[GeoNode-users] Unable to see a newly added layer in Geoserver in Geonode
Nicolas D.
hieloynieve at gmail.com
Tue Dec 10 06:04:56 PST 2019
Thank you for your help. Sorry, it's an oversight on my part. I will pay
attention next time.
I looked at the geonode / settings.py file to check for correct setting
parameters.
The OGC dictionary parameters are as follows
OGC_SERVER = {
'default': {
'BACKEND': 'geonode.geoserver',
'LOCATION': GEOSERVER_LOCATION,
'WEB_UI_LOCATION': GEOSERVER_WEB_UI_LOCATION,
'LOGIN_ENDPOINT': 'j_spring_oauth2_geonode_login',
'LOGOUT_ENDPOINT': 'j_spring_oauth2_geonode_logout',
# PUBLIC_LOCATION needs to be kept like this because in dev mode
# the proxy won't work and the integration tests will fail
# the entire block has to be overridden in the local_settings
'PUBLIC_LOCATION': GEOSERVER_PUBLIC_LOCATION,
'USER': OGC_SERVER_DEFAULT_USER,
'PASSWORD': OGC_SERVER_DEFAULT_PASSWORD,
'MAPFISH_PRINT_ENABLED': True,
'PRINT_NG_ENABLED': True,
'GEONODE_SECURITY_ENABLED': True,
'GEOFENCE_SECURITY_ENABLED': GEOFENCE_SECURITY_ENABLED,
'GEOFENCE_URL': os.getenv('GEOFENCE_URL', 'internal:/'),
'WMST_ENABLED': False,
'BACKEND_WRITE_ENABLED': True,
'WPS_ENABLED': True,
'LOG_FILE': '%s/geoserver/data/logs/geoserver.log'
% os.path.abspath(os.path.join(PROJECT_ROOT, os.pardir)),
# Set to name of database in DATABASES dictionary to enable
# 'datastore',
'DATASTORE': os.getenv('DEFAULT_BACKEND_DATASTORE', ''),
'TIMEOUT': int(os.getenv('OGC_REQUEST_TIMEOUT', '5')),
'MAX_RETRIES': int(os.getenv('OGC_REQUEST_MAX_RETRIES', '5')),
'BACKOFF_FACTOR': float(os.getenv('OGC_REQUEST_BACKOFF_FACTOR',
'0.3')),
'POOL_MAXSIZE': int(os.getenv('OGC_REQUEST_POOL_MAXSIZE', '10')),
'POOL_CONNECTIONS': int(os.getenv('OGC_REQUEST_POOL_CONNECTIONS',
'10')),
Are the variables correct?
Should I check other settings in the file for this to work?
Nicolas
Le mar. 10 déc. 2019 à 14:31, Francesco Bartoli <xbartolone at gmail.com> a
écrit :
> Please look at the documentation
> http://docs.geonode.org/en/2.10.x/basic/index.html#geonode-settings
> And also, please remember to reply to the list so the discussion can be
> useful for others
> Il 10 dic 2019, 14:27 +0100, Nicolas D. <hieloynieve at gmail.com>, ha
> scritto:
> Hi,
> Thank you for your reply. Where can I find the settings.py file? What
> settings do I need to configure or check for this to work properly?
> Regards,
> Nicolas
> Le mar. 10 déc. 2019 à 13:54, Francesco Bartoli <xbartolone at gmail.com> a
> écrit :
>> Hi,
>> apparently it doesn’t accomplish to access GeoServer properly so the
>> question is how does your settings.py look like?
>> Francesco
>> Il 10 dic 2019, 11:15 +0100, Nicolas D. <hieloynieve at gmail.com>, ha
>> scritto:
>> Hi,
>> I tried using the updatelayers function to Update the GeoNode application
>> with the GeoServer data. I used python manage.py updatelayers, but I do not
>> understand why it does not work. I have attached the errors displayed. Can
>> you please help me to find out what's wrong? Thank you in advance,
>> truthfully yours,
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191210/bf420fca/attachment.html>
More information about the geonode-users
