[GeoNode-users] Unable to see a newly added layer in Geoserver in Geonode
Nicolas D.
hieloynieve at gmail.com
Tue Dec 10 13:44:36 PST 2019
Thanks for these informations. I will see to install the latest version
2.10.
So, I wanted to know why when we add data in geoserver, we can't see them
through a WMS url in other applications? While the data added in geonode
they are visible through a WMS url.
Le mar. 10 déc. 2019 à 19:07, Francesco Bartoli <xbartolone at gmail.com> a
écrit :
> DJANGO_SETTINGS_MODULE=geonode.settings and —settings=geonode.settings are
> equivalent. That said, I’m still seeing a connection error but I cannot say
> what that should be. However, be careful about the fact that 2.8 is no
> longer maintained. I would recommend to upgrade as soon as possible
> Hope this helps
> F.
> Il 10 dic 2019, 18:36 +0100, Nicolas D. <hieloynieve at gmail.com>, ha
> scritto:
> you're right, I haven't seen this page. Thank you, it's interesting
> because that's exactly what I want to do, since I also want to add data
> from a POSTGIS database.
> When I use the DJANGO_SETTINGS_MODULE = geonode.settings python manage.py
> updatelayers --help function, it works correctly as shown in website.
> By cons, when I want to add the data with this command:
> DJANGO_SETTINGS_MODULE=geonode.settings python manage.py updatelayers -w
> geonode -f Measures, it does not work. I have attached the displayed
> errors.
> Can you please tell me the parameters to configure for this function to
> work properly? what is the next step to test what's wrong?
> Le mar. 10 déc. 2019 à 16:02, Francesco Bartoli <xbartolone at gmail.com> a
> écrit :
>> I guess you didn’t have a look at the documentation
>> http://docs.geonode.org/en/2.10.x/admin/mgmt_commands/index.html#management-command-updatelayers
>> Il 10 dic 2019, 15:58 +0100, Nicolas D. <hieloynieve at gmail.com>, ha
>> scritto:
>> What should I give you as details for "-settings = geonode.settings"?
>> Le mar. 10 déc. 2019 à 15:47, Nicolas D. <hieloynieve at gmail.com> a
>> écrit :
>>> I uploaded a layer to GeoServer as (
>>> https://geoserver.geo-solutions.it/edu/en/adding_data/add_shp.html)
>>> After, I am able to see the new layer in the GeoServer Layers page
>>> I have made changes to the GeoFence Data Rules by creating new rules for
>>> the services (GWC, WMS, *, WPS, WFS)
>>> For import data to geonode, i used the python manage.py updatelayers
>>> command for it but it doesn't work.
>>> I'm using a virtual environment. For start geonode I use the command: source
>>> env/bin/activate, then I set on the folder of the application (cd
>>> "folder"), to launch the services: paver start.
>>> - Specs: GeoNode version: 2.8 with mapstore viewer, GeoServer
>>> version: 2.14.3, Ubuntu server
>>> Le mar. 10 déc. 2019 à 15:31, Francesco Bartoli <xbartolone at gmail.com>
>>> a écrit :
>>>> All of them are missing the declaration of the settings to use, are you
>>>> in a virtual environment or something? Can you try by explicitly declaring
>>>> it?
>>>> Il 10 dic 2019, 15:27 +0100, Nicolas D. <hieloynieve at gmail.com>, ha
>>>> scritto:
>>>> I tried these different commands:
>>>> - python manage.py updatelayers
>>>> - python manage.py updatelayers --skip-geonode-registered -w geonode
>>>> - python manage.py updatelayers -w geonode
>>>> Each time, it does not work
>>>> Le mar. 10 déc. 2019 à 15:09, Francesco Bartoli <xbartolone at gmail.com>
>>>> a écrit :
>>>>> What’s then the literal command you are trying to run?
>>>>> Il 10 dic 2019, 15:05 +0100, Nicolas D. <hieloynieve at gmail.com>, ha
>>>>> scritto:
>>>>> Thank you for your help. Sorry, it's an oversight on my part. I will
>>>>> pay attention next time.
>>>>> I looked at the geonode / settings.py file to check for correct
>>>>> setting parameters.
>>>>> The OGC dictionary parameters are as follows
>>>>> OGC_SERVER = {
>>>>> 'default': {
>>>>> 'BACKEND': 'geonode.geoserver',
>>>>> 'LOCATION': GEOSERVER_LOCATION,
>>>>> 'WEB_UI_LOCATION': GEOSERVER_WEB_UI_LOCATION,
>>>>> 'LOGIN_ENDPOINT': 'j_spring_oauth2_geonode_login',
>>>>> 'LOGOUT_ENDPOINT': 'j_spring_oauth2_geonode_logout',
>>>>> # PUBLIC_LOCATION needs to be kept like this because in dev
>>>>> mode
>>>>> # the proxy won't work and the integration tests will fail
>>>>> # the entire block has to be overridden in the local_settings
>>>>> 'PUBLIC_LOCATION': GEOSERVER_PUBLIC_LOCATION,
>>>>> 'USER': OGC_SERVER_DEFAULT_USER,
>>>>> 'PASSWORD': OGC_SERVER_DEFAULT_PASSWORD,
>>>>> 'MAPFISH_PRINT_ENABLED': True,
>>>>> 'PRINT_NG_ENABLED': True,
>>>>> 'GEONODE_SECURITY_ENABLED': True,
>>>>> 'GEOFENCE_SECURITY_ENABLED': GEOFENCE_SECURITY_ENABLED,
>>>>> 'GEOFENCE_URL': os.getenv('GEOFENCE_URL', 'internal:/'),
>>>>> 'WMST_ENABLED': False,
>>>>> 'BACKEND_WRITE_ENABLED': True,
>>>>> 'WPS_ENABLED': True,
>>>>> 'LOG_FILE': '%s/geoserver/data/logs/geoserver.log'
>>>>> % os.path.abspath(os.path.join(PROJECT_ROOT, os.pardir)),
>>>>> # Set to name of database in DATABASES dictionary to enable
>>>>> # 'datastore',
>>>>> 'DATASTORE': os.getenv('DEFAULT_BACKEND_DATASTORE', ''),
>>>>> 'TIMEOUT': int(os.getenv('OGC_REQUEST_TIMEOUT', '5')),
>>>>> 'MAX_RETRIES': int(os.getenv('OGC_REQUEST_MAX_RETRIES', '5')),
>>>>> 'BACKOFF_FACTOR':
>>>>> float(os.getenv('OGC_REQUEST_BACKOFF_FACTOR', '0.3')),
>>>>> 'POOL_MAXSIZE': int(os.getenv('OGC_REQUEST_POOL_MAXSIZE',
>>>>> '10')),
>>>>> 'POOL_CONNECTIONS':
>>>>> int(os.getenv('OGC_REQUEST_POOL_CONNECTIONS', '10')),
>>>>> Are the variables correct?
>>>>> Should I check other settings in the file for this to work?
>>>>> Nicolas
>>>>> Le mar. 10 déc. 2019 à 14:31, Francesco Bartoli <xbartolone at gmail.com>
>>>>> a écrit :
>>>>>> Please look at the documentation
>>>>>> http://docs.geonode.org/en/2.10.x/basic/index.html#geonode-settings
>>>>>> And also, please remember to reply to the list so the discussion can
>>>>>> be useful for others
>>>>>> Il 10 dic 2019, 14:27 +0100, Nicolas D. <hieloynieve at gmail.com>, ha
>>>>>> scritto:
>>>>>> Hi,
>>>>>> Thank you for your reply. Where can I find the settings.py file? What
>>>>>> settings do I need to configure or check for this to work properly?
>>>>>> Regards,
>>>>>> Nicolas
>>>>>> Le mar. 10 déc. 2019 à 13:54, Francesco Bartoli <xbartolone at gmail.com>
>>>>>> a écrit :
>>>>>>> Hi,
>>>>>>> apparently it doesn’t accomplish to access GeoServer properly so the
>>>>>>> question is how does your settings.py look like?
>>>>>>> Francesco
>>>>>>> Il 10 dic 2019, 11:15 +0100, Nicolas D. <hieloynieve at gmail.com>, ha
>>>>>>> scritto:
>>>>>>> Hi,
>>>>>>> I tried using the updatelayers function to Update the GeoNode
>>>>>>> application with the GeoServer data. I used python manage.py updatelayers,
>>>>>>> but I do not understand why it does not work. I have attached the errors
>>>>>>> displayed. Can you please help me to find out what's wrong? Thank you in
>>>>>>> advance, truthfully yours,
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191210/77c14d2e/attachment.html>
More information about the geonode-users
