[GeoNode-users] Some githb issues triage
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu Sep 13 06:47:19 PDT 2018
I'm trying to identify and remove obsolete or not applicable issues from
github. I'm keeping the ones marked as "feature" or "gnip" even if very old.
If you find some important issue has been deleted, please re-open it and/or
better create a new one with the following characteristics:
- Put a label coherent with the issue
- Provide a meaningful description of the issue and possibly instructions
to reproduce (if it is an error).
- In case of a feature request, describe it as much as possible in order to
have more chance it will be taken into account
Regards,
Alessio.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180913/1078e6bf/attachment.html>
More information about the geonode-users
