[GeoNode-users] Migration from 2.4
Toni Schönbuchner toni.schoenbuchner at csgis.de
Thu Oct 18 01:12:16 PDT 2018
Perfect, thanks for sharing Olivier.
I think the best would be to patch this migration.
( It´s on my list but I couldn’t find time to look at the
model. )
All the best,
Toni
> Am 18.10.2018 um 08:45 schrieb Olivier Dalang <olivier.dalang at gmail.com>:
> Hi Toni,
> Thanks for the link, I somehow missed your issue when searching... I had the same issue than you at layers.0029_layer_service
> For reference, here's the procedure I used to successfully complete the migrations : https://github.com/olivierdalang/SPCgeonode#how-to-migrate-from-an-existing-standard-geonode-install <https://github.com/olivierdalang/SPCgeonode#how-to-migrate-from-an-existing-standard-geonode-install> (specific to SPCgeonode but can be transposed).
> Cheers,
> Olivier
> On Thu, Oct 18, 2018 at 6:26 PM Toni Schönbuchner <toni.schoenbuchner at csgis.de <mailto:toni.schoenbuchner at csgis.de>> wrote:
> Hi Olivier,
> I´ve migrated 2.4 -> 2.8 some time ago and found problems with db migrations as well.
> See Issue: https://github.com/GeoNode/geonode/issues/3870 <https://github.com/GeoNode/geonode/issues/3870>
> Did you go to 2.10? And can you share your errortrace somewhere?
> Chees,
> Toni
>> Today's Topics:
>>   1. Migration from 2.4 (Olivier Dalang)
>> Message: 1
>> Date: Thu, 18 Oct 2018 13:34:29 +1200
>> From: Olivier Dalang <olivier.dalang at gmail.com <mailto:olivier.dalang at gmail.com>>
>> To: geonode-users <geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>>
>> Subject: [GeoNode-users] Migration from 2.4
>> Message-ID:
>> 	<CAExk7p3RqhCDCg2B6cz0ZMSQigFuv5WxrsEkjZjFCGwULdUwpA at mail.gmail.com <mailto:CAExk7p3RqhCDCg2B6cz0ZMSQigFuv5WxrsEkjZjFCGwULdUwpA at mail.gmail.com>>
>> Content-Type: text/plain; charset="utf-8"
>> Hi !
>> I'm currently trying to migrate an old geonode install (2.4) to the current
>> version.
>> I managed to get the migrations to run after some tweaks (details below),
>> but the database is not consistent with the models.
>> Is this expected ? Or is there something wrong with the previous install ?
>> (it's old and I have no details about how it was installed). I searched a
>> bit about migrating old geonodes, but didn't find any details past
>> migrating with --fake-initial.
>> I can fix the schema with sqldiff (from django-extensions) but would like
>> to know if this is supposed to happen or not.
>> Thanks !!
>> Olivier
>> Here are the steps I did :
>> 1) Run migrations with --fake-initial. This fails at :
>> Applying layers.0029_layer_service...
>> django.db.utils.ProgrammingError: column "service_id" of relation
>> "layers_layer" already exists
>> 2) Manually fix this :
>> ALTER TABLE public.layers_layer DROP COLUMN service_id;
>> 3) Run the migrations (they complete)
>> 4) Check the consistency with python manage.py sqldiff -ae (from
>> django-extensions). There are inconsistencies, some of which will cause
>> problems (NOT NULL constraints, missing columns, etc.). Using this, I can
>> fix the schema (need to drop tables with no models).
>> BEGIN;
>> -- Model missing for table: account_accountdeletion
>> -- Model missing for table: account_signupcoderesult
>> -- Model missing for table: celery_taskmeta
>> -- Model missing for table: celery_tasksetmeta
>> -- Model missing for table: djcelery_intervalschedule
>> -- Model missing for table: djcelery_crontabschedule
>> -- Model missing for table: djcelery_periodictasks
>> -- Model missing for table: djcelery_workerstate
>> -- Model missing for table: account_signupcodeextended
>> -- Model missing for table: djcelery_taskstate
>> -- Application: actstream
>> -- Model: Follow
>> CREATE INDEX "actstream_follow_object_id"
>> ON "actstream_follow" ("object_id");
>> CREATE INDEX "actstream_follow_object_id_like"
>> ON "actstream_follow" ("object_id" varchar_pattern_ops);
>> CREATE INDEX "actstream_follow_started"
>> ON "actstream_follow" ("started");
>> -- Model: Action
>> CREATE INDEX "actstream_action_actor_object_id"
>> ON "actstream_action" ("actor_object_id");
>> CREATE INDEX "actstream_action_actor_object_id_like"
>> ON "actstream_action" ("actor_object_id" varchar_pattern_ops);
>> CREATE INDEX "actstream_action_verb"
>> ON "actstream_action" ("verb");
>> CREATE INDEX "actstream_action_verb_like"
>> ON "actstream_action" ("verb" varchar_pattern_ops);
>> CREATE INDEX "actstream_action_target_object_id"
>> ON "actstream_action" ("target_object_id");
>> CREATE INDEX "actstream_action_target_object_id_like"
>> ON "actstream_action" ("target_object_id" varchar_pattern_ops);
>> CREATE INDEX "actstream_action_action_object_object_id"
>> ON "actstream_action" ("action_object_object_id");
>> CREATE INDEX "actstream_action_action_object_object_id_like"
>> ON "actstream_action" ("action_object_object_id" varchar_pattern_ops);
>> CREATE INDEX "actstream_action_timestamp"
>> ON "actstream_action" ("timestamp");
>> CREATE INDEX "actstream_action_public"
>> ON "actstream_action" ("public");
>> ALTER TABLE "actstream_action"
>> ALTER "data" TYPE jsonb;
>> -- Application: tastypie
>> -- Model: ApiKey
>> ALTER TABLE "tastypie_apikey"
>> ALTER "key" TYPE varchar(128);
>> -- Application: base
>> -- Model: ContactRole
>> ALTER TABLE "base_contactrole"
>> ALTER COLUMN "resource_id" DROP NOT NULL;
>> -- Model: ResourceBase
>> ALTER TABLE "base_resourcebase"
>> DROP COLUMN "distribution_url";
>> DROP COLUMN "distribution_description";
>> -- Model: Link
>> ALTER TABLE "base_link"
>> -- Application: layers
>> -- Model: Layer
>> ALTER TABLE "layers_layer"
>> DROP COLUMN "distribution_description_en";
>> -- Application: maps
>> -- Model: Map
>> ALTER TABLE "maps_map"
>> -- Application: documents
>> -- Model: Document
>> ALTER TABLE "documents_document"
>> ALTER "doc_file" TYPE varchar(255);
>> ALTER "doc_url" TYPE varchar(255);
>> -- Application: people
>> -- Model: Profile
>> ALTER TABLE "people_profile"
>> ALTER "email" TYPE varchar(254);
>> ALTER COLUMN "last_login" DROP NOT NULL;
>> -- Application: groups
>> -- Model: GroupProfile
>> ALTER TABLE "groups_groupprofile"
>> -- Application: upload
>> -- Model: Upload
>> ALTER TABLE "upload_upload"
>> ADD COLUMN "mosaic_time_value" varchar(128);
>> ADD COLUMN "mosaic_time_regex" varchar(128);
>> ADD COLUMN "mosaic_elev_regex" varchar(128);
>> ADD COLUMN "mosaic_elev_value" varchar(128);
>> COMMIT;
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181018/e836c8ca/attachment.html <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181018/e836c8ca/attachment.html>>
>> Subject: Digest Footer
>> geonode-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/geonode-users <https://lists.osgeo.org/mailman/listinfo/geonode-users>
>> End of geonode-users Digest, Vol 45, Issue 69
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181018/c03d4b44/attachment-0001.html>
More information about the geonode-users mailing list
