[GeoNode-users] Best way to install geonode
Toni Schönbuchner toni.schoenbuchner at csgis.de
Fri Oct 26 07:58:27 PDT 2018
Great.
Are you on OSX? If so I’ ve lately had some issues with brew packages / gdal.
Let me know if you encounter further dependency errors.
Cheers,
Toni
> Am 26.10.2018 um 16:53 schrieb Paulo Frias <pfrias82 at gmail.com>:
> Probably a good shot in the dark.  I've named it "geonode" and not "my_genode" but I just erased the virtual environment to start over again.
> On Fri, 26 Oct 2018 at 15:42, Toni Schönbuchner <toni.schoenbuchner at csgis.de <mailto:toni.schoenbuchner at csgis.de>> wrote:
> Hi Paulo,
> Just a shot in the dark.
> When you started your project from template did you name it my_geonode?
> If not you should double check to use the correct settings:
> DJANGO_SETTINGS_MODULE=your_namend_geonode.settings paver reset
> Cheers,
> Toni
>> Am 26.10.2018 um 16:21 schrieb geonode-users-request at lists.osgeo.org <mailto:geonode-users-request at lists.osgeo.org>:
>> Send geonode-users mailing list submissions to
>> 	geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
>> To subscribe or unsubscribe via the World Wide Web, visit
>> 	https://lists.osgeo.org/mailman/listinfo/geonode-users <https://lists.osgeo.org/mailman/listinfo/geonode-users>
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>> 	geonode-users-owner at lists.osgeo.org <mailto:geonode-users-owner at lists.osgeo.org>
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of geonode-users digest..."
>> Today's Topics:
>>   1. Re: Best way to install geonode (Alessio Fabiani)
>> Message: 1
>> Date: Fri, 26 Oct 2018 16:21:38 +0200
>> From: Alessio Fabiani <alessio.fabiani at geo-solutions.it <mailto:alessio.fabiani at geo-solutions.it>>
>> To: Paulo Frias <pfrias82 at gmail.com <mailto:pfrias82 at gmail.com>>
>> Cc: Alessio Fabiani <alessio.fabiani at geo-solutions.it <mailto:alessio.fabiani at geo-solutions.it>>,  geonode-users
>> 	<geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>>
>> Subject: Re: [GeoNode-users] Best way to install geonode
>> Message-ID:
>> 	<CAM7ZvLLpVZXQauUZ9OmQNZLWB6iCtP=BP-cK82HDgUNvsLgZUQ at mail.gmail.com <mailto:BP-cK82HDgUNvsLgZUQ at mail.gmail.com>>
>> Content-Type: text/plain; charset="utf-8"
>>> From the link you sent to me, did you run also this one?
>> pip install -e . --upgrade
>> Il giorno ven 26 ott 2018 alle ore 16:19 Paulo Frias <pfrias82 at gmail.com <mailto:pfrias82 at gmail.com>>
>> ha scritto:
>>> I've followed this instructions
>>> https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#create-a-custom-project <https://github.com/geosolutions-it/geonode-project/blob/master/README.rst#create-a-custom-project>
>>> After "pip install Paver==1.2.4"
>>> (Geonode) bash-3.2$ DJANGO_SETTINGS_MODULE=my_geonode.settings paver reset
>>> Build failed: Unknown task: reset
>>> On Fri, 26 Oct 2018 at 15:14, Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it <mailto:alessio.fabiani at geo-solutions.it>> wrote:
>>>> Uhm, that is very strange. How did you setup GeoNode?
>>>> However, it seems to me that the issue is related to a missing dependency.
>>>> Try maybe by typing
>>>> Il giorno ven 26 ott 2018 alle ore 16:05 Paulo Frias <pfrias82 at gmail.com <mailto:pfrias82 at gmail.com>>
>>>> ha scritto:
>>>>> Hi Alessio,
>>>>> The  (pip install -r requirements.txt --upgrade) worked fine after
>>>>> another try.
>>>>> Now I'm stucked in the command (DJANGO_SETTINGS_MODULE=my_geonode.settings paver reset).
>>>>> This is the error produced:
>>>>> reset
>>>>> Traceback (most recent call last):
>>>>>  File "/Users/paulofrias/anaconda2/envs/Geonode/bin/paver", line 7, in
>>>>> <module>
>>>>>    from paver.tasks import main
>>>>> ImportError: No module named paver.tasks
>>>>> Any idea how to solve this?
>>>>> Thanks,
>>>>> Paulo
>>>>> On Fri, 26 Oct 2018 at 08:54, Alessio Fabiani <
>>>>>> Hi Paulo,
>>>>>> can you describe what's happening with a bit more detail?
>>>>>> That command should just start downloading the Python dependencies. If
>>>>>> it is stuck, most probably there's a problem reaching the PyPi repositories.
>>>>>> Il giorno gio 25 ott 2018 alle ore 16:58 Paulo Frias <
>>>>>> pfrias82 at gmail.com <mailto:pfrias82 at gmail.com>> ha scritto:
>>>>>>> Hi Alessio,
>>>>>>> I'm trying to install Geonode on Mac os X, following the tutorial you
>>>>>>> recommended (
>>>>>>> https://github.com/GeoNode/geonode-project#create-a-custom-project <https://github.com/GeoNode/geonode-project#create-a-custom-project>).
>>>>>>> When I run the command
>>>>>>> Nothing happens (I let it run on terminal for more than 2 hours).
>>>>>>> Can you help me with some possible solution?
>>>>>>> Thanks,
>>>>>>> Paulo Frias
>>>>>>> On Thu, 25 Oct 2018 at 14:49, Alessio Fabiani <
>>>>>>>> Hi Julierme,
>>>>>>>> please see my responses below.
>>>>>>>> "1 - can I make geonode-project my production environment? I meant
>>>>>>>> run GeoNode-Project as my production instance on the web."
>>>>>>>> Sure, but you will need to tweak a bit security options and settings
>>>>>>>> in order to secure and optimize your instance. Especially important are the
>>>>>>>> admin passwords and openid keys. This is valid in any case though.
>>>>>>>> "2 -  do I need GeoNode Core to run together with GeoNode-Project?"
>>>>>>>> geonode-project makes use of geonode-core as a dependency. Until we
>>>>>>>> do final releases (2.10 and 2.8), meaning that packages will go on Pypi
>>>>>>>> repositories, yes, you'll need the geonode-core among the python deps.
>>>>>>>> "3 - GeoNode-Project can run independently, no need for GeoNode Core?"
>>>>>>>> geonode-project runs independently, but it still needs geonode as a
>>>>>>>> dependency. However by using it, you won't touch the geonode-core. This
>>>>>>>> will allow you to easily keep it up to date with the development version,
>>>>>>>> without clashes.
>>>>>>>> "4 - If I am not misunderstanding, the tutorial in here <
>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html <http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/install_geonode_application.html>>
>>>>>>>> shows how to install either GeoNode at 2.8 Core and GeoNode at 2.8 DevMode
>>>>>>>> in a Ubuntu 16.04 LTS machine. Should we follow this tutorial for the same
>>>>>>>> GeoNode version or upgrade it to GeoNode 2.9.x?"
>>>>>>>> The tutorial and the documentation in general is outdated. We are
>>>>>>>> lacking of resources and, unfortunately, we did not found time yet to
>>>>>>>> cleanup it. I'm very sorry about that.
>>>>>>>> We will try to do it when we start officially the release process.
>>>>>>>> Il giorno gio 25 ott 2018 alle ore 14:44 Julierme Pinheiro <
>>>>>>>> juliermeopensourcedeveloper at gmail.com <mailto:juliermeopensourcedeveloper at gmail.com>> ha scritto:
>>>>>>>>> Hi Alessio,
>>>>>>>>> I would like to make some questions related to Annalisa's
>>>>>>>>> installation question. I installed geonode-project only to customize the
>>>>>>>>> look.
>>>>>>>>> Now:
>>>>>>>>> DevMode in a Ubuntu 16.04 LTS machine. Should we follow this tutorial for
>>>>>>>>> the same GeoNode version or upgrade it to GeoNode 2.9.x?
>>>>>>>>> Thank you very much for your time in advance
>>>>>>>>> Kind regards
>>>>>>>>> Julierme
>>>>>>>>> On Thu, Oct 25, 2018 at 8:29 AM Annalisa Schiavon <
>>>>>>>>> annalisa.schiavon at gmail.com <mailto:annalisa.schiavon at gmail.com>> wrote:
>>>>>>>>>> Thanks for the tip!
>>>>>>>>>> Annalisa
>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 13:15 Alessio Fabiani <
>>>>>>>>>> alessio.fabiani at geo-solutions.it <mailto:alessio.fabiani at geo-solutions.it>> ha scritto:
>>>>>>>>>>> Yes, absolutely. Currently, the deb installation is the most buggy
>>>>>>>>>>> and unstable one.
>>>>>>>>>>> It is worth notice that now GeoNode provides natively a way to
>>>>>>>>>>> customize the interface, at least some part of it, without the need of
>>>>>>>>>>> changing the files or the templates.
>>>>>>>>>>> Take a look at the GeoNode Themes option on the Django Admin gui.
>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 13:11 Annalisa Schiavon <
>>>>>>>>>>> annalisa.schiavon at gmail.com <mailto:annalisa.schiavon at gmail.com>> ha scritto:
>>>>>>>>>>>> Ok, thank you so much.
>>>>>>>>>>>> So you advise against the deb package installation, also if I
>>>>>>>>>>>> don't think to develop on geonode,  only to customize the look?
>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:41 Alessio Fabiani <
>>>>>>>>>>>>> If you want to install geonode for development, I would suggest
>>>>>>>>>>>>> following the procedure here
>>>>>>>>>>>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing <https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit?usp=sharing>
>>>>>>>>>>>>> If you want to start customizing your own portal (but still
>>>>>>>>>>>>> develop it), I would suggest starting from a geonode-project template. In
>>>>>>>>>>>>> that case, follow the instructions here
>>>>>>>>>>>>> Otherwise, you can virtual machines either using vagrant or
>>>>>>>>>>>>> docker. There are several ways and configurations around that you might
>>>>>>>>>>>>> want to evaluate.
>>>>>>>>>>>>> Il giorno gio 25 ott 2018 alle ore 12:27 Annalisa Schiavon <
>>>>>>>>>>>>>> Please someone may confirm that installation by deb packages,
>>>>>>>>>>>>>> with ppa:geonode/stable points to master version (2.8.x, 2.8.1 at now?)
>>>>>>>>>>>>>> What advantages does have VM Setup with VirtualBox installation
>>>>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html <http://docs.geonode.org/en/master/tutorials/install_and_admin/vm_setup_virtualbox.html>)?
>>>>>>>>>>>>>> And than the installation step by step described in
>>>>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html <http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html>
>>>>>>>>>>>>>> If I want to changes logos, colors and texts, is it recommended
>>>>>>>>>>>>>> install geonode-project and create a template, in similar way than once?
>>>>>>>>>>>>>> Because in https://github.com/GeoNode/geonode-project <https://github.com/GeoNode/geonode-project> I find
>>>>>>>>>>>>>> instructions only for a Python virtual environment.
>>>>>>>>>>>>>> Thank you for any hint.
>>>>>>>>>>>>>> Annalisa
>>>>>>>>>>>>>> Il giorno mer 24 ott 2018 alle ore 15:16 Annalisa Schiavon <
>>>>>>>>>>>>>>> Hi all.
>>>>>>>>>>>>>>> What is the best way to install geonode on Ubuntu for
>>>>>>>>>>>>>>> production, currently?
>>>>>>>>>>>>>>> Now we have geonode 2.4 working on ubuntu 16.04, installed via
>>>>>>>>>>>>>>> apt-get, following these commands:
>>>>>>>>>>>>>>> sudo add-apt-repository ppa:geonode/stable
>>>>>>>>>>>>>>> sudo apt-get update
>>>>>>>>>>>>>>> sudo apt-get install geonode
>>>>>>>>>>>>>>> Then I had installed geonode-project for a few changes in
>>>>>>>>>>>>>>> logos, colors and so on:
>>>>>>>>>>>>>>> django-admin startproject geoportale20 --template=
>>>>>>>>>>>>>>> https://github.com/GeoNode/geonode-project/archive/master.zip <https://github.com/GeoNode/geonode-project/archive/master.zip>
>>>>>>>>>>>>>>> -epy,rst
>>>>>>>>>>>>>>> sudo pip install -e geoportale20
>>>>>>>>>>>>>>> There are some procedures to migrate data from 2.4 to 2.8
>>>>>>>>>>>>>>> (jumping the 2.6 release)?
>>>>>>>>>>>>>>> Thank you,
>>>>>>>>>>>>>>> Annalisa
>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>>>>>>>> http://goo.gl/it488V <http://goo.gl/it488V> for more information.
>>>>>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>> Founder/Technical Lead
>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>>>>>>>>>>>> phone: +39 0584 962313
>>>>>>>>>>>>> fax:     +39 0584 1660272
>>>>>>>>>>>>> mob:   +39 331 6233686
>>>>>>>>>>>>> http://www.geo-solutions.it <http://www.geo-solutions.it/>
>>>>>>>>>>>>> http://twitter.com/geosolutions_it <http://twitter.com/geosolutions_it>
>>>>>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati
>>>>>>>>>>>>> personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei
>>>>>>>>>>>>> dati “GDPR”), si precisa che ogni circostanza inerente alla presente email
>>>>>>>>>>>>> (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
>>>>>>>>>>>>> conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente.
>>>>>>>>>>>>> Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni
>>>>>>>>>>>>> altra operazione è illecita. Le sarei comunque grato se potesse darmene
>>>>>>>>>>>>> notizia.
>>>>>>>>>>>>> This email is intended only for the person or entity to which it
>>>>>>>>>>>>> is addressed and may contain information that is privileged, confidential
>>>>>>>>>>>>> or otherwise protected from disclosure. We remind that - as provided by
>>>>>>>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>>>>>>>> notify us immediately by telephone or e-mail.
>>>>>>>>>>> @alfa7691
>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>>>> @alfa7691
>>>>>>>> GeoSolutions S.A.S.
>>>>>>>> This email is intended only for the person or entity to which it is
>>>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>> GeoServer Professional Services from the experts! Visit http://goo.gl/it488V <http://goo.gl/it488V>
>> @alfa7691
>> GeoSolutions S.A.S.
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/420ea2da/attachment.html <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/420ea2da/attachment.html>>
>> Subject: Digest Footer
>> End of geonode-users Digest, Vol 45, Issue 108
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181026/300de21f/attachment-0001.html>
More information about the geonode-users mailing list
