[GeoNode-users] Encoding problem in Metadata
Daniel Victoria daniel.victoria at gmail.com
Wed Sep 12 05:20:22 PDT 2018
Hi list,
I have GeoNode 2.8 installed from package in Ubuntu.
I uploaded several shapefiles along with their metadata in a xml file using
`geonode importlayers` command. Everything worked fine and I can see the
metadata using the `Metadata detail` button, including the accented
characters in the title and keywords field. But when I try to edit the
metadata (Edit layers \ metadata wizard) I get an error. Looking at the
apache error log, is mentions a problem with encoding.
Any idea how to fix this? Bellow is the apache error log
Cheers
Daniel
--- Apache error log ---
[Wed Sep 12 06:55:17.755914 2018] [wsgi:error] [pid 30108:tid
139760428979968] Internal Server Error:
/layers/geonode:go1_a01_2014_lasboundary/metadata
[Wed Sep 12 06:55:17.755940 2018] [wsgi:error] [pid 30108:tid
139760428979968] Traceback (most recent call last):
[Wed Sep 12 06:55:17.755945 2018] [wsgi:error] [pid 30108:tid
139760428979968]   File
"/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 132,
in get_response
[Wed Sep 12 06:55:17.755955 2018] [wsgi:error] [pid 30108:tid
139760428979968]     response = wrapped_callback(request, *callback_args,
**callback_kwargs)
[Wed Sep 12 06:55:17.755959 2018] [wsgi:error] [pid 30108:tid
"/usr/lib/python2.7/dist-packages/django/contrib/auth/decorators.py", line
22, in _wrapped_view
[Wed Sep 12 06:55:17.755962 2018] [wsgi:error] [pid 30108:tid
139760428979968]     return view_func(request, *args, **kwargs)
[Wed Sep 12 06:55:17.755965 2018] [wsgi:error] [pid 30108:tid
"/usr/local/lib/python2.7/dist-packages/geonode/layers/views.py", line
1093, in layer_metadata
[Wed Sep 12 06:55:17.755969 2018] [wsgi:error] [pid 30108:tid
139760428979968]     getattr(settings, 'GROUP_MANDATORY_RESOURCES', False),
[Wed Sep 12 06:55:17.755972 2018] [wsgi:error] [pid 30108:tid
"/usr/lib/python2.7/dist-packages/django/shortcuts.py", line 67, in render
[Wed Sep 12 06:55:17.755975 2018] [wsgi:error] [pid 30108:tid
139760428979968]     template_name, context, request=request, using=using)
[Wed Sep 12 06:55:17.755978 2018] [wsgi:error] [pid 30108:tid
"/usr/lib/python2.7/dist-packages/django/template/loader.py", line 99, in
render_to_string
[Wed Sep 12 06:55:17.755981 2018] [wsgi:error] [pid 30108:tid
139760428979968]     return template.render(context, request)
[Wed Sep 12 06:55:17.755984 2018] [wsgi:error] [pid 30108:tid
"/usr/lib/python2.7/dist-packages/django/template/backends/django.py", line
74, in render
[Wed Sep 12 06:55:17.755988 2018] [wsgi:error] [pid 30108:tid
139760428979968]     return self.template.render(context)
[Wed Sep 12 06:55:17.755991 2018] [wsgi:error] [pid 30108:tid
"/usr/lib/python2.7/dist-packages/django/template/base.py", line 210, in
render
[Wed Sep 12 06:55:17.755994 2018] [wsgi:error] [pid 30108:tid
139760428979968]     return self._render(context)
[Wed Sep 12 06:55:17.755997 2018] [wsgi:error] [pid 30108:tid
"/usr/lib/python2.7/dist-packages/django/template/base.py", line 202, in
_render
[Wed Sep 12 06:55:17.756000 2018] [wsgi:error] [pid 30108:tid
139760428979968]     return self.nodelist.render(context)
[Wed Sep 12 06:55:17.756003 2018] [wsgi:error] [pid 30108:tid
"/usr/lib/python2.7/dist-packages/django/template/base.py", line 905, in
render
[Wed Sep 12 06:55:17.756006 2018] [wsgi:error] [pid 30108:tid
139760428979968]     bit = self.render_node(node, context)
[Wed Sep 12 06:55:17.756009 2018] [wsgi:error] [pid 30108:tid
"/usr/lib/python2.7/dist-packages/django/template/debug.py", line 79, in
render_node
[Wed Sep 12 06:55:17.756012 2018] [wsgi:error] [pid 30108:tid
139760428979968]     return node.render(context)
[Wed Sep 12 06:55:17.756015 2018] [wsgi:error] [pid 30108:tid
"/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line
135, in render
[Wed Sep 12 06:55:17.756019 2018] [wsgi:error] [pid 30108:tid
139760428979968]     return compiled_parent._render(context)
[Wed Sep 12 06:55:17.756022 2018] [wsgi:error] [pid 30108:tid
_render
[Wed Sep 12 06:55:17.756025 2018] [wsgi:error] [pid 30108:tid
[Wed Sep 12 06:55:17.756028 2018] [wsgi:error] [pid 30108:tid
render
[Wed Sep 12 06:55:17.756031 2018] [wsgi:error] [pid 30108:tid
[Wed Sep 12 06:55:17.756034 2018] [wsgi:error] [pid 30108:tid
render_node
[Wed Sep 12 06:55:17.756037 2018] [wsgi:error] [pid 30108:tid
[Wed Sep 12 06:55:17.756040 2018] [wsgi:error] [pid 30108:tid
135, in render
[Wed Sep 12 06:55:17.756046 2018] [wsgi:error] [pid 30108:tid
[Wed Sep 12 06:55:17.756050 2018] [wsgi:error] [pid 30108:tid
_render
[Wed Sep 12 06:55:17.756053 2018] [wsgi:error] [pid 30108:tid
[Wed Sep 12 06:55:17.756056 2018] [wsgi:error] [pid 30108:tid
render
[Wed Sep 12 06:55:17.756059 2018] [wsgi:error] [pid 30108:tid
[Wed Sep 12 06:55:17.756062 2018] [wsgi:error] [pid 30108:tid
render_node
[Wed Sep 12 06:55:17.756065 2018] [wsgi:error] [pid 30108:tid
[Wed Sep 12 06:55:17.756068 2018] [wsgi:error] [pid 30108:tid
135, in render
[Wed Sep 12 06:55:17.756071 2018] [wsgi:error] [pid 30108:tid
[Wed Sep 12 06:55:17.756075 2018] [wsgi:error] [pid 30108:tid
_render
[Wed Sep 12 06:55:17.756078 2018] [wsgi:error] [pid 30108:tid
[Wed Sep 12 06:55:17.756081 2018] [wsgi:error] [pid 30108:tid
render
[Wed Sep 12 06:55:17.756084 2018] [wsgi:error] [pid 30108:tid
[Wed Sep 12 06:55:17.756087 2018] [wsgi:error] [pid 30108:tid
render_node
[Wed Sep 12 06:55:17.756090 2018] [wsgi:error] [pid 30108:tid
[Wed Sep 12 06:55:17.756093 2018] [wsgi:error] [pid 30108:tid
"/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line 65,
in render
[Wed Sep 12 06:55:17.756096 2018] [wsgi:error] [pid 30108:tid
139760428979968]     result = block.nodelist.render(context)
[Wed Sep 12 06:55:17.756099 2018] [wsgi:error] [pid 30108:tid
render
[Wed Sep 12 06:55:17.756102 2018] [wsgi:error] [pid 30108:tid
[Wed Sep 12 06:55:17.756105 2018] [wsgi:error] [pid 30108:tid
render_node
[Wed Sep 12 06:55:17.756109 2018] [wsgi:error] [pid 30108:tid
[Wed Sep 12 06:55:17.756112 2018] [wsgi:error] [pid 30108:tid
in render
[Wed Sep 12 06:55:17.756115 2018] [wsgi:error] [pid 30108:tid
[Wed Sep 12 06:55:17.756118 2018] [wsgi:error] [pid 30108:tid
render
[Wed Sep 12 06:55:17.756121 2018] [wsgi:error] [pid 30108:tid
[Wed Sep 12 06:55:17.756124 2018] [wsgi:error] [pid 30108:tid
render_node
[Wed Sep 12 06:55:17.756127 2018] [wsgi:error] [pid 30108:tid
[Wed Sep 12 06:55:17.756130 2018] [wsgi:error] [pid 30108:tid
"/usr/lib/python2.7/dist-packages/floppyforms/templatetags/floppyforms.py",
line 500, in render
[Wed Sep 12 06:55:17.756136 2018] [wsgi:error] [pid 30108:tid
139760428979968]     output = nodelist.render(context)
[Wed Sep 12 06:55:17.756139 2018] [wsgi:error] [pid 30108:tid
"/usr/lib/python2.7/dist-packages/django/template/base.py", line 212, in
render
[Wed Sep 12 06:55:17.756142 2018] [wsgi:error] [pid 30108:tid
[Wed Sep 12 06:55:17.756145 2018] [wsgi:error] [pid 30108:tid
_render
[Wed Sep 12 06:55:17.756148 2018] [wsgi:error] [pid 30108:tid
[Wed Sep 12 06:55:17.756151 2018] [wsgi:error] [pid 30108:tid
render
[Wed Sep 12 06:55:17.756154 2018] [wsgi:error] [pid 30108:tid
[Wed Sep 12 06:55:17.756158 2018] [wsgi:error] [pid 30108:tid
render_node
[Wed Sep 12 06:55:17.756161 2018] [wsgi:error] [pid 30108:tid
[Wed Sep 12 06:55:17.756164 2018] [wsgi:error] [pid 30108:tid
"/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line 56,
in render
[Wed Sep 12 06:55:17.756167 2018] [wsgi:error] [pid 30108:tid
139760428979968]     result = self.nodelist.render(context)
[Wed Sep 12 06:55:17.756170 2018] [wsgi:error] [pid 30108:tid
render
[Wed Sep 12 06:55:17.756173 2018] [wsgi:error] [pid 30108:tid
[Wed Sep 12 06:55:17.756176 2018] [wsgi:error] [pid 30108:tid
render_node
[Wed Sep 12 06:55:17.756179 2018] [wsgi:error] [pid 30108:tid
[Wed Sep 12 06:55:17.756182 2018] [wsgi:error] [pid 30108:tid
"/usr/lib/python2.7/dist-packages/django/template/debug.py", line 92, in
render
[Wed Sep 12 06:55:17.756186 2018] [wsgi:error] [pid 30108:tid
139760428979968]     output = force_text(output)
[Wed Sep 12 06:55:17.756189 2018] [wsgi:error] [pid 30108:tid
"/usr/lib/python2.7/dist-packages/django/utils/encoding.py", line 92, in
force_text
[Wed Sep 12 06:55:17.756192 2018] [wsgi:error] [pid 30108:tid
139760428979968]     s = six.text_type(s)
[Wed Sep 12 06:55:17.756195 2018] [wsgi:error] [pid 30108:tid
"/usr/lib/python2.7/dist-packages/django/utils/html.py", line 404, in
<lambda>
[Wed Sep 12 06:55:17.756198 2018] [wsgi:error] [pid 30108:tid
139760428979968]     klass.__unicode__ = lambda self:
mark_safe(klass_unicode(self))
[Wed Sep 12 06:55:17.756201 2018] [wsgi:error] [pid 30108:tid
"/usr/lib/python2.7/dist-packages/django/forms/forms.py", line 537, in
__str__
[Wed Sep 12 06:55:17.756204 2018] [wsgi:error] [pid 30108:tid
139760428979968]     return self.as_widget()
[Wed Sep 12 06:55:17.756207 2018] [wsgi:error] [pid 30108:tid
"/usr/lib/python2.7/dist-packages/django/forms/forms.py", line 593, in
as_widget
[Wed Sep 12 06:55:17.756211 2018] [wsgi:error] [pid 30108:tid
139760428979968]     return force_text(widget.render(name, self.value(),
attrs=attrs))
[Wed Sep 12 06:55:17.756214 2018] [wsgi:error] [pid 30108:tid
"/usr/local/lib/python2.7/dist-packages/geonode/base/forms.py", line 115,
in render
[Wed Sep 12 06:55:17.756217 2018] [wsgi:error] [pid 30108:tid
139760428979968]     vals = ','.join([str(i.tag.name) for i in values])
[Wed Sep 12 06:55:17.756220 2018] [wsgi:error] [pid 30108:tid
139760428979968] UnicodeEncodeError: 'ascii' codec can't encode character
u'\\xe1' in position 3: ordinal not in range(128)
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180912/677adadc/attachment-0001.html>
More information about the geonode-users mailing list
