[GeoNode-users] Installation error 2.10 on CentOS
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Feb 11 06:20:39 PST 2019
@Federico Gianoli <alpacagis at gmail.com> could you make a try with:
pip install geonode-oauth-toolkit==1.1.3
Il giorno lun 11 feb 2019 alle ore 14:25 Francesco Bartoli <
xbartolone at gmail.com> ha scritto:
> Guys,
> from the github repo I’m only seeing the openid-connect branch while in
> the metadata for the python package it is declared this
> https://github.com/GeoNode/geonode-oauth-toolkit/blob/openid-connect/setup.cfg#L8
> I think it is reason why Federico was ending up with a empty artifact.
> Il 11 feb 2019, 14:21 +0100, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it>, ha scritto:
> I'll try to take some time to double check. It seems clear that there's
> some error on the package definition.
> Il giorno lun 11 feb 2019 alle ore 14:15 Federico Gianoli <
> alpacagis at gmail.com> ha scritto:
>> This is the result :-/
>> pip install -e .
>> Obtaining file:///tmp/geonode-oauth-toolkit
>> Installing collected packages: UNKNOWN
>>   Found existing installation: UNKNOWN 0.0.0
>>     Uninstalling UNKNOWN-0.0.0:
>>       Successfully uninstalled UNKNOWN-0.0.0
>>   Running setup.py develop for UNKNOWN
>> Successfully installed UNKNOWN
>> Traceback (most recent call last):
>>   File "/bin/pip", line 9, in <module>
>>     load_entry_point('pip==19.0.2', 'console_scripts', 'pip')()
>>   File "/usr/lib/python2.7/site-packages/pip/_internal/__init__.py", line
>> 78, in main
>>     return command.main(cmd_args)
>>   File
>> "/usr/lib/python2.7/site-packages/pip/_internal/cli/base_command.py", line
>> 228, in main
>>     timeout=min(5, options.timeout)
>>   File
>> 93, in _build_session
>>     insecure_hosts=options.trusted_hosts,
>>   File "/usr/lib/python2.7/site-packages/pip/_internal/download.py", line
>> 344, in __init__
>>     self.headers["User-Agent"] = user_agent()
>> 134, in user_agent
>>     setuptools_version = get_installed_version("setuptools")
>>   File "/usr/lib/python2.7/site-packages/pip/_internal/utils/misc.py",
>> line 902, in get_installed_version
>>     working_set = pkg_resources.WorkingSet()
>>   File
>> "/usr/lib/python2.7/site-packages/pip/_vendor/pkg_resources/__init__.py",
>> line 565, in __init__
>>     self.add_entry(entry)
>>   File
>> line 621, in add_entry
>>     for dist in find_distributions(entry, True):
>>   File
>> line 1886, in find_eggs_in_zip
>>     if metadata.has_metadata('PKG-INFO'):
>>   File
>> line 1405, in has_metadata
>>     return self.egg_info and self._has(self._fn(self.egg_info, name))
>>   File
>> line 1760, in _has
>>     return zip_path in self.zipinfo or zip_path in self._index()
>>   File
>> line 1637, in zipinfo
>>     return self._zip_manifests.load(self.loader.archive)
>>   File
>> line 1594, in load
>>     mtime = os.stat(path).st_mtime
>> OSError: [Errno 2] No such file or directory:
>> '/usr/lib/python2.7/site-packages/UNKNOWN-0.0.0-py2.7.egg'
>> *From:* Federico Gianoli <gianoli.federico at gmail.com>
>> *Sent:* 11 February 2019 14:07
>> [Messaggio troncato]  Visualizza intero messaggio
>> <https://mail.google.com/mail/u/0?ui=2&ik=b344d072b8&view=lg&permmsgid=msg-f%3A1625178261382153937&ser=1>
>> Il giorno lun 11 feb 2019 alle ore 14:01 Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> ha scritto:
>>> what about
>>> cd /tmp/geonode-oauth-toolkit/
>>> pip install -e .
>>> I also would try to cleanup completely the python/lib paths of geonode-oauth-toolkit
>>> under the Env
>>> Il giorno lun 11 feb 2019 alle ore 13:57 Federico Gianoli <
>>>> I have already tried to install it manually and the log is this:
>>>> python /tmp/geonode-oauth-toolkit/setup.py install
>>>> running install
>>>> running bdist_egg
>>>> running egg_info
>>>> writing UNKNOWN.egg-info/PKG-INFO
>>>> writing top-level names to UNKNOWN.egg-info/top_level.txt
>>>> writing dependency_links to UNKNOWN.egg-info/dependency_links.txt
>>>> reading manifest file 'UNKNOWN.egg-info/SOURCES.txt'
>>>> writing manifest file 'UNKNOWN.egg-info/SOURCES.txt'
>>>> installing library code to build/bdist.linux-x86_64/egg
>>>> running install_lib
>>>> warning: install_lib: 'build/lib' does not exist -- no Python modules
>>>> to install
>>>> creating build/bdist.linux-x86_64/egg
>>>> creating build/bdist.linux-x86_64/egg/EGG-INFO
>>>> copying UNKNOWN.egg-info/PKG-INFO ->
>>>> copying UNKNOWN.egg-info/SOURCES.txt ->
>>>> copying UNKNOWN.egg-info/dependency_links.txt ->
>>>> copying UNKNOWN.egg-info/top_level.txt ->
>>>> zip_safe flag not set; analyzing archive contents...
>>>> creating 'dist/UNKNOWN-0.0.0-py2.7.egg' and adding
>>>> 'build/bdist.linux-x86_64/egg' to it
>>>> removing 'build/bdist.linux-x86_64/egg' (and everything under it)
>>>> Processing UNKNOWN-0.0.0-py2.7.egg
>>>> Removing
>>>> /srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/UNKNOWN-0.0.0-py2.7.egg
>>>> Copying UNKNOWN-0.0.0-py2.7.egg to
>>>> UNKNOWN 0.0.0 is already the active version in easy-install.pth
>>>> Installed
>>>> Processing dependencies for UNKNOWN==0.0.0
>>>> Finished processing dependencies for UNKNOWN==0.0.0
>>>> Il giorno lun 11 feb 2019 alle ore 12:21 Alessio Fabiani <
>>>>> Federico,
>>>>> from the logs it looks like the pypi package is not working correctly
>>>>> on Centos ?!? (just guessing)
>>>>> Could you mabe try to install it manually from the source code?
>>>>> Il giorno lun 11 feb 2019 alle ore 12:01 Federico Gianoli <
>>>>>> Ciao, this is a fresh setup on a new machine running centos
>>>>>> Il giorno lunedì 11 febbraio 2019, Alessio Fabiani <
>>>>>>> Uhm, never seen this until now.
>>>>>>>  you have a previous version of the library installed on your
>>>>>>> environment? Or is this a fresh setup?
>>>>>>> Il giorno lun 11 feb 2019 alle ore 11:52 Federico Gianoli <
>>>>>>> Hi Alessio,
>>>>>>> Now we have the following error
>>>>>>> pip install geonode-oauth-toolkit --upgrade
>>>>>>> DEPRECATION: Python 2.7 will reach the end of its life on January
>>>>>>> 1st, 2020. Please upgrade your Python as Python 2.7 won't be maintained
>>>>>>> after that date. A future version of pip will drop support for Python 2.7.
>>>>>>> Collecting geonode-oauth-toolkit
>>>>>>> Installing collected packages: geonode-oauth-toolkit
>>>>>>> Exception:
>>>>>>>   File
>>>>>>> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/cli/base_command.py",
>>>>>>> line 179, in main
>>>>>>>     status = self.run(options, args)
>>>>>>>   File
>>>>>>> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/commands/install.py",
>>>>>>> line 393, in run
>>>>>>>     use_user_site=options.use_user_site,
>>>>>>>   File
>>>>>>> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/req/__init__.py",
>>>>>>> line 57, in install_given_reqs
>>>>>>>     **kwargs
>>>>>>>   File
>>>>>>> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/req/req_install.py",
>>>>>>> line 913, in install
>>>>>>>     use_user_site=use_user_site, pycompile=pycompile,
>>>>>>>   File
>>>>>>> line 445, in move_wheel_files
>>>>>>>     warn_script_location=warn_script_location,
>>>>>>>   File
>>>>>>> "/srv/www/geonode/.venvs/geonode/lib/python2.7/site-packages/pip/_internal/wheel.py",
>>>>>>> line 421, in move_wheel_files
>>>>>>>     assert info_dir, "%s .dist-info directory not found" % req
>>>>>>> AssertionError: geonode-oauth-toolkit .dist-info directory not found
>>>>>>> (geonode) $
>>>>>>> Hello Federico,
>>>>>>> could you try the following command
>>>>>>> Il giorno lun 11 feb 2019 alle ore 11:02 Federico Gianoli <
>>>>>>> Thanks Alessio,
>>>>>>> Now, during the installation of geonode-oauth-toolkit>=1.1.2rc0,  I
>>>>>>> have this error:
>>>>>>> Exception:
>>>>>>>   File
>>>>>>> line 179, in main
>>>>>>>   File
>>>>>>> line 393, in run
>>>>>>>   File
>>>>>>>     **kwargs
>>>>>>>   File
>>>>>>>   File
>>>>>>>   File
>>>>>>> AssertionError: geonode-oauth-toolkit>=1.1.2rc0 .dist-info directory
>>>>>>> not found
>>>>>>> Il giorno ven 8 feb 2019 alle ore 15:10 Alessio Fabiani <
>>>>>>> Hello Federico,
>>>>>>> it looks like you have an old version of geonode-oauth-toolkit
>>>>>>> Coult you try a
>>>>>>> pip freeze | grep oauth
>>>>>>> You should get the following results:
>>>>>>> geonode-oauth-toolkit==1.1.2rc0
>>>>>>> oauthlib==2.1.0
>>>>>>> requests-oauthlib==1.0.0
>>>>>>> Il giorno ven 8 feb 2019 alle ore 11:35 Federico Gianoli <
>>>>>>> Dear all, I am trying to install GeoNode 2.10 on Centos.
>>>>>>> I am following this guide (
>>>>>>> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit
>>>>>>> <https://www.google.com/url?q=https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit&sa=D&source=hangouts&ust=1549686966108000&usg=AFQjCNFJm4OMOTuTsHR3fuPFWeZZT4cdfQ> ),
>>>>>>> everything works fine until the command paver syn that returns this error.
>>>>>>> Someone else experieced the same issue or have any suggestion to solve it?
>>>>>>> Thanks a lot
>>>>>>> paver sync
>>>>>>> ---> pavement.sync
>>>>>>>  python -W ignore manage.py makemigrations --noinput
>>>>>>> No changes detected
>>>>>>>  python -W ignore manage.py migrate --noinput
>>>>>>> Operations to perform:
>>>>>>>   Apply all migrations: account, actstream, admin, agon_ratings,
>>>>>>> announcements, auth, avatar, base, contenttypes, dialogos, documents,
>>>>>>> geonode_client, geonode_themes, groups, guardian, invitations, layers,
>>>>>>> maps, oauth2_provider, people, pinax_notifications, services, sessions,
>>>>>>> sites, socialaccount, taggit, tastypie, upload, user_messages
>>>>>>> Running migrations:
>>>>>>>   Applying contenttypes.0001_initial... OK
>>>>>>>   Applying taggit.0001_initial... OK
>>>>>>>   Applying taggit.0002_auto_20150616_2121... OK
>>>>>>>   Applying contenttypes.0002_remove_content_type_name... OK
>>>>>>>   Applying auth.0001_initial... OK
>>>>>>>   Applying auth.0002_alter_permission_name_max_length... OK
>>>>>>>   Applying auth.0003_alter_user_email_max_length... OK
>>>>>>>   Applying auth.0004_alter_user_username_opts... OK
>>>>>>>   Applying auth.0005_alter_user_last_login_null... OK
>>>>>>>   Applying auth.0006_require_contenttypes_0002... OK
>>>>>>>   Applying people.24_initial... OK
>>>>>>>   Applying account.0001_initial... OK
>>>>>>>   Applying account.0002_email_max_length... OK
>>>>>>>   Applying actstream.0001_initial... OK
>>>>>>>   Applying actstream.0002_remove_action_data... OK
>>>>>>>   Applying admin.0001_initial... OK
>>>>>>>   Applying admin.0002_logentry_remove_auto_add... OK
>>>>>>>   Applying agon_ratings.0001_initial... OK
>>>>>>>   Applying announcements.0001_initial... OK
>>>>>>>   Applying announcements.0002_auto_20190207_1459... OK
>>>>>>>   Applying auth.0007_alter_validators_add_error_messages... OK
>>>>>>>   Applying auth.0008_alter_user_username_max_length... OK
>>>>>>>   Applying avatar.0001_initial... OK
>>>>>>>   Applying base.24_initial... OK
>>>>>>>   Applying base.24_to_26... OK
>>>>>>>   Applying base.26_to_27... OK
>>>>>>>   Applying base.0027_auto_20170801_1228... OK
>>>>>>>   Applying base.0028_resourcebase_is_approved... OK
>>>>>>>   Applying base.0029_auto_20171114_0341... OK
>>>>>>>   Applying base.0030_auto_20180309_0833... OK
>>>>>>>   Applying base.0031_auto_20180309_0837... OK
>>>>>>>   Applying base.0032_auto_20180329_1844... OK
>>>>>>>   Applying base.0033_auto_20180330_0951... OK
>>>>>>>   Applying base.0034_auto_20180606_1543... OK
>>>>>>>   Applying base.0035_resourcebase_dirty_state... OK
>>>>>>>   Applying base.0036_auto_20190207_1459... OK
>>>>>>>   Applying dialogos.0001_initial... OK
>>>>>>>   Applying documents.24_initial... OK
>>>>>>>   Applying documents.25_add_documentresourcelink_table... OK
>>>>>>>   Applying documents.26_move_data_to_documentresourcelink_table... OK
>>>>>>>   Applying documents.27_drop_resource_columns_from_document_table...
>>>>>>> OK
>>>>>>>   Applying documents.0028_auto_20170801_1228... OK
>>>>>>>   Applying documents.0029_auto_20180301_1947... OK
>>>>>>>   Applying documents.0030_auto_20180302_0430... OK
>>>>>>>   Applying documents.0031_auto_20180409_1238... OK
>>>>>>>   Applying documents.0032_auto_20180412_0822... OK
>>>>>>>   Applying documents.0033_auto_20180414_2120... OK
>>>>>>>   Applying geonode_client.0001_initial... OK
>>>>>>>   Applying geonode_client.0002_auto_20180412_1039... OK
>>>>>>>   Applying
>>>>>>> geonode_client.0003_geonodethemecustomization_jumbotron_welcome_hide... OK
>>>>>>>   Applying geonode_client.0004_auto_20180416_1319... OK
>>>>>>>   Applying geonode_client.0005_auto_20181015_1201... OK
>>>>>>>   Applying geonode_themes.0001_initial... OK
>>>>>>>   Applying geonode_themes.0002_auto_20181015_1208... OK
>>>>>>>   Applying
>>>>>>> geonode_themes.0003_remove_geonodethemecustomization_identifier... OK
>>>>>>>   Applying groups.24_initial... OK
>>>>>>>   Applying groups.26_to_27... OK
>>>>>>>   Applying groups.0027_auto_20180105_1631... OK
>>>>>>>   Applying groups.0028_auto_20180606_1543... OK
>>>>>>>   Applying guardian.0001_initial... OK
>>>>>>>   Applying invitations.0001_initial... OK
>>>>>>>   Applying invitations.0002_auto_20151126_0426... OK
>>>>>>>   Applying invitations.0003_auto_20151126_1523... OK
>>>>>>>   Applying layers.24_initial... OK
>>>>>>>   Applying services.24_initial... OK
>>>>>>>   Applying services.0025_harvestjob... OK
>>>>>>>   Applying services.0026_auto_20171130_0600... OK
>>>>>>>   Applying services.0027_harvestjob_details... OK
>>>>>>>   Applying services.0028_auto_20171201_0640... OK
>>>>>>>   Applying services.0029_auto_20171203_1624... OK
>>>>>>>   Applying services.0030_auto_20171212_0518... OK
>>>>>>>   Applying layers.24_to_26... OK
>>>>>>>   Applying layers.26_to_27... OK
>>>>>>>   Applying layers.0027_auto_20170801_1228... OK
>>>>>>>   Applying layers.0028_auto_20171218_0249... OK
>>>>>>>   Applying layers.0029_layer_service... OK
>>>>>>>   Applying layers.0030_auto_20180228_0812... OK
>>>>>>>   Applying layers.0031_uploadsession_resource... OK
>>>>>>>   Applying layers.0032_auto_20180424_1638... OK
>>>>>>>   Applying layers.0033_auto_20180606_1543... OK
>>>>>>>   Applying maps.24_initial... OK
>>>>>>>   Applying maps.0025_auto_20170801_1228... OK
>>>>>>>   Applying maps.0026_auto_20180301_1947... OK
>>>>>>>   Applying maps.0027_auto_20180302_0430... OK
>>>>>>>   Applying maps.0028_auto_20180409_1238... OK
>>>>>>>   Applying maps.0029_auto_20180412_0822... OK
>>>>>>>   Applying maps.0030_auto_20180414_2120... OK
>>>>>>>   Applying oauth2_provider.0001_initial... OK
>>>>>>>   Applying oauth2_provider.0002_08_updates... OK
>>>>>>>   Applying oauth2_provider.0003_auto_20160316_1503... OK
>>>>>>>   Applying oauth2_provider.0004_auto_20160525_1623... OK
>>>>>>>   Applying people.0025_auto_20170924_0932... OK
>>>>>>>   Applying people.0026_auto_20171120_0730... OK
>>>>>>>   Applying people.0027_auto_20180414_2120... OK
>>>>>>>   Applying people.0028_auto_20180606_1543... OK
>>>>>>>   Applying pinax_notifications.0001_initial... OK
>>>>>>>   Applying pinax_notifications.0002_auto_20171003_2006... OK
>>>>>>>   Applying services.0031_auto_20180301_1947... OK
>>>>>>>   Applying services.0032_auto_20180302_0430... OK
>>>>>>>   Applying services.0031_service_proxy_base... OK
>>>>>>>   Applying services.0033_merge... OK
>>>>>>>   Applying services.0034_auto_20180309_0917... OK
>>>>>>>   Applying services.0035_auto_20180327_0846... OK
>>>>>>>   Applying services.0036_auto_20180331_1039... OK
>>>>>>>   Applying services.0037_auto_20180409_1238... OK
>>>>>>>   Applying services.0038_auto_20180412_0822... OK
>>>>>>>   Applying services.0039_auto_20180414_2120... OK
>>>>>>>   Applying sessions.0001_initial... OK
>>>>>>>   Applying sites.0001_initial... OK
>>>>>>>   Applying sites.0002_alter_domain_unique... OK
>>>>>>>   Applying socialaccount.0001_initial... OK
>>>>>>>   Applying socialaccount.0002_token_max_lengths... OK
>>>>>>>   Applying socialaccount.0003_extra_data_default_dict... OK
>>>>>>>   Applying tastypie.0001_initial... OK
>>>>>>>   Applying upload.24_initial... OK
>>>>>>>   Applying user_messages.0001_initial... OK
>>>>>>>   Applying user_messages.0002_auto_20171107_1128... OK
>>>>>>>   Applying user_messages.0003_auto_20171108_1037... OK
>>>>>>>   Applying user_messages.0004_auto_20171108_1101... OK
>>>>>>>  python -W ignore manage.py loaddata sample_admin.json
>>>>>>> Installed 1 object(s) from 1 fixture(s)
>>>>>>> geonode/base/fixtures/default_oauth_apps.json
>>>>>>>   File "manage.py", line 29, in <module>
>>>>>>>     execute_from_command_line(sys.argv)
>>>>>>>   File
>>>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/management/__init__.py",
>>>>>>> line 364, in execute_from_command_line
>>>>>>>     utility.execute()
>>>>>>>   File
>>>>>>> line 356, in execute
>>>>>>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>>>>   File
>>>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/management/base.py",
>>>>>>> line 283, in run_from_argv
>>>>>>>     self.execute(*args, **cmd_options)
>>>>>>>   File
>>>>>>> line 330, in execute
>>>>>>>     output = self.handle(*args, **options)
>>>>>>>   File
>>>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/modeltranslation/management/commands/loaddata.py",
>>>>>>> line 61, in handle
>>>>>>>     return super(Command, self).handle(*fixture_labels, **options)
>>>>>>>   File
>>>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/management/commands/loaddata.py",
>>>>>>> line 69, in handle
>>>>>>>     self.loaddata(fixture_labels)
>>>>>>>   File
>>>>>>> line 109, in loaddata
>>>>>>>     self.load_label(fixture_label)
>>>>>>>   File
>>>>>>> line 166, in load_label
>>>>>>>     for obj in objects:
>>>>>>>   File
>>>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/serializers/json.py",
>>>>>>> line 88, in Deserializer
>>>>>>>     six.reraise(DeserializationError, DeserializationError(e),
>>>>>>> sys.exc_info()[2])
>>>>>>>   File
>>>>>>> line 82, in Deserializer
>>>>>>>     for obj in PythonDeserializer(objects, **options):
>>>>>>>   File
>>>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/core/serializers/python.py",
>>>>>>> line 129, in Deserializer
>>>>>>>     field = Model._meta.get_field(field_name)
>>>>>>>   File
>>>>>>> "/home/webbonimar/.venvs/geonode/lib/python2.7/site-packages/django/db/models/options.py",
>>>>>>> line 619, in get_field
>>>>>>>     raise FieldDoesNotExist("%s has no field named '%s'" %
>>>>>>> (self.object_name, field_name))
>>>>>>> django.core.serializers.base.DeserializationError: Problem
>>>>>>> installing fixture
>>>>>>> '/srv/www/geonode/geonode/base/fixtures/default_oauth_apps.json':
>>>>>>> Application has no field named 'updated'
>>>>>>> Captured Task Output:
>>>>>>> ---> pavement.sync
>>>>>>> Build failed running pavement.sync: Subprocess return code: 1
>>>>>>> Jan 25, 9:54
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>> http://goo.gl/it488V for more information.
>>>>>>> Ing. Alessio Fabiani
>>>>>>> @alfa7691
>>>>>>> Founder/Technical Lead
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Via di Montramito 3
>>>>>>> <https://maps.google.com/?q=Via+di+Montramito+3&entry=gmail&source=g>/A
>>>>>>> - 55054 Massarosa (LU) - Italy
>>>>>>> phone: +39 0584 962313
>>>>>>> fax: +39 0584 1660272
>>>>>>> mob: +39 331 6233686
>>>>>>> http://www.geo-solutions.it
>>>>>>> http://twitter.com/geosolutions_it
>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>>> This email is intended only for the person or entity to which it is
>>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>> notify us immediately by telephone or e-mail.
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Via di Montramito 3
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Via di Montramito 3
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190211/1ab59a35/attachment-0001.html>
More information about the geonode-users mailing list
