[GeoNode-users] Info about updatelayers command?
Ana Boljevic ana.boljevic at cedis.me
Fri Oct 26 06:45:24 PDT 2018
Sorry, but my docker experience is weak. I don't know how to solve the problem.
I want to apply fix from github without loosing my data. Is it possible?
Can you please write commands?
Regards,
Ana
-------- Original message --------
Date: 10/26/18 14:25 (GMT+01:00)
To: Ana Boljevic <ana.boljevic at cedis.me>
Cc: geonode-users <geonode-users at lists.osgeo.org>, geonode-users-bounces at lists.osgeo.org
Subject: RE: [GeoNode-users] Info about updatelayers command?
If you already cloned it then you can just execute
git pull origin master
Rebuilding all the containers is not terrible until you don’t remove the volumes.
Hope this helps
Francesco
On 26 Oct 2018, 12:54 +0200, Ana Boljevic <ana.boljevic at cedis.me>, wrote:
Dear Francesco,
Can you please be more specific.
Should we pull latest code with this command:
git clone https://github.com/GeoNode/geonode.git
Do I have to rebuild all containers or can I rebuild only django4geonode ?
Will I lose all of my settings and data by doing this ?
Regards,
Ana Boljević
Direkcija za razvoj, pristup mreži i ICT
Sektor za ICT
Služba za GIS i tehničku bazu podataka
[CEDIS]
DOO „Crnogorski elektrodistributivni sistem“ Podgorica
Ivana Milutinovića br.12, Podgorica
Tel: +382 20 408 473
www.cedis.me<http://www.cedis.me/>
[jelkica]Please do not print this e-mail unless you really need to
From: francesco bartoli [mailto:xbartolone at gmail.com]
Sent: Friday, October 26, 2018 11:12 AM
Cc: Michael Fedak <mikefedak at gmail.com>; geonode-users <geonode-users at lists.osgeo.org>; geonode-users-bounces at lists.osgeo.org
Subject: Re: [GeoNode-users] Info about updatelayers command?
If you apply changes or you have got new updates from the repo then you have to rebuild the image so please try to add and use the option "--build" that I mentioned above.
However if you are going to modify geonode and don't want to contribute back with pull requests then the suggested method would be to use a geonode-project.
Il giorno ven 26 ott 2018 alle ore 09:46 Ana Boljevic <ana.boljevic at cedis.me<mailto:ana.boljevic at cedis.me>> ha scritto:
Dear Francesco,
We did the following 15 days ago:
cd /home/geonode/geonode
docker-compose up -d
In meantime, we make changes on containers and then commit those changes.
Can you please explain in details how to apply fix from github ?
Regards
Ana
From: francesco bartoli <xbartolone at gmail.com<mailto:xbartolone at gmail.com>>
Date: 10/26/18 08:50 (GMT+01:00)
To: Ana Boljevic <ana.boljevic at cedis.me<mailto:ana.boljevic at cedis.me>>
Cc: Michael Fedak <mikefedak at gmail.com<mailto:mikefedak at gmail.com>>, geonode-users <geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>>, geonode-users-bounces at lists.osgeo.org<mailto:geonode-users-bounces at lists.osgeo.org>
Hi Ana,
can you please explain what did you do? The better to try is to pull the latest code from github and then run "docker-compose up --build" regardless of the version. The fix is for sure also in master.
Hope this helps,
Francesco
Il giorno ven 26 ott 2018 alle ore 07:16 Ana Boljevic <ana.boljevic at cedis.me<mailto:ana.boljevic at cedis.me>> ha scritto:
Dears,
We have tried to implement solution by Mr. Fabiani:
https://github.com/GeoNode/geonode/pull/3986/files
but after we have manually changed those 4 files django4geonode containers can't bring up anymore.
Does this solution apply also for GeoNode version 2.10rc4 ?
Thanks in advance.
Regards,
Ana Boljević
Sektor za ICT
From: Michael Fedak [mailto:mikefedak at gmail.com<mailto:mikefedak at gmail.com>]
Sent: Monday, October 22, 2018 3:20 PM
Cc: geonode-users-bounces at lists.osgeo.org<mailto:geonode-users-bounces at lists.osgeo.org>; geonode-users <geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>>
 I had a similar issue on 2.8 last week. See here for the discussion/fix: https://github.com/GeoNode/geonode/issues/3984
On Mon, Oct 22, 2018 at 7:25 AM Ana Boljevic <ana.boljevic at cedis.me<mailto:ana.boljevic at cedis.me>> wrote:
Dear Geonode community,
If someone knows little bit more about this, we would appreciate your help ☺ Explanation below:
We have installed Geonode on docker (version 2.10rc4). We imported first kml layer but updatelayers (from inside of django4geonode container) report problem "Could not ADD GeoServer User None Rule for Layer":
root at 5058e8a1637f:/usr/src/app# ./manage.py updatelayers
Inspecting the available layers in GeoServer ...
Found 1 layers, starting processing
Stopping process because --ignore-errors was not set and an error was found.
  File "./manage.py", line 29, in <module>
    execute_from_command_line(sys.argv)
  File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 364, in execute_from_command_line
    utility.execute()
  File "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py", line 356, in execute
    self.fetch_command(subcommand).run_from_argv(self.argv)
  File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 283, in run_from_argv
    self.execute(*args, **cmd_options)
  File "/usr/local/lib/python2.7/site-packages/django/core/management/base.py", line 330, in execute
    output = self.handle(*args, **options)
  File "/usr/src/app/geonode/geoserver/management/commands/updatelayers.py", line 124, in handle
    execute_signals=True)
  File "/usr/src/app/geonode/geoserver/helpers.py", line 637, in gs_slurp
    layer.set_permissions(perm_spec)
  File "/usr/src/app/geonode/security/models.py", line 216, in set_permissions
    sync_geofence_with_guardian(self.layer, perms, group=group)
  File "/usr/src/app/geonode/decorators.py", line 44, in wrapper
    return func(*args, **kwargs)
  File "/usr/src/app/geonode/security/utils.py", line 392, in sync_geofence_with_guardian
    _update_geofence_rule(layer.name<http://layer.name>, layer.workspace, service)
  File "/usr/src/app/geonode/security/utils.py", line 563, in _update_geofence_rule
    raise RuntimeError(msg)
Exception: ('Failed to process novi_r6_Slijepac_most_10kV', RuntimeError("Could not ADD GeoServer User None Rule for Layer u'novi_r6_Slijepac_most_10kV'",))
But the same command from celery4geonode container has different output:
root at bca672a5673d:/usr/src/app# ./manage.py updatelayers
Found 6 layers, starting processing
/usr/local/lib/python2.7/site-packages/owslib/iso.py:117: FutureWarning: the .identification and .serviceidentification properties will merge into .identification being a list of properties.  This is currently implemented in .identificationinfo.  Please see https://github.com/geopython/OWSLib/issues/38 for more information
  FutureWarning)
/usr/local/lib/python2.7/site-packages/owslib/iso.py:482: FutureWarning: The .keywords and .keywords2 properties will merge into the .keywords property in the future, with .keywords becoming a list of MD_Keywords instances. This is currently implemented in .keywords2. Please see https://github.com/geopython/OWSLib/issues/301 for more information
  FutureWarning)
/usr/local/lib/python2.7/site-packages/geoserver/style.py:73: FutureWarning: The behavior of this method will change in future versions.  Use specific 'len(elem)' or 'elem is not None' test instead.
  if not user_style:
/usr/local/lib/python2.7/site-packages/geoserver/style.py:77: FutureWarning: The behavior of this method will change in future versions.  Use specific 'len(elem)' or 'elem is not None' test instead.
  if user_style:
... Creating Thumbnail for Layer [geonode:OPSTINE]
[updated] Layer OPSTINE (1/6)
... Creating Thumbnail for Layer [geonode:novi_novi_r6_Pavino_Polje_10kV_izmijenjen]
[updated] Layer novi_novi_r6_Pavino_Polje_10kV_izmijenjen (2/6)
... Creating Thumbnail for Layer [geonode:novi_r6_Ambarine_Przista_10kV]
[created] Layer novi_r6_Ambarine_Przista_10kV (3/6)
... Creating Thumbnail for Layer [geonode:novi_r6_Gimnazija_10_kV]
[updated] Layer novi_r6_Gimnazija_10_kV (4/6)
... Creating Thumbnail for Layer [geonode:novi_r6_Planinica_10_kV]
[updated] Layer novi_r6_Planinica_10_kV (5/6)
... Creating Thumbnail for Layer [geonode:novi_r6_Rasovo_10kV]
[updated] Layer novi_r6_Rasovo_10kV (6/6)
Finished processing 6 layers in 53.0 seconds.
1 Created layers
5 Updated layers
0 Failed layers
8.830000 seconds per layer
Is such behavior normal ?
Thanks in advance.
Kind regards,
Ana Boljević
Sektor za ICT
geonode-users mailing list
https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/c3cfabc0/attachment-0001.html>
Type: image/png
Desc: 41799D00941E4F9D835FE3B20C02EF9E.png
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/c3cfabc0/attachment-0002.png>
Type: image/png
Desc: C3C0DE65A6A44755872317B0B90CE659.png
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/c3cfabc0/attachment-0003.png>
More information about the geonode-users mailing list
