[GeoNode-users] Encoding problem in Metadata
Daniel Victoria
daniel.victoria at gmail.com
Wed Sep 12 18:47:32 PDT 2018
Hi Alessio,
By 'compare with the code base' you mean checkout the 2.7.x branch and see
what changed from my current install? And how will I know which changes
will fix this problem?
Regarding the Issue, I'll try to open one up tomorrow
Cheers
Daniel
On Wed, Sep 12, 2018 at 11:42 AM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Hello Daniel,
> I guess this issue has been fixed on 2.7.x branch already. Any chance to
> compare with the code base?
> If not let me know, I'll try to extract the fix.
> Also, could be useful if we track this discussion on an issue on GitHub.
> Il giorno mer 12 set 2018 alle ore 14:20 Daniel Victoria <
> daniel.victoria at gmail.com> ha scritto:
>> Hi list,
>> I have GeoNode 2.8 installed from package in Ubuntu.
>> I uploaded several shapefiles along with their metadata in a xml file
>> using `geonode importlayers` command. Everything worked fine and I can see
>> the metadata using the `Metadata detail` button, including the accented
>> characters in the title and keywords field. But when I try to edit the
>> metadata (Edit layers \ metadata wizard) I get an error. Looking at the
>> apache error log, is mentions a problem with encoding.
>> Any idea how to fix this? Bellow is the apache error log
>> Cheers
>> Daniel
>> --- Apache error log ---
>> [Wed Sep 12 06:55:17.755914 2018] [wsgi:error] [pid 30108:tid
>> 139760428979968] Internal Server Error:
>> /layers/geonode:go1_a01_2014_lasboundary/metadata
>> [Wed Sep 12 06:55:17.755940 2018] [wsgi:error] [pid 30108:tid
>> 139760428979968] Traceback (most recent call last):
>> [Wed Sep 12 06:55:17.755945 2018] [wsgi:error] [pid 30108:tid
>> 139760428979968] File
>> "/usr/lib/python2.7/dist-packages/django/core/handlers/base.py", line 132,
>> in get_response
>> [Wed Sep 12 06:55:17.755955 2018] [wsgi:error] [pid 30108:tid
>> 139760428979968] response = wrapped_callback(request, *callback_args,
>> **callback_kwargs)
>> [Wed Sep 12 06:55:17.755959 2018] [wsgi:error] [pid 30108:tid
>> "/usr/lib/python2.7/dist-packages/django/contrib/auth/decorators.py", line
>> 22, in _wrapped_view
>> [Wed Sep 12 06:55:17.755962 2018] [wsgi:error] [pid 30108:tid
>> 139760428979968] return view_func(request, *args, **kwargs)
>> [Wed Sep 12 06:55:17.755965 2018] [wsgi:error] [pid 30108:tid
>> "/usr/local/lib/python2.7/dist-packages/geonode/layers/views.py", line
>> 1093, in layer_metadata
>> [Wed Sep 12 06:55:17.755969 2018] [wsgi:error] [pid 30108:tid
>> 139760428979968] getattr(settings, 'GROUP_MANDATORY_RESOURCES', False),
>> [Wed Sep 12 06:55:17.755972 2018] [wsgi:error] [pid 30108:tid
>> "/usr/lib/python2.7/dist-packages/django/shortcuts.py", line 67, in render
>> [Wed Sep 12 06:55:17.755975 2018] [wsgi:error] [pid 30108:tid
>> 139760428979968] template_name, context, request=request, using=using)
>> [Wed Sep 12 06:55:17.755978 2018] [wsgi:error] [pid 30108:tid
>> "/usr/lib/python2.7/dist-packages/django/template/loader.py", line 99, in
>> render_to_string
>> [Wed Sep 12 06:55:17.755981 2018] [wsgi:error] [pid 30108:tid
>> 139760428979968] return template.render(context, request)
>> [Wed Sep 12 06:55:17.755984 2018] [wsgi:error] [pid 30108:tid
>> "/usr/lib/python2.7/dist-packages/django/template/backends/django.py", line
>> 74, in render
>> [Wed Sep 12 06:55:17.755988 2018] [wsgi:error] [pid 30108:tid
>> 139760428979968] return self.template.render(context)
>> [Wed Sep 12 06:55:17.755991 2018] [wsgi:error] [pid 30108:tid
>> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 210, in
>> render
>> [Wed Sep 12 06:55:17.755994 2018] [wsgi:error] [pid 30108:tid
>> 139760428979968] return self._render(context)
>> [Wed Sep 12 06:55:17.755997 2018] [wsgi:error] [pid 30108:tid
>> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 202, in
>> _render
>> [Wed Sep 12 06:55:17.756000 2018] [wsgi:error] [pid 30108:tid
>> 139760428979968] return self.nodelist.render(context)
>> [Wed Sep 12 06:55:17.756003 2018] [wsgi:error] [pid 30108:tid
>> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 905, in
>> render
>> [Wed Sep 12 06:55:17.756006 2018] [wsgi:error] [pid 30108:tid
>> 139760428979968] bit = self.render_node(node, context)
>> [Wed Sep 12 06:55:17.756009 2018] [wsgi:error] [pid 30108:tid
>> "/usr/lib/python2.7/dist-packages/django/template/debug.py", line 79, in
>> render_node
>> [Wed Sep 12 06:55:17.756012 2018] [wsgi:error] [pid 30108:tid
>> 139760428979968] return node.render(context)
>> [Wed Sep 12 06:55:17.756015 2018] [wsgi:error] [pid 30108:tid
>> "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line
>> 135, in render
>> [Wed Sep 12 06:55:17.756019 2018] [wsgi:error] [pid 30108:tid
>> 139760428979968] return compiled_parent._render(context)
>> [Wed Sep 12 06:55:17.756022 2018] [wsgi:error] [pid 30108:tid
>> _render
>> [Wed Sep 12 06:55:17.756025 2018] [wsgi:error] [pid 30108:tid
>> [Wed Sep 12 06:55:17.756028 2018] [wsgi:error] [pid 30108:tid
>> render
>> [Wed Sep 12 06:55:17.756031 2018] [wsgi:error] [pid 30108:tid
>> [Wed Sep 12 06:55:17.756034 2018] [wsgi:error] [pid 30108:tid
>> render_node
>> [Wed Sep 12 06:55:17.756037 2018] [wsgi:error] [pid 30108:tid
>> [Wed Sep 12 06:55:17.756040 2018] [wsgi:error] [pid 30108:tid
>> 135, in render
>> [Wed Sep 12 06:55:17.756046 2018] [wsgi:error] [pid 30108:tid
>> [Wed Sep 12 06:55:17.756050 2018] [wsgi:error] [pid 30108:tid
>> _render
>> [Wed Sep 12 06:55:17.756053 2018] [wsgi:error] [pid 30108:tid
>> [Wed Sep 12 06:55:17.756056 2018] [wsgi:error] [pid 30108:tid
>> render
>> [Wed Sep 12 06:55:17.756059 2018] [wsgi:error] [pid 30108:tid
>> [Wed Sep 12 06:55:17.756062 2018] [wsgi:error] [pid 30108:tid
>> render_node
>> [Wed Sep 12 06:55:17.756065 2018] [wsgi:error] [pid 30108:tid
>> [Wed Sep 12 06:55:17.756068 2018] [wsgi:error] [pid 30108:tid
>> 135, in render
>> [Wed Sep 12 06:55:17.756071 2018] [wsgi:error] [pid 30108:tid
>> [Wed Sep 12 06:55:17.756075 2018] [wsgi:error] [pid 30108:tid
>> _render
>> [Wed Sep 12 06:55:17.756078 2018] [wsgi:error] [pid 30108:tid
>> [Wed Sep 12 06:55:17.756081 2018] [wsgi:error] [pid 30108:tid
>> render
>> [Wed Sep 12 06:55:17.756084 2018] [wsgi:error] [pid 30108:tid
>> [Wed Sep 12 06:55:17.756087 2018] [wsgi:error] [pid 30108:tid
>> render_node
>> [Wed Sep 12 06:55:17.756090 2018] [wsgi:error] [pid 30108:tid
>> [Wed Sep 12 06:55:17.756093 2018] [wsgi:error] [pid 30108:tid
>> "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line 65,
>> in render
>> [Wed Sep 12 06:55:17.756096 2018] [wsgi:error] [pid 30108:tid
>> 139760428979968] result = block.nodelist.render(context)
>> [Wed Sep 12 06:55:17.756099 2018] [wsgi:error] [pid 30108:tid
>> render
>> [Wed Sep 12 06:55:17.756102 2018] [wsgi:error] [pid 30108:tid
>> [Wed Sep 12 06:55:17.756105 2018] [wsgi:error] [pid 30108:tid
>> render_node
>> [Wed Sep 12 06:55:17.756109 2018] [wsgi:error] [pid 30108:tid
>> [Wed Sep 12 06:55:17.756112 2018] [wsgi:error] [pid 30108:tid
>> in render
>> [Wed Sep 12 06:55:17.756115 2018] [wsgi:error] [pid 30108:tid
>> [Wed Sep 12 06:55:17.756118 2018] [wsgi:error] [pid 30108:tid
>> render
>> [Wed Sep 12 06:55:17.756121 2018] [wsgi:error] [pid 30108:tid
>> [Wed Sep 12 06:55:17.756124 2018] [wsgi:error] [pid 30108:tid
>> render_node
>> [Wed Sep 12 06:55:17.756127 2018] [wsgi:error] [pid 30108:tid
>> [Wed Sep 12 06:55:17.756130 2018] [wsgi:error] [pid 30108:tid
>> "/usr/lib/python2.7/dist-packages/floppyforms/templatetags/floppyforms.py",
>> line 500, in render
>> [Wed Sep 12 06:55:17.756136 2018] [wsgi:error] [pid 30108:tid
>> 139760428979968] output = nodelist.render(context)
>> [Wed Sep 12 06:55:17.756139 2018] [wsgi:error] [pid 30108:tid
>> "/usr/lib/python2.7/dist-packages/django/template/base.py", line 212, in
>> render
>> [Wed Sep 12 06:55:17.756142 2018] [wsgi:error] [pid 30108:tid
>> [Wed Sep 12 06:55:17.756145 2018] [wsgi:error] [pid 30108:tid
>> _render
>> [Wed Sep 12 06:55:17.756148 2018] [wsgi:error] [pid 30108:tid
>> [Wed Sep 12 06:55:17.756151 2018] [wsgi:error] [pid 30108:tid
>> render
>> [Wed Sep 12 06:55:17.756154 2018] [wsgi:error] [pid 30108:tid
>> [Wed Sep 12 06:55:17.756158 2018] [wsgi:error] [pid 30108:tid
>> render_node
>> [Wed Sep 12 06:55:17.756161 2018] [wsgi:error] [pid 30108:tid
>> [Wed Sep 12 06:55:17.756164 2018] [wsgi:error] [pid 30108:tid
>> "/usr/lib/python2.7/dist-packages/django/template/loader_tags.py", line 56,
>> in render
>> [Wed Sep 12 06:55:17.756167 2018] [wsgi:error] [pid 30108:tid
>> 139760428979968] result = self.nodelist.render(context)
>> [Wed Sep 12 06:55:17.756170 2018] [wsgi:error] [pid 30108:tid
>> render
>> [Wed Sep 12 06:55:17.756173 2018] [wsgi:error] [pid 30108:tid
>> [Wed Sep 12 06:55:17.756176 2018] [wsgi:error] [pid 30108:tid
>> render_node
>> [Wed Sep 12 06:55:17.756179 2018] [wsgi:error] [pid 30108:tid
>> [Wed Sep 12 06:55:17.756182 2018] [wsgi:error] [pid 30108:tid
>> "/usr/lib/python2.7/dist-packages/django/template/debug.py", line 92, in
>> render
>> [Wed Sep 12 06:55:17.756186 2018] [wsgi:error] [pid 30108:tid
>> 139760428979968] output = force_text(output)
>> [Wed Sep 12 06:55:17.756189 2018] [wsgi:error] [pid 30108:tid
>> "/usr/lib/python2.7/dist-packages/django/utils/encoding.py", line 92, in
>> force_text
>> [Wed Sep 12 06:55:17.756192 2018] [wsgi:error] [pid 30108:tid
>> 139760428979968] s = six.text_type(s)
>> [Wed Sep 12 06:55:17.756195 2018] [wsgi:error] [pid 30108:tid
>> "/usr/lib/python2.7/dist-packages/django/utils/html.py", line 404, in
>> <lambda>
>> [Wed Sep 12 06:55:17.756198 2018] [wsgi:error] [pid 30108:tid
>> 139760428979968] klass.__unicode__ = lambda self:
>> mark_safe(klass_unicode(self))
>> [Wed Sep 12 06:55:17.756201 2018] [wsgi:error] [pid 30108:tid
>> "/usr/lib/python2.7/dist-packages/django/forms/forms.py", line 537, in
>> __str__
>> [Wed Sep 12 06:55:17.756204 2018] [wsgi:error] [pid 30108:tid
>> 139760428979968] return self.as_widget()
>> [Wed Sep 12 06:55:17.756207 2018] [wsgi:error] [pid 30108:tid
>> "/usr/lib/python2.7/dist-packages/django/forms/forms.py", line 593, in
>> as_widget
>> [Wed Sep 12 06:55:17.756211 2018] [wsgi:error] [pid 30108:tid
>> 139760428979968] return force_text(widget.render(name, self.value(),
>> attrs=attrs))
>> [Wed Sep 12 06:55:17.756214 2018] [wsgi:error] [pid 30108:tid
>> "/usr/local/lib/python2.7/dist-packages/geonode/base/forms.py", line 115,
>> in render
>> [Wed Sep 12 06:55:17.756217 2018] [wsgi:error] [pid 30108:tid
>> 139760428979968] vals = ','.join([str(i.tag.name) for i in values])
>> [Wed Sep 12 06:55:17.756220 2018] [wsgi:error] [pid 30108:tid
>> 139760428979968] UnicodeEncodeError: 'ascii' codec can't encode character
>> u'\\xe1' in position 3: ordinal not in range(128)
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A -
> <https://maps.google.com/?q=Via+di+Montramito+3/A+-++55054+%C2%A0Massarosa&entry=gmail&source=g>55054
> Massarosa
> (LU) - Italy
> phone: +39 0584 962313 <+39%200584%20962313>
> fax: +39 0584 1660272 <+39%200584%20166%200272>
> mob: +39 331 6233686 <+39%20331%20623%203686>
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180912/3c214c4a/attachment-0001.html>
More information about the geonode-users
