[GeoNode-users] Unexpected error when uploading
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Mon Feb 11 05:10:04 PST 2019
I did another test locally and I can confirm that the issue is caused by
those lines
owner__first_name = indexes.CharField(model_attr="owner__first_name",
faceted=True, null=True)
owner__last_name = indexes.CharField(model_attr="owner__last_name",
on the "search_indexes" file.
Il giorno lun 11 feb 2019 alle ore 14:06 Francesco Bartoli <
xbartolone at gmail.com> ha scritto:
> done
> Il 11 feb 2019, 14:02 +0100, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it>, ha scritto:
> Yes, we need to revert the PR for sure, at least for now.
> Il giorno lun 11 feb 2019 alle ore 14:00 Francesco Bartoli <
>> What can we do? I’d go with reverting it and asking the developer to come
>> up with a solution. This is gone to block geonode-project at all
>> Il 11 feb 2019, 13:48 +0100, Alessio Fabiani <
>> Given the stacktrace below, it seems to me a regression caused by this PR
>> https://github.com/GeoNode/geonode/pull/4209
>> File "/usr/local/lib/python2.7/site-packages/haystack/signals.py", line
>> 52, in handle_save
>> index.update_object(instance, using=using)
>> File "/usr/local/lib/python2.7/site-packages/haystack/indexes.py", line
>> 284, in update_object
>> backend.update(self, [instance])
>> File
>> "/usr/local/lib/python2.7/site-packages/haystack/backends/elasticsearch_backend.py",
>> line 168, in update
>> prepped_data = index.full_prepare(obj)
>> 208, in full_prepare
>> self.prepared_data = self.prepare(obj)
>> 199, in prepare
>> self.prepared_data[field.index_fieldname] = field.prepare(obj)
>> File "/usr/local/lib/python2.7/site-packages/haystack/fields.py", line
>> 206, in prepare
>> return self.convert(super(CharField, self).prepare(obj))
>> 88, in prepare
>> values = self.resolve_attributes_lookup(current_objects, attrs)
>> 115, in resolve_attributes_lookup
>> values.extend(self.resolve_attributes_lookup(current_objects_in_attr,
>> attributes[1:]))
>> 107, in resolve_attributes_lookup
>> for current_object in current_objects:
>> File
>> "/usr/local/lib/python2.7/site-packages/django/utils/functional.py", line
>> 239, in inner
>> return func(self._wrapped, *args)
>> TypeError: 'Profile' object is not iterable
>> Il giorno lun 11 feb 2019 alle ore 13:40 Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> ha scritto:
>>> Does not seem to be a GeoServer <--> GeoNode issue, but just a GeoNode
>>> one
>>> {"errors": ["Unexpected exception 'Profile' object is not iterable"],
>>> "success": false}
>>> Il giorno lun 11 feb 2019 alle ore 11:51 Alessio Fabiani <
>>>> At a first glance, GeoFence rules seem to be good to me.
>>>> In that case it could be some REST specific security rule, which is
>>>> strange in any case.
>>>> Il giorno lun 11 feb 2019 alle ore 11:47 Paolo Pasquali <
>>>> paolo.pasquali at gmail.com> ha scritto:
>>>>> Hi all,
>>>>> These are the GeoFence rules after uploading 3 layers:
>>>>> <Screenshot 2019-02-11 at 11.45.58.png>
>>>>> On Mon, Feb 11, 2019 at 10:51 AM Alessio Fabiani <
>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>> Dear all,
>>>>>> I'm going to make a test also myself.
>>>>>> From the logged report my guess is that, somehow, the GeoFence rules
>>>>>> are not correctly set after the upload.
>>>>>> Il giorno lun 11 feb 2019 alle ore 10:39 Dimitris Karakostis <
>>>>>> karakostis.dimitris at gmail.com> ha scritto:
>>>>>>> Hello Paolo,
>>>>>>> I am not sure if this helps but, I had the same error sometime ago
>>>>>>> and it was related to folder permissions and ownership. I fixed by
>>>>>>> assigning the right permissions to the following folders:
>>>>>>> $ sudo chown -Rf geonode /home/geonode/my_geonode/
>>>>>>> $ sudo chown -Rf geonode:www-data /home/geonode/my_geonode/my_geonode/static/
>>>>>>> $ sudo chown -Rf geonode:www-data /home/geonode/my_geonode/my_geonode/uploaded/
>>>>>>> $ chmod -Rf 777 /home/geonode/my_geonode/my_geonode/uploaded/thumbs
>>>>>>> $ chmod -Rf 777 /home/geonode/my_geonode/my_geonode/uploaded/layers
>>>>>>> $ sudo chown www-data:www-data /home/geonode/my_geonode/my_geonode/static_root/
>>>>>>> From here:
>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/setup_configure_httpd.html
>>>>>>> On Fri, Feb 8, 2019 at 4:49 PM Paolo Pasquali <
>>>>>>> paolo.pasquali at gmail.com> wrote:
>>>>>>>> Dear all,
>>>>>>>> I have installed a GeoNode 2.10.x (master) with Docker and using
>>>>>>>> the geonode-project and following this documentation: [1]
>>>>>>>> The issue I have is an Unespected error! when I try to upload a
>>>>>>>> layer. So in GeoNode the layer is not present.
>>>>>>>> But when I double check I find the layer in GeoServer with no
>>>>>>>> apparent issue and if I run updatelayers the layer appear in the django db
>>>>>>>> and of course in GeoNode.
>>>>>>>> I have found these errors in the log:
>>>>>>>> 08 Feb 15:38:06 ERROR [geoserver.rest] - No such layer:
>>>>>>>> ne_10m_geography_regions_polys
>>>>>>>> geoserver4fabspace | org.geoserver.rest.ResourceNotFoundException
>>>>>>>> 404 NOT_FOUND: No such layer: ne_10m_geography_regions_polys
>>>>>>>> 08 Feb 15:38:15 ERROR [geoserver.rest] - No such style
>>>>>>>> ne_10m_geography_regions_polys in workspace geonode
>>>>>>>> org.geoserver.rest.ResourceNotFoundException 404 NOT_FOUND: No such
>>>>>>>> style ne_10m_geography_regions_polys in workspace geonode
>>>>>>>> Your help would be much appreciated.
>>>>>>>> Thanks!
>>>>>>>> Paolo
>>>>>>>> [1] https://github.com/GeoNode/geonode-project#start-your-server
>>>>>>>> _______________________________________________
>>>>>>>> geonode-users mailing list
>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>> http://goo.gl/it488V for more information.
>>>>>> Ing. Alessio Fabiani
>>>>>> @alfa7691
>>>>>> Founder/Technical Lead
>>>>>> GeoSolutions S.A.S.
>>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>>> phone: +39 0584 962313
>>>>>> fax: +39 0584 1660272
>>>>>> mob: +39 331 6233686
>>>>>> http://www.geo-solutions.it
>>>>>> http://twitter.com/geosolutions_it
>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>> This email is intended only for the person or entity to which it is
>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>> notify us immediately by telephone or e-mail.
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> @alfa7691
>>> GeoSolutions S.A.S.
>> @alfa7691
>> GeoSolutions S.A.S.
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190211/97e0d95c/attachment-0001.html>
More information about the geonode-users
