[GeoNode-users] Migration from 2.4
Toni Schönbuchner
toni.schoenbuchner at csgis.de
Fri Oct 19 11:04:45 PDT 2018
Thanks Paolo.
But with World map the title ‚master of migration‘
Is yours :D
> remember, therefore you may need to run the sync_geofence command.
A small note: I darkly remember that this command will be removed.
(If I’m not wrong said at some GitHub issue by Alessio).
Cheers,
Toni
> Am 19.10.2018 um 19:56 schrieb Paolo Corti <pcorti at gmail.com>:
> Great instructions, thanks to both of you.
> One thing to add: I think 2.4 didn't use GeoFence as far as I can
> Also updatelayers should sync the permissions in GeoFence database
> tough.
> best
> Paolo
> On Thu, Oct 18, 2018 at 4:23 AM Toni Schönbuchner
> <toni.schoenbuchner at csgis.de> wrote:
>> A small addition for the record. I more or less followed Olivers path for migrations.
>> But needed to alter layers as well like:
>> sudo -u postgres psql -d geonode_new -c 'UPDATE base_resourcebase SET is_approved = TRUE'
>> # might be specific to my instance
>> sudo -u postgres psql -d geonode_new -c "DELETE FROM maps_maplayer WHERE maps_maplayer.name = 'AerialWithLabels'"
>> Cheers,
>> Toni
>> Am 18.10.2018 um 08:45 schrieb Olivier Dalang <olivier.dalang at gmail.com>:
>> Hi Toni,
>> Thanks for the link, I somehow missed your issue when searching... I had the same issue than you at layers.0029_layer_service
>> For reference, here's the procedure I used to successfully complete the migrations : https://github.com/olivierdalang/SPCgeonode#how-to-migrate-from-an-existing-standard-geonode-install (specific to SPCgeonode but can be transposed).
>> Cheers,
>> Olivier
>> On Thu, Oct 18, 2018 at 6:26 PM Toni Schönbuchner <toni.schoenbuchner at csgis.de> wrote:
>>> Hi Olivier,
>>> I´ve migrated 2.4 -> 2.8 some time ago and found problems with db migrations as well.
>>> See Issue: https://github.com/GeoNode/geonode/issues/3870
>>> Did you go to 2.10? And can you share your errortrace somewhere?
>>> Chees,
>>> Toni
>>> Today's Topics:
>>> 1. Migration from 2.4 (Olivier Dalang)
>>> Message: 1
>>> Date: Thu, 18 Oct 2018 13:34:29 +1200
>>> From: Olivier Dalang <olivier.dalang at gmail.com>
>>> To: geonode-users <geonode-users at lists.osgeo.org>
>>> Subject: [GeoNode-users] Migration from 2.4
>>> Message-ID:
>>> <CAExk7p3RqhCDCg2B6cz0ZMSQigFuv5WxrsEkjZjFCGwULdUwpA at mail.gmail.com>
>>> Content-Type: text/plain; charset="utf-8"
>>> Hi !
>>> I'm currently trying to migrate an old geonode install (2.4) to the current
>>> version.
>>> I managed to get the migrations to run after some tweaks (details below),
>>> but the database is not consistent with the models.
>>> Is this expected ? Or is there something wrong with the previous install ?
>>> (it's old and I have no details about how it was installed). I searched a
>>> bit about migrating old geonodes, but didn't find any details past
>>> migrating with --fake-initial.
>>> I can fix the schema with sqldiff (from django-extensions) but would like
>>> to know if this is supposed to happen or not.
>>> Thanks !!
>>> Olivier
>>> Here are the steps I did :
>>> 1) Run migrations with --fake-initial. This fails at :
>>> Applying layers.0029_layer_service...
>>> django.db.utils.ProgrammingError: column "service_id" of relation
>>> "layers_layer" already exists
>>> 2) Manually fix this :
>>> ALTER TABLE public.layers_layer DROP COLUMN service_id;
>>> 3) Run the migrations (they complete)
>>> 4) Check the consistency with python manage.py sqldiff -ae (from
>>> django-extensions). There are inconsistencies, some of which will cause
>>> problems (NOT NULL constraints, missing columns, etc.). Using this, I can
>>> fix the schema (need to drop tables with no models).
>>> BEGIN;
>>> -- Model missing for table: account_accountdeletion
>>> -- Model missing for table: account_signupcoderesult
>>> -- Model missing for table: celery_taskmeta
>>> -- Model missing for table: celery_tasksetmeta
>>> -- Model missing for table: djcelery_intervalschedule
>>> -- Model missing for table: djcelery_crontabschedule
>>> -- Model missing for table: djcelery_periodictasks
>>> -- Model missing for table: djcelery_workerstate
>>> -- Model missing for table: account_signupcodeextended
>>> -- Model missing for table: djcelery_taskstate
>>> -- Application: actstream
>>> -- Model: Follow
>>> CREATE INDEX "actstream_follow_object_id"
>>> ON "actstream_follow" ("object_id");
>>> CREATE INDEX "actstream_follow_object_id_like"
>>> ON "actstream_follow" ("object_id" varchar_pattern_ops);
>>> CREATE INDEX "actstream_follow_started"
>>> ON "actstream_follow" ("started");
>>> -- Model: Action
>>> CREATE INDEX "actstream_action_actor_object_id"
>>> ON "actstream_action" ("actor_object_id");
>>> CREATE INDEX "actstream_action_actor_object_id_like"
>>> ON "actstream_action" ("actor_object_id" varchar_pattern_ops);
>>> CREATE INDEX "actstream_action_verb"
>>> ON "actstream_action" ("verb");
>>> CREATE INDEX "actstream_action_verb_like"
>>> ON "actstream_action" ("verb" varchar_pattern_ops);
>>> CREATE INDEX "actstream_action_target_object_id"
>>> ON "actstream_action" ("target_object_id");
>>> CREATE INDEX "actstream_action_target_object_id_like"
>>> ON "actstream_action" ("target_object_id" varchar_pattern_ops);
>>> CREATE INDEX "actstream_action_action_object_object_id"
>>> ON "actstream_action" ("action_object_object_id");
>>> CREATE INDEX "actstream_action_action_object_object_id_like"
>>> ON "actstream_action" ("action_object_object_id" varchar_pattern_ops);
>>> CREATE INDEX "actstream_action_timestamp"
>>> ON "actstream_action" ("timestamp");
>>> CREATE INDEX "actstream_action_public"
>>> ON "actstream_action" ("public");
>>> ALTER TABLE "actstream_action"
>>> ALTER "data" TYPE jsonb;
>>> -- Application: tastypie
>>> -- Model: ApiKey
>>> ALTER TABLE "tastypie_apikey"
>>> ALTER "key" TYPE varchar(128);
>>> -- Application: base
>>> -- Model: ContactRole
>>> ALTER TABLE "base_contactrole"
>>> ALTER COLUMN "resource_id" DROP NOT NULL;
>>> -- Model: ResourceBase
>>> ALTER TABLE "base_resourcebase"
>>> DROP COLUMN "distribution_url";
>>> DROP COLUMN "distribution_description";
>>> -- Model: Link
>>> ALTER TABLE "base_link"
>>> -- Application: layers
>>> -- Model: Layer
>>> ALTER TABLE "layers_layer"
>>> DROP COLUMN "distribution_description_en";
>>> -- Application: maps
>>> -- Model: Map
>>> ALTER TABLE "maps_map"
>>> -- Application: documents
>>> -- Model: Document
>>> ALTER TABLE "documents_document"
>>> ALTER "doc_file" TYPE varchar(255);
>>> ALTER "doc_url" TYPE varchar(255);
>>> -- Application: people
>>> -- Model: Profile
>>> ALTER TABLE "people_profile"
>>> ALTER "email" TYPE varchar(254);
>>> ALTER COLUMN "last_login" DROP NOT NULL;
>>> -- Application: groups
>>> -- Model: GroupProfile
>>> ALTER TABLE "groups_groupprofile"
>>> -- Application: upload
>>> -- Model: Upload
>>> ALTER TABLE "upload_upload"
>>> ADD COLUMN "mosaic_time_value" varchar(128);
>>> ADD COLUMN "mosaic_time_regex" varchar(128);
>>> ADD COLUMN "mosaic_elev_regex" varchar(128);
>>> ADD COLUMN "mosaic_elev_value" varchar(128);
>>> COMMIT;
>>> -------------- next part --------------
>>> An HTML attachment was scrubbed...
>>> URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181018/e836c8ca/attachment.html>
>>> Subject: Digest Footer
>>> geonode-users mailing list
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> End of geonode-users Digest, Vol 45, Issue 69
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
More information about the geonode-users
