[GeoNode-users] WMS name clashes / contributors agreement problem
francesco bartoli xbartolone at gmail.com
Thu Sep 13 06:03:08 PDT 2018
Hi Stefan,
sorry for the problem but I cannot figure out what the problem is. Did the
error change from your previous message? Could you give me more information
on which page is failing and which redirections are you facing with? I
configured a new hook into github which I thought it was working(green
light)
Thanks,
Francesco
Il giorno gio 13 set 2018 alle ore 12:15 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> I see,
> I guess the only way would be to change the way we configured it on
> github, i.e. via the clahub.
> I have to figure out other ways to provide Osgeo CLA for GeoNode. Most
> probably we will need to provide a file containing the list of the
> contributors.
> Il giorno gio 13 set 2018 alle ore 12:02 Fina, Stefan <
> Stefan.Fina at ils-forschung.de> ha scritto:
>> Hi Alessio,
>> the PR is/was posted here: https://github.com/GeoNode/geonode/pull/3875.
>> It would be great if you could take care of this.
>> However, since we are planning to contribute long-term we think it would
>> help the whole community if the problem with the contributors agreement
>> could be fixed. I’m not the only one who experienced it, other team members
>> had the same issue.
>> Stefan
>> *Von:* Alessio Fabiani [mailto:alessio.fabiani at geo-solutions.it]
>> *Gesendet:* Mittwoch, 12. September 2018 16:32
>> *An:* Fina, Stefan
>> *Cc:* Francesco Bartoli; Alessio Fabiani; geonode-users
>> *Betreff:* Re: [GeoNode-users] WMS name clashes / contributors agreement
>> problem
>> Hi Stefan,
>> currently I really can't figure out what the problem could be. However,
>> if you need this thing done on GeoNode, send me pointers to your
>> repo/branch and I will take care of doing the PR.
>> I will try to ask around if any other user is experiencing such issue.
>> Il giorno mer 12 set 2018 alle ore 14:20 Fina, Stefan <
>> Hi Francesco,
>> I just tried one more time, same result with the message: “We're sorry,
>> but something went wrong.” Can you check?
>> Stefan
>> *Von:* francesco bartoli [mailto:xbartolone at gmail.com]
>> *Gesendet:* Freitag, 7. September 2018 17:01
>> *An:* Alessio Fabiani
>> *Cc:* Fina, Stefan; geonode-users
>> problem
>> Hi Stefan,
>> can you give another try?
>> Thanks,
>> Francesco
>> Il giorno ven 7 set 2018 alle ore 15:02 Alessio Fabiani <
>> Can you give it a try?
>> Il giorno ven 7 set 2018 alle ore 14:45 Fina, Stefan <
>> Many thanks for your response, Alessio, here is what happens in detail:
>> filling in the form at https://www.clahub.com/agreements/GeoNode/geonode
>> with correct email address, name and affiliation information results in the
>> error shown in the screenshot.
>> Stefan
>> *Fehler! Es wurde kein Dateiname angegeben.*
>> *Gesendet:* Freitag, 7. September 2018 10:03
>> *An:* Fina, Stefan
>> *Cc:* geonode-users
>> problem
>> Dear Fina,
>> I will try to investigate on that. Can you please explain exactly the
>> issue you are having with the contribution agreement and the steps you did?
>> That said, if you want to send PRs it is still ok, we can review them,
>> but accordingly to the new rules, they must be sent first to the master
>> branch and related to a specific issue describing the technical problem
>> and, if applicable/possible, the proposed solution.
>> Il giorno gio 6 set 2018 alle ore 19:40 Fina, Stefan <
>> We are a team of GeoNode users with some development capacities that we
>> would like to bring in to the GeoNode community. We currently have a
>> problem with WMS name clashes that we actually know how to fix with some
>> code changes, see https://github.com/GeoNode/geonode/pull/3875. We also
>> provided a fix for another problem recently that was accepted (
>> https://github.com/GeoNode/ansible-geonode/pull/45).
>> Due to problems with the contributors agreement our fix for the WMS name
>> clashes has now been declined. Could you pls reconsider this and check
>> what’s wrong with the contributors agreement?
>> Stefan
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> *Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.*
>> * This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.*
>> @alfa7691
>> GeoSolutions S.A.S.
>> @alfa7691
>> GeoSolutions S.A.S.
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180913/845200a4/attachment-0001.html>
More information about the geonode-users mailing list
