[GeoNode-users] Unable to see a newly added layer in Geoserver in Geonode
Nicolas D. hieloynieve at gmail.com
Tue Dec 10 09:35:59 PST 2019
you're right, I haven't seen this page. Thank you, it's interesting because
that's exactly what I want to do, since I also want to add data from a
POSTGIS database.
When I use the DJANGO_SETTINGS_MODULE = geonode.settings python manage.py
updatelayers --help function, it works correctly as shown in website.
By cons, when I want to add the data with this command:
DJANGO_SETTINGS_MODULE=geonode.settings python manage.py updatelayers -w
geonode -f Measures, it does not work. I have attached the displayed errors.
Can you please tell me the parameters to configure for this function to
work properly? what is the next step to test what's wrong?
Le mar. 10 déc. 2019 à 16:02, Francesco Bartoli <xbartolone at gmail.com> a
écrit :
> I guess you didn’t have a look at the documentation
> http://docs.geonode.org/en/2.10.x/admin/mgmt_commands/index.html#management-command-updatelayers
> Il 10 dic 2019, 15:58 +0100, Nicolas D. <hieloynieve at gmail.com>, ha
> scritto:
> What should I give you as details for "-settings = geonode.settings"?
> Le mar. 10 déc. 2019 à 15:47, Nicolas D. <hieloynieve at gmail.com> a écrit :
>> I uploaded a layer to GeoServer as (
>> https://geoserver.geo-solutions.it/edu/en/adding_data/add_shp.html)
>> After, I am able to see the new layer in the GeoServer Layers page
>> I have made changes to the GeoFence Data Rules by creating new rules for
>> the services (GWC, WMS, *, WPS, WFS)
>> For import data to geonode, i used the python manage.py updatelayers
>> command for it but it doesn't work.
>> I'm using a virtual environment. For start geonode I use the command: source
>> env/bin/activate, then I set on the folder of the application (cd
>> "folder"), to launch the services: paver start.
>>    - Specs: GeoNode version: 2.8 with mapstore viewer, GeoServer
>>    version: 2.14.3, Ubuntu server
>> Le mar. 10 déc. 2019 à 15:31, Francesco Bartoli <xbartolone at gmail.com> a
>> écrit :
>>> All of them are missing the declaration of the settings to use, are you
>>> in a virtual environment or something? Can you try by explicitly declaring
>>> it?
>>> —settings=geonode.settings
>>> Il 10 dic 2019, 15:27 +0100, Nicolas D. <hieloynieve at gmail.com>, ha
>>> scritto:
>>> I tried these different commands:
>>> - python manage.py updatelayers
>>> - python manage.py updatelayers --skip-geonode-registered -w geonode
>>> - python manage.py updatelayers -w geonode
>>> Each time, it does not work
>>> Le mar. 10 déc. 2019 à 15:09, Francesco Bartoli <xbartolone at gmail.com>
>>> a écrit :
>>>> What’s then the literal command you are trying to run?
>>>> Il 10 dic 2019, 15:05 +0100, Nicolas D. <hieloynieve at gmail.com>, ha
>>>> scritto:
>>>> Thank you for your help. Sorry, it's an oversight on my part. I will
>>>> pay attention next time.
>>>> I looked at the geonode / settings.py file to check for correct setting
>>>> parameters.
>>>> The OGC dictionary parameters are as follows
>>>> OGC_SERVER = {
>>>>     'default': {
>>>>         'BACKEND': 'geonode.geoserver',
>>>>         'LOCATION': GEOSERVER_LOCATION,
>>>>         'WEB_UI_LOCATION': GEOSERVER_WEB_UI_LOCATION,
>>>>         'LOGIN_ENDPOINT': 'j_spring_oauth2_geonode_login',
>>>>         'LOGOUT_ENDPOINT': 'j_spring_oauth2_geonode_logout',
>>>>         # PUBLIC_LOCATION needs to be kept like this because in dev mode
>>>>         # the proxy won't work and the integration tests will fail
>>>>         # the entire block has to be overridden in the local_settings
>>>>         'PUBLIC_LOCATION': GEOSERVER_PUBLIC_LOCATION,
>>>>         'USER': OGC_SERVER_DEFAULT_USER,
>>>>         'PASSWORD': OGC_SERVER_DEFAULT_PASSWORD,
>>>>         'MAPFISH_PRINT_ENABLED': True,
>>>>         'PRINT_NG_ENABLED': True,
>>>>         'GEONODE_SECURITY_ENABLED': True,
>>>>         'GEOFENCE_SECURITY_ENABLED': GEOFENCE_SECURITY_ENABLED,
>>>>         'GEOFENCE_URL': os.getenv('GEOFENCE_URL', 'internal:/'),
>>>>         'WMST_ENABLED': False,
>>>>         'BACKEND_WRITE_ENABLED': True,
>>>>         'WPS_ENABLED': True,
>>>>         'LOG_FILE': '%s/geoserver/data/logs/geoserver.log'
>>>>         % os.path.abspath(os.path.join(PROJECT_ROOT, os.pardir)),
>>>>         # Set to name of database in DATABASES dictionary to enable
>>>>         # 'datastore',
>>>>         'DATASTORE': os.getenv('DEFAULT_BACKEND_DATASTORE', ''),
>>>>         'TIMEOUT': int(os.getenv('OGC_REQUEST_TIMEOUT', '5')),
>>>>         'MAX_RETRIES': int(os.getenv('OGC_REQUEST_MAX_RETRIES', '5')),
>>>>         'BACKOFF_FACTOR': float(os.getenv('OGC_REQUEST_BACKOFF_FACTOR',
>>>> '0.3')),
>>>>         'POOL_MAXSIZE': int(os.getenv('OGC_REQUEST_POOL_MAXSIZE',
>>>> '10')),
>>>>         'POOL_CONNECTIONS':
>>>> int(os.getenv('OGC_REQUEST_POOL_CONNECTIONS', '10')),
>>>> Are the variables correct?
>>>> Should I check other settings in the file for this to work?
>>>> Nicolas
>>>> Le mar. 10 déc. 2019 à 14:31, Francesco Bartoli <xbartolone at gmail.com>
>>>> a écrit :
>>>>> Please look at the documentation
>>>>> http://docs.geonode.org/en/2.10.x/basic/index.html#geonode-settings
>>>>> And also, please remember to reply to the list so the discussion can
>>>>> be useful for others
>>>>> Il 10 dic 2019, 14:27 +0100, Nicolas D. <hieloynieve at gmail.com>, ha
>>>>> scritto:
>>>>> Hi,
>>>>> Thank you for your reply. Where can I find the settings.py file? What
>>>>> settings do I need to configure or check for this to work properly?
>>>>> Regards,
>>>>> Nicolas
>>>>> Le mar. 10 déc. 2019 à 13:54, Francesco Bartoli <xbartolone at gmail.com>
>>>>> a écrit :
>>>>>> Hi,
>>>>>> apparently it doesn’t accomplish to access GeoServer properly so the
>>>>>> question is how does your settings.py look like?
>>>>>> Francesco
>>>>>> Il 10 dic 2019, 11:15 +0100, Nicolas D. <hieloynieve at gmail.com>, ha
>>>>>> scritto:
>>>>>> Hi,
>>>>>> I tried using the updatelayers function to Update the GeoNode
>>>>>> application with the GeoServer data. I used python manage.py updatelayers,
>>>>>> but I do not understand why it does not work. I have attached the errors
>>>>>> displayed. Can you please help me to find out what's wrong? Thank you in
>>>>>> advance, truthfully yours,
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191210/d9e951ac/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191210/d9e951ac/attachment-0001.png>
More information about the geonode-users mailing list
