[GeoNode-users] MapStore2 Viewer - Custom WMTS background map
Pascal Coulon
Pascal.Coulon at scisys.co.uk
Fri Apr 26 05:23:41 PDT 2019
Alessio.
This is a great reply, thanks for the update. I thought it would be the case. I will create a pull request for this and you may wish to have it. The use of Ordnance Survey API in mapstore may be useful for many in the UK.
Regards,
Pascal
From: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
Sent: 26 April 2019 13:20
To: Pascal Coulon <Pascal.Coulon at scisys.co.uk>
Cc: geonode-users at lists.osgeo.org
Subject: Re: [GeoNode-users] MapStore2 Viewer - Custom WMTS background map
Hello Pascal,
well, unfortunately at this time this is not quite easy to achieve in MapStore2.
There are plans to introduce a generic "TMS" Provider in the next release, but at this time only configured providers are supported. See the list here
https://mapstore.readthedocs.io/en/latest/developer-guide/maps-configuration/#providers-and-variants
In order to add your own provider, you should roughly follow those steps:
1) download the geonode-mapstore-client source code
git clone https://github.com/geosolutions-it/geonode-mapstore-client.git
2) go to folder geonode-mapstore-client/geonode_mapstore_client/client and run
git submodule update --recursive
3) edit the file ConfigProvider.js and add your new provider
vim MapStore2/web/client/utils/ConfigProvider.js
4) rebuild the library; from geonode-mapstore-client/geonode_mapstore_client/client
npm run compile
5) install your local version of the python library; from geonode-mapstore-client
pip install -e .
6) go back to geonode source folder and run
python manage.py collectstatic
7) restart the server after having updated the MS2_DEFAULT_BACKGROUNDs config accordingly
Hope this helps.
By the way, the same procedure applies whenever you would like to update/customize MapStore2 somehow.
Regards,
Alessio.
Il giorno ven 26 apr 2019 alle ore 12:01 Pascal Coulon <Pascal.Coulon at scisys.co.uk<mailto:Pascal.Coulon at scisys.co.uk>> ha scritto:
All,
We have decided to use MapStore2 as the main viewer in Geonode (2.10RC4). We would like to set-up a custom WMTS or XYZ (tile) layer for the background map. We are based in the UK and we would need to use the Ordnance Survey OGC feed for this.
In our settings.py we have set-up the following config.
DEFAULT_MAP_CRS = "EPSG:3857"
if 'geonode_mapstore_client' not in INSTALLED_APPS:
INSTALLED_APPS += (
'mapstore2_adapter',
'geonode_mapstore_client',)
GEONODE_CLIENT_LAYER_PREVIEW_LIBRARY = 'mapstore' # DEPRECATED use HOOKSET instead
GEONODE_CLIENT_HOOKSET = "geonode_mapstore_client.hooksets.MapStoreHookSet"
MAPSTORE_DEBUG = False
### The key to access OS API as obfuscated. #####
DEFAULT_MS2_BACKGROUNDS = [
"type":"wmts",
"title":"Ordnance Survey",
"allowedSRS": {
"EPSG:3857": True
"url": [
"https://api2.ordnancesurvey.co.uk/mapping_api/v1/service/zxy/EPSG:3857/Outdoor 3857/${z}/${x}/${y}.png?key=xxxxx"
"visibility": False,
"group":"background",
"matrixIds": [
"EPSG:3857",
"tileMatrixSet": [
"capabilitiesURL": "https://api2.ordnancesurvey.co.uk/mapping_api/v1/service/wmts?Request=GetCapabilities&key=XXXXXXXXXXXX"
MAPSTORE_BASELAYERS = DEFAULT_MS2_BACKGROUNDS
The background data from OS does not get properly set and we get some JavaScript errors that lead us to believe that we are not setting the background layer the proper way.
Any help or recommendation would be gratefully received.
Regards,
Pascal
SCISYS UK Limited. Registered in England and Wales No. 4373530.
Registered Office: Methuen Park, Chippenham, Wiltshire SN14 0GB, UK.
Before printing, please think about the environment.
geonode-users mailing list
geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190426/e2cc6b0f/attachment-0001.html>
More information about the geonode-users
