[GeoNode-users] Unexpected error when uploading
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Feb 11 05:01:46 PST 2019
Yes, we need to revert the PR for sure, at least for now.
Il giorno lun 11 feb 2019 alle ore 14:00 Francesco Bartoli <
xbartolone at gmail.com> ha scritto:
> What can we do? I’d go with reverting it and asking the developer to come
> up with a solution. This is gone to block geonode-project at all
> Il 11 feb 2019, 13:48 +0100, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it>, ha scritto:
> Given the stacktrace below, it seems to me a regression caused by this PR
> https://github.com/GeoNode/geonode/pull/4209
>   File "/usr/local/lib/python2.7/site-packages/haystack/signals.py", line
> 52, in handle_save
>     index.update_object(instance, using=using)
>   File "/usr/local/lib/python2.7/site-packages/haystack/indexes.py", line
> 284, in update_object
>     backend.update(self, [instance])
>   File
> "/usr/local/lib/python2.7/site-packages/haystack/backends/elasticsearch_backend.py",
> line 168, in update
>     prepped_data = index.full_prepare(obj)
> 208, in full_prepare
>     self.prepared_data = self.prepare(obj)
> 199, in prepare
>     self.prepared_data[field.index_fieldname] = field.prepare(obj)
>   File "/usr/local/lib/python2.7/site-packages/haystack/fields.py", line
> 206, in prepare
>     return self.convert(super(CharField, self).prepare(obj))
> 88, in prepare
>     values = self.resolve_attributes_lookup(current_objects, attrs)
> 115, in resolve_attributes_lookup
>     values.extend(self.resolve_attributes_lookup(current_objects_in_attr,
> attributes[1:]))
> 107, in resolve_attributes_lookup
>     for current_object in current_objects:
>   File
> "/usr/local/lib/python2.7/site-packages/django/utils/functional.py", line
> 239, in inner
>     return func(self._wrapped, *args)
> TypeError: 'Profile' object is not iterable
> Il giorno lun 11 feb 2019 alle ore 13:40 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> ha scritto:
>> Does not seem to be a GeoServer <--> GeoNode issue, but just a GeoNode
>> one
>> {"errors": ["Unexpected exception 'Profile' object is not iterable"],
>> "success": false}
>> Il giorno lun 11 feb 2019 alle ore 11:51 Alessio Fabiani <
>>> At a first glance, GeoFence rules seem to be good to me.
>>> In that case it could be some REST specific security rule, which is
>>> strange in any case.
>>> Il giorno lun 11 feb 2019 alle ore 11:47 Paolo Pasquali <
>>> paolo.pasquali at gmail.com> ha scritto:
>>>> Hi all,
>>>> These are the GeoFence rules after uploading 3 layers:
>>>> <Screenshot 2019-02-11 at 11.45.58.png>
>>>> On Mon, Feb 11, 2019 at 10:51 AM Alessio Fabiani <
>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>> Dear all,
>>>>> I'm going to make a test also myself.
>>>>> From the logged report my guess is that, somehow, the GeoFence rules
>>>>> are not correctly set after the upload.
>>>>> Il giorno lun 11 feb 2019 alle ore 10:39 Dimitris Karakostis <
>>>>> karakostis.dimitris at gmail.com> ha scritto:
>>>>>> Hello Paolo,
>>>>>> I am not sure if this helps but, I had the same error sometime ago
>>>>>> and it was related to folder permissions and ownership. I fixed by
>>>>>> assigning the right permissions to the following folders:
>>>>>> $ sudo chown -Rf geonode /home/geonode/my_geonode/
>>>>>> $ sudo chown -Rf geonode:www-data /home/geonode/my_geonode/my_geonode/static/
>>>>>> $ sudo chown -Rf geonode:www-data /home/geonode/my_geonode/my_geonode/uploaded/
>>>>>> $ chmod -Rf 777 /home/geonode/my_geonode/my_geonode/uploaded/thumbs
>>>>>> $ chmod -Rf 777 /home/geonode/my_geonode/my_geonode/uploaded/layers
>>>>>> $ sudo chown www-data:www-data /home/geonode/my_geonode/my_geonode/static_root/
>>>>>> From here:
>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/setup_configure_httpd.html
>>>>>> On Fri, Feb 8, 2019 at 4:49 PM Paolo Pasquali <
>>>>>> paolo.pasquali at gmail.com> wrote:
>>>>>>> Dear all,
>>>>>>> I have installed a GeoNode 2.10.x (master) with Docker and using the
>>>>>>> geonode-project and following this documentation: [1]
>>>>>>> The issue I have is an Unespected error! when I try to upload a
>>>>>>> layer. So in GeoNode the layer is not present.
>>>>>>> But when I double check I find the layer in GeoServer with no
>>>>>>> apparent issue and if I run updatelayers the layer appear in the django db
>>>>>>> and of course in GeoNode.
>>>>>>> I have found these errors in the log:
>>>>>>> 08 Feb 15:38:06 ERROR [geoserver.rest] - No such layer:
>>>>>>> ne_10m_geography_regions_polys
>>>>>>> geoserver4fabspace | org.geoserver.rest.ResourceNotFoundException
>>>>>>> 404 NOT_FOUND: No such layer: ne_10m_geography_regions_polys
>>>>>>> 08 Feb 15:38:15 ERROR [geoserver.rest] - No such style
>>>>>>> ne_10m_geography_regions_polys in workspace geonode
>>>>>>> org.geoserver.rest.ResourceNotFoundException 404 NOT_FOUND: No such
>>>>>>> style ne_10m_geography_regions_polys in workspace geonode
>>>>>>> Your help would be much appreciated.
>>>>>>> Thanks!
>>>>>>> Paolo
>>>>>>> [1] https://github.com/GeoNode/geonode-project#start-your-server
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>> GeoServer Professional Services from the experts! Visit
>>>>> http://goo.gl/it488V for more information.
>>>>> Ing. Alessio Fabiani
>>>>> @alfa7691
>>>>> Founder/Technical Lead
>>>>> GeoSolutions S.A.S.
>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>> phone: +39 0584 962313
>>>>> fax: +39 0584 1660272
>>>>> mob: +39 331 6233686
>>>>> http://www.geo-solutions.it
>>>>> http://twitter.com/geosolutions_it
>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>> This email is intended only for the person or entity to which it is
>>>>> addressed and may contain information that is privileged, confidential or
>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>> e-mail or the information herein by anyone other than the intended
>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>> notify us immediately by telephone or e-mail.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> @alfa7691
>> GeoSolutions S.A.S.
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190211/23972442/attachment-0001.html>
More information about the geonode-users mailing list
