[GeoNode-users] Info about updatelayers command?
francesco bartoli xbartolone at gmail.com
Tue Oct 30 02:23:20 PDT 2018
Dear Ana,
Did you see errors in the django4geonode bootstratp? I did not. Also, the
git commands can be executed outside the container. Now that you have the
backup of the files changed I'd suggest to start from scratch with a new
clone from github. I would do the following actions:
   1. docker-compose down -v (so we remove all the volumes)
   2. Remove the geonode folder cloned by github
   3. Clone again geonode
   4. Modify the .env files just for address and port where you want to
   navigate geonode
      1. GEONODE_LB_HOST_IP
      2. GEONODE_LB_PORT
   5. Verify that geonode can be correctly browsed
   6. docker-compose down -v
   7. copy you custom changes
   8. docker-compose up --build -d
   9. See what happens and eventually share your changes
Il giorno mar 30 ott 2018 alle ore 07:11 Ana Boljevic <ana.boljevic at cedis.me>
ha scritto:
> Dear Francessco,
> We have done by your instruction, but after doing so, django4geonode
> container can't bring up :
> docker exec -i -t django4geonode bash
> root at 5058e8a1637f:/usr/src/app# git
> checkout
> M       docker-compose.yml
> M       entrypoint.sh
> M       geonode/settings.py
> M       scripts/docker/env/production/celery.env
> M       scripts/docker/env/production/django.env
> M       scripts/docker/env/production/geoserver.env
> git checkout -- /usr/src/app/docker-compose.yml
> git checkout -- /usr/src/app/entrypoint.sh
> git checkout -- /usr/src/app/geonode/settings.py
> git checkout -- /usr/src/app/scripts/docker/env/production/celery.env
> git checkout -- /usr/src/app/scripts/docker/env/production/django.env
> git checkout -- /usr/src/app/scripts/docker/env/production/geoserver.env
> git pull
> exit
> docker-compose stop
> docker-compose up --no-build -d
> Last part of docker-compose logs -t (full log in attachment):
> rabbitmq4geonode | 2018-10-29T12:43:20.588892346Z 2018-10-29 12:43:20.588
> [info] <0.540.0> Stopping application 'rabbit'
> rabbitmq4geonode | 2018-10-29T12:43:20.589183104Z 2018-10-29 12:43:20.589
> [info] <0.218.0> Peer discovery backend
> rabbit_peer_discovery_classic_config does not support registration,
> skipping unregistration.
> rabbitmq4geonode | 2018-10-29T12:43:20.589676074Z 2018-10-29 12:43:20.589
> [info] <0.432.0> stopped TCP Listener on [::]:5672
> rabbitmq4geonode | 2018-10-29T12:43:20.590238567Z 2018-10-29 12:43:20.590
> [info] <0.284.0> Closing all connections in vhost '/' on node
> 'rabbit at 39ca0b651470' because the vhost is stopping
> rabbitmq4geonode | 2018-10-29T12:43:20.595635959Z 2018-10-29 12:43:20.595
> [info] <0.343.0> Stopping message store for directory
> '/var/lib/rabbitmq/mnesia/rabbit at 39ca0b651470
> /msg_stores/vhosts/628WB79CIFDYO9LJI6DKMI09L/msg_store_persistent'
> rabbitmq4geonode | 2018-10-29T12:43:20.599318737Z 2018-10-29 12:43:20.599
> [info] <0.343.0> Message store for directory
> '/var/lib/rabbitmq/mnesia/rabbit at 39ca0b651470/msg_stores/vhosts/628WB79CIFDYO9LJI6DKMI09L/msg_store_persistent'
> is stopped
> rabbitmq4geonode | 2018-10-29T12:43:20.599446920Z 2018-10-29 12:43:20.599
> [info] <0.340.0> Stopping message store for directory
> /msg_stores/vhosts/628WB79CIFDYO9LJI6DKMI09L/msg_store_transient'
> rabbitmq4geonode | 2018-10-29T12:43:20.603303639Z 2018-10-29 12:43:20.603
> [info] <0.340.0> Message store for directory
> '/var/lib/rabbitmq/mnesia/rabbit at 39ca0b651470/msg_stores/vhosts/628WB79CIFDYO9LJI6DKMI09L/msg_store_transient'
> is stopped
> rabbitmq4geonode | 2018-10-29T12:43:20.608970890Z 2018-10-29 12:43:20.608
> [info] <0.540.0> Stopping application 'mnesia'
> rabbitmq4geonode | 2018-10-29T12:43:20.608994851Z 2018-10-29 12:43:20.608
> [info] <0.33.0> Application rabbit exited with reason: stopped
> rabbitmq4geonode | 2018-10-29T12:43:20.611254941Z 2018-10-29 12:43:20.611
> [info] <0.33.0> Application mnesia exited with reason: stopped
> rabbitmq4geonode | 2018-10-29T12:43:20.611271354Z 2018-10-29 12:43:20.611
> [info] <0.540.0> Stopping application 'rabbit_common'
> rabbitmq4geonode | 2018-10-29T12:43:20.611332663Z 2018-10-29 12:43:20.611
> [info] <0.540.0> Stopping application 'os_mon'
> rabbitmq4geonode | 2018-10-29T12:43:20.611344830Z 2018-10-29 12:43:20.611
> [info] <0.33.0> Application rabbit_common exited with reason: stopped
> rabbitmq4geonode | 2018-10-29T12:43:20.612459731Z 2018-10-29 12:43:20.612
> [info] <0.540.0> Successfully stopped RabbitMQ and its dependencies
> rabbitmq4geonode | 2018-10-29T12:43:20.612470835Z 2018-10-29 12:43:20.612
> [info] <0.33.0> Application os_mon exited with reason: stopped
> rabbitmq4geonode | 2018-10-29T12:43:20.612722429Z 2018-10-29 12:43:20.612
> [info] <0.540.0> Halting Erlang VM with the following applications:
> rabbitmq4geonode | 2018-10-29T12:43:20.612734347Z     ranch_proxy_protocol
> rabbitmq4geonode | 2018-10-29T12:43:20.612739407Z     ranch
> rabbitmq4geonode | 2018-10-29T12:43:20.612744182Z     ssl
> rabbitmq4geonode | 2018-10-29T12:43:20.612748862Z     public_key
> rabbitmq4geonode | 2018-10-29T12:43:20.612753388Z     asn1
> rabbitmq4geonode | 2018-10-29T12:43:20.612757814Z     xmerl
> rabbitmq4geonode | 2018-10-29T12:43:20.612762239Z     recon
> rabbitmq4geonode | 2018-10-29T12:43:20.612766700Z     jsx
> rabbitmq4geonode | 2018-10-29T12:43:20.612771098Z     inets
> rabbitmq4geonode | 2018-10-29T12:43:20.612775351Z     crypto
> rabbitmq4geonode | 2018-10-29T12:43:20.612779629Z     lager
> rabbitmq4geonode | 2018-10-29T12:43:20.612783758Z     goldrush
> rabbitmq4geonode | 2018-10-29T12:43:20.612788015Z     compiler
> rabbitmq4geonode | 2018-10-29T12:43:20.612803534Z     syntax_tools
> rabbitmq4geonode | 2018-10-29T12:43:20.612808638Z     syslog
> rabbitmq4geonode | 2018-10-29T12:43:20.612813120Z     sasl
> rabbitmq4geonode | 2018-10-29T12:43:20.612817409Z     stdlib
> rabbitmq4geonode | 2018-10-29T12:43:20.612821461Z     kernel
> rabbitmq4geonode | 2018-10-29T12:43:20.612959249Z Gracefully halting
> Erlang VM
> rabbitmq4geonode | 2018-10-29T12:43:33.091907754Z 2018-10-29 12:43:33.065
> [info] <0.33.0> Application lager started on node rabbit at 39ca0b651470
> rabbitmq4geonode | 2018-10-29T12:43:36.029168547Z 2018-10-29 12:43:36.028
> [info] <0.33.0> Application crypto started on node rabbit at 39ca0b651470
> rabbitmq4geonode | 2018-10-29T12:43:36.029992423Z 2018-10-29 12:43:36.029
> [info] <0.33.0> Application inets started on node rabbit at 39ca0b651470
> rabbitmq4geonode | 2018-10-29T12:43:36.030546671Z 2018-10-29 12:43:36.030
> [info] <0.33.0> Application os_mon started on node rabbit at 39ca0b651470
> rabbitmq4geonode | 2018-10-29T12:43:36.030810293Z 2018-10-29 12:43:36.030
> [info] <0.33.0> Application jsx started on node rabbit at 39ca0b651470
> rabbitmq4geonode | 2018-10-29T12:43:36.049033039Z 2018-10-29 12:43:36.048
> [info] <0.33.0> Application mnesia started on node rabbit at 39ca0b651470
> rabbitmq4geonode | 2018-10-29T12:43:36.050909483Z 2018-10-29 12:43:36.050
> [info] <0.33.0> Application recon started on node rabbit at 39ca0b651470
> rabbitmq4geonode | 2018-10-29T12:43:36.052442655Z 2018-10-29 12:43:36.051
> [info] <0.33.0> Application xmerl started on node rabbit at 39ca0b651470
> rabbitmq4geonode | 2018-10-29T12:43:36.052714043Z 2018-10-29 12:43:36.052
> [info] <0.33.0> Application asn1 started on node rabbit at 39ca0b651470
> rabbitmq4geonode | 2018-10-29T12:43:36.053066947Z 2018-10-29 12:43:36.052
> [info] <0.33.0> Application public_key started on node rabbit at 39ca0b651470
> rabbitmq4geonode | 2018-10-29T12:43:36.053215735Z 2018-10-29 12:43:36.052
> [info] <0.33.0> Application ssl started on node rabbit at 39ca0b651470
> rabbitmq4geonode | 2018-10-29T12:43:36.053542399Z 2018-10-29 12:43:36.053
> [info] <0.33.0> Application ranch started on node rabbit at 39ca0b651470
> rabbitmq4geonode | 2018-10-29T12:43:36.053777832Z 2018-10-29 12:43:36.053
> [info] <0.33.0> Application ranch_proxy_protocol started on node
> rabbitmq4geonode | 2018-10-29T12:43:36.053924296Z 2018-10-29 12:43:36.053
> [info] <0.33.0> Application rabbit_common started on node
> rabbitmq4geonode | 2018-10-29T12:43:36.054515076Z 2018-10-29 12:43:36.054
> [info] <0.222.0>
> rabbitmq4geonode | 2018-10-29T12:43:36.054553438Z  Starting RabbitMQ 3.7.8
> on Erlang 20.3.8.5
> rabbitmq4geonode | 2018-10-29T12:43:36.054561791Z  Copyright (C) 2007-2018
> Pivotal Software, Inc.
> rabbitmq4geonode | 2018-10-29T12:43:36.054567013Z  Licensed under the
> MPL.  See http://www.rabbitmq.com/
> rabbitmq4geonode | 2018-10-29T12:43:36.054751509Z
> rabbitmq4geonode | 2018-10-29T12:43:36.054764333Z   ##  ##
> rabbitmq4geonode | 2018-10-29T12:43:36.054769868Z   ##  ##      RabbitMQ
> 3.7.8. Copyright (C) 2007-2018 Pivotal Software, Inc.
> rabbitmq4geonode | 2018-10-29T12:43:36.054774924Z   ##########  Licensed
> under the MPL.  See http://www.rabbitmq.com/
> rabbitmq4geonode | 2018-10-29T12:43:36.054779743Z   ######  ##
> rabbitmq4geonode | 2018-10-29T12:43:36.054784220Z   ##########  Logs:
> <stdout>
> rabbitmq4geonode | 2018-10-29T12:43:36.054800451Z
> rabbitmq4geonode | 2018-10-29T12:43:36.054805564Z               Starting
> broker...
> rabbitmq4geonode | 2018-10-29T12:43:36.056202160Z 2018-10-29 12:43:36.055
> [info] <0.222.0>
> rabbitmq4geonode | 2018-10-29T12:43:36.056215245Z  node           :
> rabbitmq4geonode | 2018-10-29T12:43:36.056220775Z  home dir       :
> /var/lib/rabbitmq
> rabbitmq4geonode | 2018-10-29T12:43:36.056225395Z  config file(s) :
> /etc/rabbitmq/rabbitmq.conf
> rabbitmq4geonode | 2018-10-29T12:43:36.056230030Z  cookie hash    :
> ex/x+PypG9qStotoDhyANw==
> rabbitmq4geonode | 2018-10-29T12:43:36.056234375Z  log(s)         :
> <stdout>
> rabbitmq4geonode | 2018-10-29T12:43:36.056239009Z  database dir   :
> rabbitmq4geonode | 2018-10-29T12:43:36.091638434Z 2018-10-29 12:43:36.091
> [info] <0.264.0> Memory high watermark set to 3192 MiB (3347958988 bytes)
> of 7982 MiB (8369897472 bytes) total
> rabbitmq4geonode | 2018-10-29T12:43:36.107514572Z 2018-10-29 12:43:36.107
> [info] <0.266.0> Enabling free disk space monitoring
> rabbitmq4geonode | 2018-10-29T12:43:36.107690505Z 2018-10-29 12:43:36.107
> [info] <0.266.0> Disk free limit set to 50MB
> rabbitmq4geonode | 2018-10-29T12:43:36.126513337Z 2018-10-29 12:43:36.126
> [info] <0.269.0> Limiting to approx 1048476 file handles (943626 sockets)
> rabbitmq4geonode | 2018-10-29T12:43:36.126767100Z 2018-10-29 12:43:36.126
> [info] <0.270.0> FHC read buffering:  OFF
> rabbitmq4geonode | 2018-10-29T12:43:36.126895478Z 2018-10-29 12:43:36.126
> [info] <0.270.0> FHC write buffering: ON
> rabbitmq4geonode | 2018-10-29T12:43:36.129582128Z 2018-10-29 12:43:36.129
> [info] <0.222.0> Waiting for Mnesia tables for 30000 ms, 9 retries left
> rabbitmq4geonode | 2018-10-29T12:43:36.157630132Z 2018-10-29 12:43:36.157
> rabbitmq4geonode | 2018-10-29T12:43:36.157694197Z 2018-10-29 12:43:36.157
> [info] <0.222.0> Peer discovery backend
> skipping registration.
> rabbitmq4geonode | 2018-10-29T12:43:36.158718359Z 2018-10-29 12:43:36.158
> [info] <0.222.0> Priority queues enabled, real BQ is rabbit_variable_queue
> rabbitmq4geonode | 2018-10-29T12:43:36.162726893Z 2018-10-29 12:43:36.162
> [info] <0.292.0> Starting rabbit_node_monitor
> rabbitmq4geonode | 2018-10-29T12:43:36.189329652Z 2018-10-29 12:43:36.188
> [info] <0.338.0> Making sure data directory
> '/var/lib/rabbitmq/mnesia/rabbit at 39ca0b651470/msg_stores/vhosts/628WB79CIFDYO9LJI6DKMI09L'
> for vhost '/' exists
> rabbitmq4geonode | 2018-10-29T12:43:36.205375889Z 2018-10-29 12:43:36.205
> [info] <0.338.0> Starting message stores for vhost '/'
> rabbitmq4geonode | 2018-10-29T12:43:36.205674103Z 2018-10-29 12:43:36.205
> [info] <0.342.0> Message store
> "628WB79CIFDYO9LJI6DKMI09L/msg_store_transient": using
> rabbit_msg_store_ets_index to provide index
> rabbitmq4geonode | 2018-10-29T12:43:36.208536564Z 2018-10-29 12:43:36.208
> [info] <0.338.0> Started message store of type transient for vhost '/'
> rabbitmq4geonode | 2018-10-29T12:43:36.208822596Z 2018-10-29 12:43:36.208
> [info] <0.345.0> Message store
> "628WB79CIFDYO9LJI6DKMI09L/msg_store_persistent": using
> rabbitmq4geonode | 2018-10-29T12:43:36.215934044Z 2018-10-29 12:43:36.215
> [info] <0.338.0> Started message store of type persistent for vhost '/'
> rabbitmq4geonode | 2018-10-29T12:43:36.243343874Z 2018-10-29 12:43:36.243
> [info] <0.434.0> started TCP Listener on [::]:5672
> rabbitmq4geonode | 2018-10-29T12:43:36.243855088Z 2018-10-29 12:43:36.243
> [info] <0.222.0> Setting up a table for connection tracking on this node:
> tracked_connection_on_node_rabbit at 39ca0b651470
> rabbitmq4geonode | 2018-10-29T12:43:36.244177734Z 2018-10-29 12:43:36.243
> [info] <0.222.0> Setting up a table for per-vhost connection counting on
> this node: tracked_connection_per_vhost_on_node_rabbit at 39ca0b651470
> rabbitmq4geonode | 2018-10-29T12:43:36.244673829Z 2018-10-29 12:43:36.244
> [info] <0.33.0> Application rabbit started on node rabbit at 39ca0b651470
> rabbitmq4geonode | 2018-10-29T12:43:36.665060821Z 2018-10-29 12:43:36.664
> [info] <0.5.0> Server startup complete; 0 plugins started.
> rabbitmq4geonode | 2018-10-29T12:43:36.665094232Z  completed with 0
> plugins.
> rabbitmq4geonode | 2018-10-29T12:43:52.068167997Z 2018-10-29 12:43:52.067
> [info] <0.440.0> accepting AMQP connection <0.440.0> (172.18.0.3:42078 ->
> 172.18.0.2:5672)
> rabbitmq4geonode | 2018-10-29T12:43:52.070800718Z 2018-10-29 12:43:52.070
> [info] <0.440.0> connection <0.440.0> (172.18.0.3:42078 -> 172.18.0.2:5672):
> user 'guest' authenticated and granted access to vhost '/'
> rabbitmq4geonode | 2018-10-29T12:43:52.081172134Z 2018-10-29 12:43:52.080
> [info] <0.449.0> accepting AMQP connection <0.449.0> (172.18.0.3:42080 ->
> 172.18.0.2:5672)
> rabbitmq4geonode | 2018-10-29T12:43:52.103513457Z 2018-10-29 12:43:52.103
> [info] <0.449.0> connection <0.449.0> (172.18.0.3:42080 -> 172.18.0.2:5672):
> rabbitmq4geonode | 2018-10-29T12:43:52.143869719Z 2018-10-29 12:43:52.143
> [info] <0.469.0> accepting AMQP connection <0.469.0> (172.18.0.3:42082 ->
> 172.18.0.2:5672)
> rabbitmq4geonode | 2018-10-29T12:43:52.147983783Z 2018-10-29 12:43:52.147
> [info] <0.469.0> connection <0.469.0> (172.18.0.3:42082 -> 172.18.0.2:5672):
> Regards,
> *Ana Boljević*
> Direkcija za razvoj, pristup mreži i ICT
> Sektor za ICT
> Služba za GIS i tehničku bazu podataka
> *[image: CEDIS]*
> *DOO „Crnogorski elektrodistributivni sistem“ Podgorica*
> Ivana Milutinovića br.12, Podgorica
> Tel: +382 20 408 473
> *www.cedis.me <http://www.cedis.me/>*
> [image: jelkica]Please do not print this e-mail unless you really need to
> *From:* francesco bartoli [mailto:xbartolone at gmail.com]
> *Sent:* Sunday, October 28, 2018 3:02 PM
> *To:* Ana Boljevic <ana.boljevic at cedis.me>
> *Cc:* Alessio Fabiani <alessio.fabiani at geo-solutions.it>;
> geonode-users-bounces at lists.osgeo.org; geonode-users <
> geonode-users at lists.osgeo.org>
> *Subject:* Re: [GeoNode-users] Info about updatelayers command?
> Ana,
> if you run
> git checkout -- <file>
> for each changed file then you don't need to remove them. Can you try
> again? What is the error from the container that doesn't start?
> Il giorno dom 28 ott 2018 alle ore 12:54 Ana Boljevic <
> ana.boljevic at cedis.me> ha scritto:
> Dear Francesco and Alessio,
> We have moved all changed files in /tmp folder of the host, git pull, put
> moved files back in thair original path and than
> docker-compose stop
> but now django container can't bring up
> checkout
> M       entrypoint.sh
> geonode at testgis:/tmp$ docker cp 5058e8a1637f:/usr/src/app/entrypoint.sh
> /tmp
> geonode at testgis:/tmp$ docker cp 5058e8a1637f:/usr/src/app/geonode/
> settings.py /tmp
> 5058e8a1637f:/usr/src/app/scripts/docker/env/production/celery.env /tmp
> 5058e8a1637f:/usr/src/app/scripts/docker/env/production/django.env /tmp
> 5058e8a1637f:/usr/src/app/scripts/docker/env/production/geoserver.env /tmp
> rm docker-compose.yml entrypoint.sh geonode/settings.py
> git pull
> geonode at testgis:~/geonode$ docker cp /tmp/docker-compose.yml
> 5058e8a1637f:/usr/src/app/docker-compose.yml
> geonode at testgis:~/geonode$ docker cp /tmp/entrypoint.sh
> geonode at testgis:~/geonode$ docker cp /tmp/settings.py
> 5058e8a1637f:/usr/src/app/geonode/settings.py
> geonode at testgis:~/geonode$ docker cp /tmp/celery.env
> geonode at testgis:~/geonode$ docker cp /tmp/django.env
> geonode at testgis:~/geonode$ docker cp /tmp/geoserver.env
> docker-compose stop
> Regards,
> Ana
> -------- Original message --------
> From: francesco bartoli <xbartolone at gmail.com>
> Date: 10/27/18 00:36 (GMT+01:00)
> To: Ana Boljevic <ana.boljevic at cedis.me>
> Cc: Alessio Fabiani <alessio.fabiani at geo-solutions.it>,
> geonode-users-bounces at lists.osgeo.org, geonode-users <
> Subject: Re: [GeoNode-users] Info about updatelayers command?
> Yes Alessio but I guessed Ana would be ended up with a merge issue. One
> easy solution if settings.py is the only file edited would be to copy it
> somewhere else then run
> *git checkout*
> before
> *git pull*
> finally overwrite settings.py with the copied one.
> Il giorno ven 26 ott 2018 alle ore 20:00 Ana Boljevic <
> Sorry,
> we have error, I didn't notice at first:
> geonode at testgis:~/geonode$ docker exec -i -t django4geonode bash
> root at 5058e8a1637f:/usr/src/app# git pull
> remote: Enumerating objects: 321, done.
> remote: Counting objects: 100% (321/321), done.
> remote: Compressing objects: 100% (20/20), done.
> remote: Total 620 (delta 308), reused 307 (delta 301), pack-reused 299
> Receiving objects: 100% (620/620), 3.66 MiB | 812.00 KiB/s, done.
> Resolving deltas: 100% (441/441), completed with 126 local objects.
> From https://github.com/GeoNode/geonode
>    33aa3e6..34ac634  master     -> origin/master
>    2ea8bc6..89efc19  2.8.x      -> origin/2.8.x
>  * [new branch]      ISSUE_4025 -> origin/ISSUE_4025
> Updating 33aa3e6..34ac634
> error: Your local changes to the following files would be overwritten by
> merge:
>         geonode/settings.py
> Please, commit your changes or stash them before you can merge.
> Aborting
> Regards,
> Ana
> From: Ana Boljevic <ana.boljevic at cedis.me>
> Date: 10/26/18 19:50 (GMT+01:00)
> To: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
> Cc: geonode-users-bounces at lists.osgeo.org, geonode-users <
> Dear Alessio,
> We have done:
> git pull
> exit
> docker-compose stop
> and after that, from django4geonode container error still remains:
> root at 5058e8a1637f:/usr/src/app# python manage.py updatelayers
> Inspecting the available layers in GeoServer ...
> Found 6 layers, starting processing
> Stopping process because --ignore-errors was not set and an error was
> found.
> Traceback (most recent call last):
>   File "manage.py", line 29, in <module>
>     execute_from_command_line(sys.argv)
>   File
> "/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py",
> line 364, in execute_from_command_line
>     utility.execute()
>   File
> line 356, in execute
>     self.fetch_command(subcommand).run_from_argv(self.argv)
>   File "/usr/local/lib/python2.7/site-packages/django/core/management/
> base.py", line 283, in run_from_argv
>     self.execute(*args, **cmd_options)
> base.py", line 330, in execute
>     output = self.handle(*args, **options)
>   File "/usr/src/app/geonode/geoserver/management/commands/updatelayers.py",
> line 124, in handle
>     execute_signals=True)
>   File "/usr/src/app/geonode/geoserver/helpers.py", line 637, in gs_slurp
>     layer.set_permissions(perm_spec)
>   File "/usr/src/app/geonode/security/models.py", line 216, in
> set_permissions
>     sync_geofence_with_guardian(self.layer, perms, group=group)
>   File "/usr/src/app/geonode/decorators.py", line 44, in wrapper
>     return func(*args, **kwargs)
>   File "/usr/src/app/geonode/security/utils.py", line 392, in
>     _update_geofence_rule(layer.name, layer.workspace, service)
>   File "/usr/src/app/geonode/security/utils.py", line 563, in
>     raise RuntimeError(msg)
> Exception: ('Failed to process OPSTINE', RuntimeError("Could not ADD
> GeoServer User None Rule for Layer u'OPSTINE'",))
> Regards,
> Ana
> From: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
> Date: 10/26/18 15:51 (GMT+01:00)
> Cc: Francesco Bartoli <xbartolone at gmail.com>,
> Hi Ana,
> In order to update the GeoNode on your GeoNode instance, I guess you can
> try something like
> git pull
> exit
> docker-compose stop
> @Francesco Bartoli <xbartolone at gmail.com> can you confirm?
> Il giorno ven 26 ott 2018 alle ore 15:45 Ana Boljevic <
> Sorry, but my docker experience is weak. I don't know how to solve the
> problem.
> I want to apply fix from github without loosing my data. Is it possible?
> Can you please write commands?
> Regards,
> Ana
> From: Francesco Bartoli <xbartolone at gmail.com>
> Date: 10/26/18 14:25 (GMT+01:00)
> Cc: geonode-users <geonode-users at lists.osgeo.org>,
> Subject: RE: [GeoNode-users] Info about updatelayers command?
> If you already cloned it then you can just execute
> *git pull origin master*
> Rebuilding all the containers is not terrible until you don’t remove the
> volumes.
> Hope this helps
> Francesco
> On 26 Oct 2018, 12:54 +0200, Ana Boljevic <ana.boljevic at cedis.me>, wrote:
> Dear Francesco,
> Can you please be more specific.
> Should we pull latest code with this command:
> git clone https://github.com/GeoNode/geonode.git
> Do I have to rebuild all containers or can I rebuild only django4geonode ?
> Will I lose all of my settings and data by doing this ?
> Regards,
> *Ana Boljević*
> Sektor za ICT
> *Sent:* Friday, October 26, 2018 11:12 AM
> *Cc:* Michael Fedak <mikefedak at gmail.com>; geonode-users <
> geonode-users at lists.osgeo.org>; geonode-users-bounces at lists.osgeo.org
> If you apply changes or you have got new updates from the repo then you
> have to rebuild the image so please try to add and use the option "--build"
> that I mentioned above.
> However if you are going to modify geonode and don't want to contribute
> back with pull requests then the suggested method would be to use a
> geonode-project.
> Il giorno ven 26 ott 2018 alle ore 09:46 Ana Boljevic <
> Dear Francesco,
> We did the following 15 days ago:
> cd /home/geonode/geonode
> docker-compose up -d
> In meantime, we make changes on containers and then commit those changes.
> Can you please explain in details how to apply fix from github ?
> Regards
> Ana
> Date: 10/26/18 08:50 (GMT+01:00)
> Cc: Michael Fedak <mikefedak at gmail.com>, geonode-users <
> geonode-users at lists.osgeo.org>, geonode-users-bounces at lists.osgeo.org
> Hi Ana,
> can you please explain what did you do? The better to try is to pull the
> latest code from github and then run "docker-compose up --build" regardless
> of the version. The fix is for sure also in master.
> Hope this helps,
> Francesco
> Il giorno ven 26 ott 2018 alle ore 07:16 Ana Boljevic <
> Dears,
> We have tried to implement solution by Mr. Fabiani:
> https://github.com/GeoNode/geonode/pull/3986/files
> but after we have manually changed those 4 files django4geonode containers
> can't bring up anymore.
> Does this solution apply also for GeoNode version 2.10rc4 ?
> Thanks in advance.
> Regards,
> *Ana Boljević*
> Sektor za ICT
> *From:* Michael Fedak [mailto:mikefedak at gmail.com]
> *Sent:* Monday, October 22, 2018 3:20 PM
> *Cc:* geonode-users-bounces at lists.osgeo.org; geonode-users <
>  I had a similar issue on 2.8 last week. See here for the discussion/fix:
> https://github.com/GeoNode/geonode/issues/3984
> On Mon, Oct 22, 2018 at 7:25 AM Ana Boljevic <ana.boljevic at cedis.me>
> wrote:
> Dear Geonode community,
> If someone knows little bit more about this, we would appreciate your help
> J Explanation below:
> We have installed Geonode on docker (version 2.10rc4). We imported first
> kml layer but updatelayers (from inside of django4geonode container) report
> problem "Could not ADD GeoServer User None Rule for Layer":
> root at 5058e8a1637f:/usr/src/app# ./manage.py updatelayers
> Found 1 layers, starting processing
> found.
>   File "./manage.py", line 29, in <module>
>   File
>     utility.execute()
>   File
>   File
> "/usr/local/lib/python2.7/site-packages/django/core/management/base.py",
>   File
>   File
> "/usr/src/app/geonode/geoserver/management/commands/updatelayers.py", line
> 124, in handle
> set_permissions
> Exception: ('Failed to process novi_r6_Slijepac_most_10kV',
> RuntimeError("Could not ADD GeoServer User None Rule for Layer
> u'novi_r6_Slijepac_most_10kV'",))
> But the same command from celery4geonode container has different output:
> root at bca672a5673d:/usr/src/app# ./manage.py updatelayers
> /usr/local/lib/python2.7/site-packages/owslib/iso.py:117: FutureWarning:
> the .identification and .serviceidentification properties will merge into
> .identification being a list of properties.  This is currently implemented
> in .identificationinfo.  Please see
> https://github.com/geopython/OWSLib/issues/38 for more information
>   FutureWarning)
> /usr/local/lib/python2.7/site-packages/owslib/iso.py:482: FutureWarning:
> The .keywords and .keywords2 properties will merge into the .keywords
> property in the future, with .keywords becoming a list of MD_Keywords
> instances. This is currently implemented in .keywords2. Please see
> https://github.com/geopython/OWSLib/issues/301 for more information
>   FutureWarning)
> /usr/local/lib/python2.7/site-packages/geoserver/style.py:73:
> FutureWarning: The behavior of this method will change in future versions.
> Use specific 'len(elem)' or 'elem is not None' test instead.
>   if not user_style:
> /usr/local/lib/python2.7/site-packages/geoserver/style.py:77:
>   if user_style:
> ... Creating Thumbnail for Layer [geonode:OPSTINE]
> [updated] Layer OPSTINE (1/6)
> [geonode:novi_novi_r6_Pavino_Polje_10kV_izmijenjen]
> [updated] Layer novi_novi_r6_Pavino_Polje_10kV_izmijenjen (2/6)
> ... Creating Thumbnail for Layer [geonode:novi_r6_Ambarine_Przista_10kV]
> [created] Layer novi_r6_Ambarine_Przista_10kV (3/6)
> ... Creating Thumbnail for Layer [geonode:novi_r6_Gimnazija_10_kV]
> [updated] Layer novi_r6_Gimnazija_10_kV (4/6)
> ... Creating Thumbnail for Layer [geonode:novi_r6_Planinica_10_kV]
> [updated] Layer novi_r6_Planinica_10_kV (5/6)
> ... Creating Thumbnail for Layer [geonode:novi_r6_Rasovo_10kV]
> [updated] Layer novi_r6_Rasovo_10kV (6/6)
> Finished processing 6 layers in 53.0 seconds.
> 1 Created layers
> 5 Updated layers
> 0 Failed layers
> 8.830000 seconds per layer
> *Is such behavior normal ?*
> Thanks in advance.
> Kind regards,
> *Ana Boljević*
> Sektor za ICT
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *Con riferimento alla normativa sul trattamento dei dati personali (Reg.
> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.*
> * This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.*
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181030/eec115d0/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181030/eec115d0/attachment-0003.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181030/eec115d0/attachment-0004.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20181030/eec115d0/attachment-0005.jpg>
More information about the geonode-users mailing list
