[GeoNode-users] GeoNode Project master Docker - Upload layers
francesco bartoli xbartolone at gmail.com
Mon Sep 17 10:02:28 PDT 2018
Hi Julierme,
the master branch is not supposed to be always in a safe docker build, at
least until we could have time and maybe sponsors to introduce a reliable
CI/CD procedure.
With regards to the sentence "Django container gets a new one every time
docker-compose up is run.", can you please elaborate more the issue? Is not
clear what you are facing with.
Thanks,
Francesco
Il giorno lun 17 set 2018 alle ore 18:52 Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> ha scritto:
> Hi Simone,
> I have several instances of GeoNode-Project in different VMs.
> GeoNode-Project at 2.7 Docker Centos7 VM
> Issue:
> Django container gets a new one every time docker-compose up is run.
> GeoNode-Project at 2master Docker Centos7 VM
> Issue:
> Related to upload layers
> *Unable to
> usecom.vividsolutions.jts.geom.impl.CoordinateArraySequenceFactory at 32f58c5e
> to produce CoordinateSequence with dimension 2*
> Thank you very much for your reply. I appreciated your time.
> Kind regards
> Julierme
> On Sat, Sep 15, 2018 at 5:18 AM Simone Dalmasso <simone.dalmasso at gmail.com>
> wrote:
>> Hi,
>> which version of GeoNode are you using. Keep in mind that the
>> geonode-project branch you use should follow the geonode's version.
>> Best
>> Il giorno ven 14 set 2018 alle ore 22:37 Julierme Pinheiro <
>>> Dear users,
>>> I had geonode-project at 2.7 running perfectly fine, including uploading
>>> layers. Now, I am running GeoNode-Project at master, but I am unable to
>>> upload data layers. The following message is shown at the end of the
>>> uploading layers process:
>>> *Unable to
>>> This would not happen on version 2.7
>>> Any comment on this issue would be very appreciated.
>>> Kind regards
>>> Julierme
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180917/14f985db/attachment-0001.html>
More information about the geonode-users mailing list
