[GeoNode-users] Failed to save to Geoserver catalog: 500, Store already exists in workspace 'geonode'.
Israel López asralf at gmail.com
Mon Aug 26 16:39:40 PDT 2019
Hi guys, I'm testing de 2.10.0-release branch on a Ubuntu installation dev
mode (no docker), when the local_settings.py.geoserver.sample is edited and
assign postgres databases, I got
this error when I'm trying to upload a second shape. The first time
everything is ok,
but in the second time I get this error always, I've tried to with clean
databases again
and always is the same.
Does I'm doing something wrong??
The error says:
  File "/home/israel/Proyectos/geonode/geonode/upload/views.py", line 650,
in view
    resp = _steps[step](req, upload_session)
  File "/home/israel/Proyectos/geonode/geonode/upload/views.py", line 425,
in check_step_view
    return next_step_response(request, upload_session)
  File "/home/israel/Proyectos/geonode/geonode/upload/utils.py", line 382,
in next_step_response
    return run_response(req, upload_session)
  File "/home/israel/Proyectos/geonode/geonode/upload/utils.py", line 618,
in run_response
    run_import(upload_session)
  File "/home/israel/Proyectos/geonode/geonode/upload/utils.py", line 584,
in run_import
    store_name=ogc_server_settings.datastore_db['NAME']
  File "/home/israel/Proyectos/geonode/geonode/geoserver/helpers.py", line
1293, in create_geoserver_db_featurestore
    cat.save(ds)
  File
"/home/israel/.virtualenvs/forkGeonode/local/lib/python2.7/site-packages/geoserver/catalog.py",
line 290, in save
    raise FailedRequestError('Failed to save to Geoserver catalog: {},
{}'.format(resp.status_code, resp.text))
FailedRequestError: Failed to save to Geoserver catalog: 500, Store
'base1_data' already exists in workspace 'geonode'
I've found that the next line can't get the datastore and tries to create
it again,
so then raises the error.
helpers.py line 1248
if dsname:
    ds = cat.get_store(dsname)
My local_settings.py
import ast
import os
from urlparse import urlparse, urlunparse
from geonode.settings import *
PROJECT_ROOT = os.path.abspath(os.path.dirname(__file__))
MEDIA_ROOT = os.getenv('MEDIA_ROOT', os.path.join(PROJECT_ROOT, "uploaded"))
STATIC_ROOT = os.getenv('STATIC_ROOT',
                        os.path.join(PROJECT_ROOT, "static_root")
TIME_ZONE = 'UTC'
# Backend
DATABASES = {
    'default': {
        'ENGINE': 'django.db.backends.postgresql_psycopg2',
        'NAME': 'base1',
        'USER': 'idegeo',
        'PASSWORD': 'idegeo',
        'HOST': 'localhost',
        'PORT': '5432',
        'CONN_TOUT': 900,
    # vector datastore for uploads
    'datastore': {
        'ENGINE': 'django.contrib.gis.db.backends.postgis',
        # 'ENGINE': '', # Empty ENGINE name disables
        'NAME': 'base1_data',
        'USER': 'idegeo',
        'PORT': '5432',
        'CONN_TOUT': 900,
GEOSERVER_LOCATION = os.getenv(
    'GEOSERVER_LOCATION', 'http://localhost:8080/geoserver/'
GEOSERVER_PUBLIC_HOST = os.getenv(
    'GEOSERVER_PUBLIC_HOST', SITE_HOST_NAME
GEOSERVER_PUBLIC_PORT = os.getenv(
    'GEOSERVER_PUBLIC_PORT', 8080
_default_public_location =
'http://{}:{}/geoserver/'.format(GEOSERVER_PUBLIC_HOST,
GEOSERVER_PUBLIC_PORT) if GEOSERVER_PUBLIC_PORT else
'http://{}/geoserver/'.format(GEOSERVER_PUBLIC_HOST)
GEOSERVER_WEB_UI_LOCATION = os.getenv(
    'GEOSERVER_WEB_UI_LOCATION', GEOSERVER_LOCATION
GEOSERVER_PUBLIC_LOCATION = os.getenv(
    'GEOSERVER_PUBLIC_LOCATION', _default_public_location
OGC_SERVER_DEFAULT_USER = os.getenv(
    'GEOSERVER_ADMIN_USER', 'admin'
OGC_SERVER_DEFAULT_PASSWORD = os.getenv(
    'GEOSERVER_ADMIN_PASSWORD', 'geoserver'
# OGC (WMS/WFS/WCS) Server Settings
OGC_SERVER = {
    'default': {
        'BACKEND': 'geonode.geoserver',
        'LOCATION': GEOSERVER_LOCATION,
        'WEB_UI_LOCATION': GEOSERVER_WEB_UI_LOCATION,
        'LOGIN_ENDPOINT': 'j_spring_oauth2_geonode_login',
        'LOGOUT_ENDPOINT': 'j_spring_oauth2_geonode_logout',
        # PUBLIC_LOCATION needs to be kept like this because in dev mode
        # the proxy won't work and the integration tests will fail
        # the entire block has to be overridden in the local_settings
        'PUBLIC_LOCATION': GEOSERVER_PUBLIC_LOCATION,
        'USER': OGC_SERVER_DEFAULT_USER,
        'PASSWORD': OGC_SERVER_DEFAULT_PASSWORD,
        'MAPFISH_PRINT_ENABLED': True,
        'PRINT_NG_ENABLED': True,
        'GEONODE_SECURITY_ENABLED': True,
        'GEOFENCE_SECURITY_ENABLED': True,
        'WMST_ENABLED': False,
        'BACKEND_WRITE_ENABLED': True,
        'WPS_ENABLED': False,
        'LOG_FILE': '%s/geoserver/data/logs/geoserver.log' %
os.path.abspath(os.path.join(PROJECT_ROOT, os.pardir)),
        # Set to dictionary identifier of database containing spatial
data in DATABASES dictionary to enable
        'DATASTORE': 'datastore',
        'TIMEOUT': int(os.getenv('OGC_REQUEST_TIMEOUT', '5')),
        'MAX_RETRIES': int(os.getenv('OGC_REQUEST_MAX_RETRIES', '5')),
        'BACKOFF_FACTOR': float(os.getenv('OGC_REQUEST_BACKOFF_FACTOR', '0.3')),
        'POOL_MAXSIZE': int(os.getenv('OGC_REQUEST_POOL_MAXSIZE', '10')),
        'POOL_CONNECTIONS':
int(os.getenv('OGC_REQUEST_POOL_CONNECTIONS', '10')),
# WARNING: Map Editing is affected by this. GeoExt Configuration is
cached for 5 minutes
# CACHES = {
#     'default': {
#         'BACKEND': 'django.core.cache.backends.filebased.FileBasedCache',
#         'LOCATION': '/var/tmp/django_cache',
# If you want to enable Mosaics use the following configuration
UPLOADER = {
    # 'BACKEND': 'geonode.rest',
    'BACKEND': 'geonode.importer',
    'OPTIONS': {
        'TIME_ENABLED': True,
        'MOSAIC_ENABLED': False,
    'SUPPORTED_CRS': [
        'EPSG:4326',
        'EPSG:3785',
        'EPSG:3857',
        'EPSG:32647',
        'EPSG:32736'
    'SUPPORTED_EXT': [
        '.shp',
        '.csv',
        '.kml',
        '.kmz',
        '.json',
        '.geojson',
        '.tif',
        '.tiff',
        '.geotiff',
        '.gml',
        '.xml'
# CSW settings
CATALOGUE = {
    'default': {
        # The underlying CSW implementation
        # default is pycsw in local mode (tied directly to GeoNode Django DB)
        'ENGINE': 'geonode.catalogue.backends.pycsw_local',
        # pycsw in non-local mode
        # 'ENGINE': 'geonode.catalogue.backends.pycsw_http',
        # GeoNetwork opensource
        # 'ENGINE': 'geonode.catalogue.backends.geonetwork',
        # deegree and others
        # 'ENGINE': 'geonode.catalogue.backends.generic',
        # The FULLY QUALIFIED base url to the CSW instance for this GeoNode
        'URL': urljoin(SITEURL, '/catalogue/csw'),
        # 'URL': 'http://localhost:8080/geonetwork/srv/en/csw',
        # 'URL': 'http://localhost:8080/deegree-csw-demo-3.0.4/services',
        # login credentials (for GeoNetwork)
        # 'USER': 'admin',
        # 'PASSWORD': 'admin',
        # 'ALTERNATES_ONLY': True,
# pycsw settings
PYCSW = {
    # pycsw configuration
    'CONFIGURATION': {
        # uncomment / adjust to override server config system defaults
        # 'server': {
        #    'maxrecords': '10',
        #    'pretty_print': 'true',
        #    'federatedcatalogues': 'http://catalog.data.gov/csw'
        'server': {
            'home': '.',
            'url': CATALOGUE['default']['URL'],
            'encoding': 'UTF-8',
            'language': LANGUAGE_CODE,
            'maxrecords': '20',
            # 'domainquerytype': 'range',
            'domaincounts': 'true',
            'profiles': 'apiso,ebrim',
        'manager': {
            # authentication/authorization is handled by Django
            'transactions': 'false',
            'allowed_ips': '*',
            # 'csw_harvest_pagesize': '10',
        'metadata:main': {
            'identification_title': 'GeoNode Catalogue',
            'identification_abstract': 'GeoNode is an open source platform' \
            ' that facilitates the creation, sharing, and collaborative use' \
            ' of geospatial data',
            'identification_keywords': 'sdi, catalogue, discovery, metadata,' \
            ' GeoNode',
            'identification_keywords_type': 'theme',
            'identification_fees': 'None',
            'identification_accessconstraints': 'None',
            'provider_name': 'Organization Name',
            'provider_url': SITEURL,
            'contact_name': 'Lastname, Firstname',
            'contact_position': 'Position Title',
            'contact_address': 'Mailing Address',
            'contact_city': 'City',
            'contact_stateorprovince': 'Administrative Area',
            'contact_postalcode': 'Zip or Postal Code',
            'contact_country': 'Country',
            'contact_phone': '+xx-xxx-xxx-xxxx',
            'contact_fax': '+xx-xxx-xxx-xxxx',
            'contact_email': 'Email Address',
            'contact_url': 'Contact URL',
            'contact_hours': 'Hours of Service',
            'contact_instructions': 'During hours of service. Off on ' \
            'weekends.',
            'contact_role': 'pointOfContact',
        'metadata:inspire': {
            'enabled': 'true',
            'languages_supported': 'eng,gre',
            'default_language': 'eng',
            'date': 'YYYY-MM-DD',
            'gemet_keywords': 'Utility and governmental services',
            'conformity_service': 'notEvaluated',
            'contact_name': 'Organization Name',
            'temp_extent': 'YYYY-MM-DD/YYYY-MM-DD',
LOGGING = {
    'version': 1,
    'disable_existing_loggers': True,
    'formatters': {
        'verbose': {
            'format': '%(levelname)s %(asctime)s %(module)s %(process)d '
                      '%(thread)d %(message)s'
        'simple': {
            'format': '%(message)s',
    'filters': {
        'require_debug_false': {
            '()': 'django.utils.log.RequireDebugFalse'
    'handlers': {
        'console': {
            'level': 'DEBUG',
            'class': 'logging.StreamHandler',
            'formatter': 'simple'
        'mail_admins': {
            'level': 'ERROR',
            'filters': ['require_debug_false'],
            'class': 'django.utils.log.AdminEmailHandler',
    "loggers": {
        "django": {
            "handlers": ["console"], "level": "ERROR", },
        "geonode": {
            "handlers": ["console"], "level": "INFO", },
        "geonode.qgis_server": {
        "gsconfig.catalog": {
        "owslib": {
        "pycsw": {
        "celery": {
            'handlers': ["console"], 'level': 'ERROR', },
# Additional settings
X_FRAME_OPTIONS = 'ALLOW-FROM %s' % SITEURL
CORS_ORIGIN_ALLOW_ALL = True
GEOIP_PATH = "/usr/local/share/GeoIP"
ACCOUNT_OPEN_SIGNUP = True
ACCOUNT_APPROVAL_REQUIRED = True
Could you help me, thanks in advance.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190826/9a72918a/attachment-0001.html>
More information about the geonode-users mailing list
