[GeoNode-users] WMS name clashes / contributors agreement problem
francesco bartoli
xbartolone at gmail.com
Fri Sep 7 08:00:48 PDT 2018
Hi Stefan,
can you give another try?
Thanks,
Francesco
Il giorno ven 7 set 2018 alle ore 15:02 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> Can you give it a try?
> Il giorno ven 7 set 2018 alle ore 14:45 Fina, Stefan <
> Stefan.Fina at ils-forschung.de> ha scritto:
>> Many thanks for your response, Alessio, here is what happens in detail:
>> filling in the form at https://www.clahub.com/agreements/GeoNode/geonode
>> with correct email address, name and affiliation information results in the
>> error shown in the screenshot.
>> Stefan
>> *Von:* Alessio Fabiani [mailto:alessio.fabiani at geo-solutions.it]
>> *Gesendet:* Freitag, 7. September 2018 10:03
>> *An:* Fina, Stefan
>> *Cc:* geonode-users
>> *Betreff:* Re: [GeoNode-users] WMS name clashes / contributors agreement
>> problem
>> Dear Fina,
>> I will try to investigate on that. Can you please explain exactly the
>> issue you are having with the contribution agreement and the steps you did?
>> That said, if you want to send PRs it is still ok, we can review them,
>> but accordingly to the new rules, they must be sent first to the master
>> branch and related to a specific issue describing the technical problem
>> and, if applicable/possible, the proposed solution.
>> Il giorno gio 6 set 2018 alle ore 19:40 Fina, Stefan <
>> We are a team of GeoNode users with some development capacities that we
>> would like to bring in to the GeoNode community. We currently have a
>> problem with WMS name clashes that we actually know how to fix with some
>> code changes, see https://github.com/GeoNode/geonode/pull/3875. We also
>> provided a fix for another problem recently that was accepted (
>> https://github.com/GeoNode/ansible-geonode/pull/45).
>> Due to problems with the contributors agreement our fix for the WMS name
>> clashes has now been declined. Could you pls reconsider this and check
>> what’s wrong with the contributors agreement?
>> Stefan
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>> phone: +39 0584 962313
>> fax: +39 0584 1660272
>> mob: +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> *Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.*
>> * This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.*
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180907/2e383f74/attachment.html>
More information about the geonode-users
