[GeoNode-users] WMS name clashes / contributors agreement problem
Fina, Stefan
Stefan.Fina at ils-forschung.de
Thu Sep 13 03:00:42 PDT 2018
Hi Alessio,
the PR is/was posted here: https://github.com/GeoNode/geonode/pull/3875. It would be great if you could take care of this.
However, since we are planning to contribute long-term we think it would help the whole community if the problem with the contributors agreement could be fixed. I’m not the only one who experienced it, other team members had the same issue.
Stefan
Von: Alessio Fabiani [mailto:alessio.fabiani at geo-solutions.it]
Gesendet: Mittwoch, 12. September 2018 16:32
An: Fina, Stefan
Cc: Francesco Bartoli; Alessio Fabiani; geonode-users
Betreff: Re: [GeoNode-users] WMS name clashes / contributors agreement problem
Hi Stefan,
currently I really can't figure out what the problem could be. However, if you need this thing done on GeoNode, send me pointers to your repo/branch and I will take care of doing the PR.
I will try to ask around if any other user is experiencing such issue.
Il giorno mer 12 set 2018 alle ore 14:20 Fina, Stefan <Stefan.Fina at ils-forschung.de<mailto:Stefan.Fina at ils-forschung.de>> ha scritto:
Hi Francesco,
I just tried one more time, same result with the message: “We're sorry, but something went wrong.” Can you check?
Stefan
Von: francesco bartoli [mailto:xbartolone at gmail.com<mailto:xbartolone at gmail.com>]
Gesendet: Freitag, 7. September 2018 17:01
An: Alessio Fabiani
Cc: Fina, Stefan; geonode-users
Hi Stefan,
can you give another try?
Thanks,
Francesco
Il giorno ven 7 set 2018 alle ore 15:02 Alessio Fabiani <alessio.fabiani at geo-solutions.it<mailto:alessio.fabiani at geo-solutions.it>> ha scritto:
Can you give it a try?
Il giorno ven 7 set 2018 alle ore 14:45 Fina, Stefan <Stefan.Fina at ils-forschung.de<mailto:Stefan.Fina at ils-forschung.de>> ha scritto:
Many thanks for your response, Alessio, here is what happens in detail: filling in the form at https://www.clahub.com/agreements/GeoNode/geonode with correct email address, name and affiliation information results in the error shown in the screenshot.
Stefan
Fehler! Es wurde kein Dateiname angegeben.
Von: Alessio Fabiani [mailto:alessio.fabiani at geo-solutions.it<mailto:alessio.fabiani at geo-solutions.it>]
Gesendet: Freitag, 7. September 2018 10:03
An: Fina, Stefan
Cc: geonode-users
Dear Fina,
I will try to investigate on that. Can you please explain exactly the issue you are having with the contribution agreement and the steps you did?
That said, if you want to send PRs it is still ok, we can review them, but accordingly to the new rules, they must be sent first to the master branch and related to a specific issue describing the technical problem and, if applicable/possible, the proposed solution.
Il giorno gio 6 set 2018 alle ore 19:40 Fina, Stefan <Stefan.Fina at ils-forschung.de<mailto:Stefan.Fina at ils-forschung.de>> ha scritto:
We are a team of GeoNode users with some development capacities that we would like to bring in to the GeoNode community. We currently have a problem with WMS name clashes that we actually know how to fix with some code changes, see https://github.com/GeoNode/geonode/pull/3875. We also provided a fix for another problem recently that was accepted (https://github.com/GeoNode/ansible-geonode/pull/45).
Due to problems with the contributors agreement our fix for the WMS name clashes has now been declined. Could you pls reconsider this and check what’s wrong with the contributors agreement?
Stefan
geonode-users mailing list
geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
@alfa7691
GeoSolutions S.A.S.
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180913/da46144e/attachment-0001.html>
More information about the geonode-users
