[GeoNode-users] GeoNode Project master Docker - Upload layers
Julierme Pinheiro
juliermeopensourcedeveloper at gmail.com
Mon Sep 17 10:37:42 PDT 2018
... their default configuration [1] and [2]
Kind regards
Julierme
On Mon, Sep 17, 2018 at 2:36 PM Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> wrote:
> Hi Francesco,
> Thank you very much for your reply. I have GeoNode-Project at 2.7 installed
> via Docker in a Centos7 VM and I had edited the templates html (site_base
> and site_index) and css file (site_base). GeoNode site was working
> smoothly. But lately, after running docker-compose down and right after
> docker-compose up, this last command resets the django container (the
> container gets a new ID), and why I see that, after running docker-compose
> up the templates [1] and static [2] returns to their default configuration.
> [1]
> https://github.com/GeoNode/geonode-project/tree/2.7/project_name/templates
> [2]
> https://github.com/GeoNode/geonode-project/tree/2.7/project_name/static/css
> I appreciated your time
> Kind regards
> Julierme
> On Mon, Sep 17, 2018 at 2:02 PM francesco bartoli <xbartolone at gmail.com>
> wrote:
>> Hi Julierme,
>> the master branch is not supposed to be always in a safe docker build, at
>> least until we could have time and maybe sponsors to introduce a reliable
>> CI/CD procedure.
>> With regards to the sentence "Django container gets a new one every time
>> docker-compose up is run.", can you please elaborate more the issue? Is not
>> clear what you are facing with.
>> Thanks,
>> Francesco
>> Il giorno lun 17 set 2018 alle ore 18:52 Julierme Pinheiro <
>> juliermeopensourcedeveloper at gmail.com> ha scritto:
>>> Hi Simone,
>>> I have several instances of GeoNode-Project in different VMs.
>>> GeoNode-Project at 2.7 Docker Centos7 VM
>>> Issue:
>>> Django container gets a new one every time docker-compose up is run.
>>> GeoNode-Project at 2master Docker Centos7 VM
>>> Issue:
>>> Related to upload layers
>>> *Unable to
>>> usecom.vividsolutions.jts.geom.impl.CoordinateArraySequenceFactory at 32f58c5e
>>> to produce CoordinateSequence with dimension 2*
>>> Thank you very much for your reply. I appreciated your time.
>>> Kind regards
>>> Julierme
>>> On Sat, Sep 15, 2018 at 5:18 AM Simone Dalmasso <
>>> simone.dalmasso at gmail.com> wrote:
>>>> Hi,
>>>> which version of GeoNode are you using. Keep in mind that the
>>>> geonode-project branch you use should follow the geonode's version.
>>>> Best
>>>> Il giorno ven 14 set 2018 alle ore 22:37 Julierme Pinheiro <
>>>>> Dear users,
>>>>> I had geonode-project at 2.7 running perfectly fine, including uploading
>>>>> layers. Now, I am running GeoNode-Project at master, but I am unable to
>>>>> upload data layers. The following message is shown at the end of the
>>>>> uploading layers process:
>>>>> *Unable to
>>>>> This would not happen on version 2.7
>>>>> Any comment on this issue would be very appreciated.
>>>>> Kind regards
>>>>> Julierme
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20180917/a8599a09/attachment.html>
More information about the geonode-users
