>>>>> and a value of type
>>>>>>> [org.geotools.referencing.operation.projection.TransverseMercator.Provider]
>>>>>>> (value [PROJECTION["Transverse_Mercator"]]) but failed to remove it when
>>>>>>> the web application was stopped. Threads are going to be renewed over time
>>>>>>> to try and avoid a probable memory leak.
>>>>>>> type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal at 86e380d])
>>>>>>> and a value of type [org.geotools.referencing.wkt.Formatter] (value []) but
>>>>>>> failed to remove it when the web application was stopped. Threads are going
>>>>>>> to be renewed over time to try and avoid a probable memory leak.
>>>>>>> I will keep trying to troubleshoot this.
>>>>>>> On Sun, Oct 14, 2018 at 10:02 AM Michael Fedak <mikefedak at gmail.com>
>>>>>>> wrote:
>>>>>>>> Never mind, found your build server:
>>>>>>>> https://build.geo-solutions.it/geonode/geoserver/latest/
>>>>>>>> On Sun, Oct 14, 2018 at 10:00 AM Michael Fedak <mikefedak at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> Ok, I can do that. Is there a place to download the build with the
>>>>>>>>> extension since build.geonode.org is down? Or shall I just
>>>>>>>>> download vanilla 2.13 and apply the extension myself?
>>>>>>>>> On Sun, Oct 14, 2018 at 9:56 AM Alessio Fabiani <
>>>>>>>>>> Uhm, most probably a Geoserver issue. From. Geoserver 2.13+
>>>>>>>>>> there's a fix to threat void users as * users.
>>>>>>>>>> Any chance to try out updating to Geoserver 2.13.x?
>>>>>>>>>> You won't have to change anything on the data dir.
>>>>>>>>>> Il ven 12 ott 2018, 19:11 Michael Fedak <mikefedak at gmail.com> ha
>>>>>>>>>> scritto:
>>>>>>>>>>> I am using the latest 2.8.x branch with Geoserver 2.12.2 and I
>>>>>>>>>>> keep receiving the following error when attempting to run the updatelayers
>>>>>>>>>>> command (Below).
>>>>>>>>>>> I am also having trouble with users not being sync'd with
>>>>>>>>>>> geoserver. I have gone through the documentation for security
>>>>>>>>>>> configuration, and checked that the geonode role/user apis are accessible
>>>>>>>>>>> to geoserver. As far as I can tell, nothing is blocking either geonode from
>>>>>>>>>>> reaching geofence or vice-versa.
>>>>>>>>>>> Traceback (most recent call last):
>>>>>>>>>>>   File "manage.py", line 29, in <module>
>>>>>>>>>>>     execute_from_command_line(sys.argv)
>>>>>>>>>>>   File
>>>>>>>>>>> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/__init__.py",
>>>>>>>>>>> line 354, in execute_from_command_line
>>>>>>>>>>>     utility.execute()
>>>>>>>>>>>   File
>>>>>>>>>>> line 346, in execute
>>>>>>>>>>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>>>>>>>>   File
>>>>>>>>>>> "/home/gnode/gndev/local/lib/python2.7/site-packages/django/core/management/base.py",
>>>>>>>>>>> line 394, in run_from_argv
>>>>>>>>>>>     self.execute(*args, **cmd_options)
>>>>>>>>>>>   File
>>>>>>>>>>> line 445, in execute
>>>>>>>>>>>     output = self.handle(*args, **options)
>>>>>>>>>>>   File
>>>>>>>>>>> "/home/gnode/geonode_dev/geonode/geonode/geoserver/management/commands/updatelayers.py",
>>>>>>>>>>> line 124, in handle
>>>>>>>>>>>     execute_signals=True)
>>>>>>>>>>>   File
>>>>>>>>>>> "/home/gnode/geonode_dev/geonode/geonode/geoserver/helpers.py", line 636,
>>>>>>>>>>> in gs_slurp
>>>>>>>>>>>     layer.set_permissions(perm_spec)
>>>>>>>>>>>   File
>>>>>>>>>>> "/home/gnode/geonode_dev/geonode/geonode/security/models.py", line 216, in
>>>>>>>>>>> set_permissions
>>>>>>>>>>>     sync_geofence_with_guardian(self.layer, perms, group=group)
>>>>>>>>>>>   File "/home/gnode/geonode_dev/geonode/geonode/decorators.py",
>>>>>>>>>>> line 44, in wrapper
>>>>>>>>>>>     return func(*args, **kwargs)
>>>>>>>>>>>   File
>>>>>>>>>>> "/home/gnode/geonode_dev/geonode/geonode/security/utils.py", line 393, in
>>>>>>>>>>>     _update_geofence_rule(layer.name, layer.workspace, service)
>>>>>>>>>>>   File
>>>>>>>>>>> "/home/gnode/geonode_dev/geonode/geonode/security/utils.py", line 564, in
>>>>>>>>>>>     raise RuntimeError(msg)
>>>>>>>>>>> Exception: ('Failed to process lprca_ws_boundarywgs84',
>>>>>>>>>>> RuntimeError("Could not ADD GeoServer User None Rule for Layer
>>>>>>>>>>> u'lprca_ws_boundarywgs84'",))
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181015/d8e6bfde/attachment-0001.html>
More information about the geonode-users mailing list
