[GeoNode-users] Unable to see a newly added layer in Geoserver in Geonode
Nicolas D.
hieloynieve at gmail.com
Tue Dec 10 06:27:35 PST 2019
I tried these different commands:
- python manage.py updatelayers
- python manage.py updatelayers --skip-geonode-registered -w geonode
- python manage.py updatelayers -w geonode
Each time, it does not work
Le mar. 10 déc. 2019 à 15:09, Francesco Bartoli <xbartolone at gmail.com> a
écrit :
> What’s then the literal command you are trying to run?
> Il 10 dic 2019, 15:05 +0100, Nicolas D. <hieloynieve at gmail.com>, ha
> scritto:
> Thank you for your help. Sorry, it's an oversight on my part. I will pay
> attention next time.
> I looked at the geonode / settings.py file to check for correct setting
> parameters.
> The OGC dictionary parameters are as follows
> OGC_SERVER = {
> 'default': {
> 'BACKEND': 'geonode.geoserver',
> 'LOCATION': GEOSERVER_LOCATION,
> 'WEB_UI_LOCATION': GEOSERVER_WEB_UI_LOCATION,
> 'LOGIN_ENDPOINT': 'j_spring_oauth2_geonode_login',
> 'LOGOUT_ENDPOINT': 'j_spring_oauth2_geonode_logout',
> # PUBLIC_LOCATION needs to be kept like this because in dev mode
> # the proxy won't work and the integration tests will fail
> # the entire block has to be overridden in the local_settings
> 'PUBLIC_LOCATION': GEOSERVER_PUBLIC_LOCATION,
> 'USER': OGC_SERVER_DEFAULT_USER,
> 'PASSWORD': OGC_SERVER_DEFAULT_PASSWORD,
> 'MAPFISH_PRINT_ENABLED': True,
> 'PRINT_NG_ENABLED': True,
> 'GEONODE_SECURITY_ENABLED': True,
> 'GEOFENCE_SECURITY_ENABLED': GEOFENCE_SECURITY_ENABLED,
> 'GEOFENCE_URL': os.getenv('GEOFENCE_URL', 'internal:/'),
> 'WMST_ENABLED': False,
> 'BACKEND_WRITE_ENABLED': True,
> 'WPS_ENABLED': True,
> 'LOG_FILE': '%s/geoserver/data/logs/geoserver.log'
> % os.path.abspath(os.path.join(PROJECT_ROOT, os.pardir)),
> # Set to name of database in DATABASES dictionary to enable
> # 'datastore',
> 'DATASTORE': os.getenv('DEFAULT_BACKEND_DATASTORE', ''),
> 'TIMEOUT': int(os.getenv('OGC_REQUEST_TIMEOUT', '5')),
> 'MAX_RETRIES': int(os.getenv('OGC_REQUEST_MAX_RETRIES', '5')),
> 'BACKOFF_FACTOR': float(os.getenv('OGC_REQUEST_BACKOFF_FACTOR',
> '0.3')),
> 'POOL_MAXSIZE': int(os.getenv('OGC_REQUEST_POOL_MAXSIZE', '10')),
> 'POOL_CONNECTIONS': int(os.getenv('OGC_REQUEST_POOL_CONNECTIONS',
> '10')),
> Are the variables correct?
> Should I check other settings in the file for this to work?
> Nicolas
> Le mar. 10 déc. 2019 à 14:31, Francesco Bartoli <xbartolone at gmail.com> a
> écrit :
>> Please look at the documentation
>> http://docs.geonode.org/en/2.10.x/basic/index.html#geonode-settings
>> And also, please remember to reply to the list so the discussion can be
>> useful for others
>> Il 10 dic 2019, 14:27 +0100, Nicolas D. <hieloynieve at gmail.com>, ha
>> scritto:
>> Hi,
>> Thank you for your reply. Where can I find the settings.py file? What
>> settings do I need to configure or check for this to work properly?
>> Regards,
>> Nicolas
>> Le mar. 10 déc. 2019 à 13:54, Francesco Bartoli <xbartolone at gmail.com> a
>> écrit :
>>> Hi,
>>> apparently it doesn’t accomplish to access GeoServer properly so the
>>> question is how does your settings.py look like?
>>> Francesco
>>> Il 10 dic 2019, 11:15 +0100, Nicolas D. <hieloynieve at gmail.com>, ha
>>> scritto:
>>> Hi,
>>> I tried using the updatelayers function to Update the GeoNode
>>> application with the GeoServer data. I used python manage.py updatelayers,
>>> but I do not understand why it does not work. I have attached the errors
>>> displayed. Can you please help me to find out what's wrong? Thank you in
>>> advance, truthfully yours,
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191210/54364c2e/attachment.html>
More information about the geonode-users
