[GeoNode-users] Unexpected error when uploading
Francesco Bartoli xbartolone at gmail.com
Mon Feb 11 11:21:16 PST 2019
Paolo,
with the last revert on geonode repo the issue looks like solved for the upload, I’m still seeing the 404 errors on layer and style from geoserver log though.
@Alessio do you think it is worth to keep these errors traced?
Il 11 feb 2019, 14:25 +0100, G. Allegri <giovanni.allegri at geo-solutions.it>, ha scritto:
> I would like to dig into this more because haystack supports related data, even if "preparing" the data (or denormalizing them) is suggested.
> The issue aslo highlights that some tests for haystack should be added.
> Giovanni
> > Il giorno lun 11 feb 2019 alle ore 14:00 Francesco Bartoli <xbartolone at gmail.com> ha scritto:
> > > What can we do? I’d go with reverting it and asking the developer to come up with a solution. This is gone to block geonode-project at all
> > > Il 11 feb 2019, 13:48 +0100, Alessio Fabiani <alessio.fabiani at geo-solutions.it>, ha scritto:
> > > > Given the stacktrace below, it seems to me a regression caused by this PR
> > > > https://github.com/GeoNode/geonode/pull/4209
> > > >   File "/usr/local/lib/python2.7/site-packages/haystack/signals.py", line 52, in handle_save
> > > >     index.update_object(instance, using=using)
> > > >   File "/usr/local/lib/python2.7/site-packages/haystack/indexes.py", line 284, in update_object
> > > >     backend.update(self, [instance])
> > > >   File "/usr/local/lib/python2.7/site-packages/haystack/backends/elasticsearch_backend.py", line 168, in update
> > > >     prepped_data = index.full_prepare(obj)
> > > >   File "/usr/local/lib/python2.7/site-packages/haystack/indexes.py", line 208, in full_prepare
> > > >     self.prepared_data = self.prepare(obj)
> > > >   File "/usr/local/lib/python2.7/site-packages/haystack/indexes.py", line 199, in prepare
> > > >     self.prepared_data[field.index_fieldname] = field.prepare(obj)
> > > >   File "/usr/local/lib/python2.7/site-packages/haystack/fields.py", line 206, in prepare
> > > >     return self.convert(super(CharField, self).prepare(obj))
> > > >   File "/usr/local/lib/python2.7/site-packages/haystack/fields.py", line 88, in prepare
> > > >     values = self.resolve_attributes_lookup(current_objects, attrs)
> > > >   File "/usr/local/lib/python2.7/site-packages/haystack/fields.py", line 115, in resolve_attributes_lookup
> > > >     values.extend(self.resolve_attributes_lookup(current_objects_in_attr, attributes[1:]))
> > > >   File "/usr/local/lib/python2.7/site-packages/haystack/fields.py", line 107, in resolve_attributes_lookup
> > > >     for current_object in current_objects:
> > > >   File "/usr/local/lib/python2.7/site-packages/django/utils/functional.py", line 239, in inner
> > > >     return func(self._wrapped, *args)
> > > > TypeError: 'Profile' object is not iterable
> > > > > Il giorno lun 11 feb 2019 alle ore 13:40 Alessio Fabiani <alessio.fabiani at geo-solutions.it> ha scritto:
> > > > > > Does not seem to be a GeoServer <--> GeoNode issue, but just a GeoNode one
> > > > > > {"errors": ["Unexpected exception 'Profile' object is not iterable"], "success": false}
> > > > > > > Il giorno lun 11 feb 2019 alle ore 11:51 Alessio Fabiani <alessio.fabiani at geo-solutions.it> ha scritto:
> > > > > > > > At a first glance, GeoFence rules seem to be good to me.
> > > > > > > > In that case it could be some REST specific security rule, which is strange in any case.
> > > > > > > > > Il giorno lun 11 feb 2019 alle ore 11:47 Paolo Pasquali <paolo.pasquali at gmail.com> ha scritto:
> > > > > > > > > > Hi all,
> > > > > > > > > > These are the GeoFence rules after uploading 3 layers:
> > > > > > > > > > <Screenshot 2019-02-11 at 11.45.58.png>
> > > > > > > > > > > On Mon, Feb 11, 2019 at 10:51 AM Alessio Fabiani <alessio.fabiani at geo-solutions.it> wrote:
> > > > > > > > > > > > Dear all,
> > > > > > > > > > > > I'm going to make a test also myself.
> > > > > > > > > > > > From the logged report my guess is that, somehow, the GeoFence rules are not correctly set after the upload.
> > > > > > > > > > > > > Il giorno lun 11 feb 2019 alle ore 10:39 Dimitris Karakostis <karakostis.dimitris at gmail.com> ha scritto:
> > > > > > > > > > > > > > Hello Paolo,
> > > > > > > > > > > > > > I am not sure if this helps but, I had the same error sometime ago and it was related to folder permissions and ownership. I fixed by assigning the right permissions to the following folders:
> > > > > > > > > > > > > > $ sudo chown -Rf geonode /home/geonode/my_geonode/
> > > > > > > > > > > > > > $ sudo chown -Rf geonode:www-data /home/geonode/my_geonode/my_geonode/static/
> > > > > > > > > > > > > > $ sudo chown -Rf geonode:www-data /home/geonode/my_geonode/my_geonode/uploaded/
> > > > > > > > > > > > > > $ chmod -Rf 777 /home/geonode/my_geonode/my_geonode/uploaded/thumbs
> > > > > > > > > > > > > > $ chmod -Rf 777 /home/geonode/my_geonode/my_geonode/uploaded/layers
> > > > > > > > > > > > > > $ sudo chown www-data:www-data /home/geonode/my_geonode/my_geonode/static_root/
> > > > > > > > > > > > > > From here:
> > > > > > > > > > > > > > http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/setup_configure_httpd.html
> > > > > > > > > > > > > > > On Fri, Feb 8, 2019 at 4:49 PM Paolo Pasquali <paolo.pasquali at gmail.com> wrote:
> > > > > > > > > > > > > > > > Dear all,
> > > > > > > > > > > > > > > > I have installed a GeoNode 2.10.x (master) with Docker and using the geonode-project and following this documentation: [1]
> > > > > > > > > > > > > > > > The issue I have is an Unespected error! when I try to upload a layer. So in GeoNode the layer is not present.
> > > > > > > > > > > > > > > > But when I double check I find the layer in GeoServer with no apparent issue and if I run updatelayers the layer appear in the django db and of course in GeoNode.
> > > > > > > > > > > > > > > > I have found these errors in the log:
> > > > > > > > > > > > > > > > 08 Feb 15:38:06 ERROR [geoserver.rest] - No such layer: ne_10m_geography_regions_polys
> > > > > > > > > > > > > > > > geoserver4fabspace | org.geoserver.rest.ResourceNotFoundException 404 NOT_FOUND: No such layer: ne_10m_geography_regions_polys
> > > > > > > > > > > > > > > > 08 Feb 15:38:15 ERROR [geoserver.rest] - No such style ne_10m_geography_regions_polys in workspace geonode
> > > > > > > > > > > > > > > > org.geoserver.rest.ResourceNotFoundException 404 NOT_FOUND: No such style ne_10m_geography_regions_polys in workspace geonode
> > > > > > > > > > > > > > > > Your help would be much appreciated.
> > > > > > > > > > > > > > > > Thanks!
> > > > > > > > > > > > > > > > Paolo
> > > > > > > > > > > > > > > > [1] https://github.com/GeoNode/geonode-project#start-your-server
> > > > > > > > > > > > > > > > _______________________________________________
> > > > > > > > > > > > > > > > geonode-users mailing list
> > > > > > > > > > > > > > > > geonode-users at lists.osgeo.org
> > > > > > > > > > > > > > > > https://lists.osgeo.org/mailman/listinfo/geonode-users
> > > > > > > > > > > > GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
> > > > > > > > > > > > Ing. Alessio Fabiani
> > > > > > > > > > > > @alfa7691
> > > > > > > > > > > > Founder/Technical Lead
> > > > > > > > > > > > GeoSolutions S.A.S.
> > > > > > > > > > > > Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> > > > > > > > > > > > phone: +39 0584 962313
> > > > > > > > > > > > fax:     +39 0584 1660272
> > > > > > > > > > > > mob:   +39 331 6233686
> > > > > > > > > > > > http://www.geo-solutions.it
> > > > > > > > > > > > http://twitter.com/geosolutions_it
> > > > > > > > > > > > Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> > > > > > > > > > > > This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
> > > > > > > > @alfa7691
> > > > > > > > GeoSolutions S.A.S.
> > > > > > @alfa7691
> > > > > > GeoSolutions S.A.S.
> > > > @alfa7691
> > > > GeoSolutions S.A.S.
> Giovanni Allegri
> GeoSolutions S.A.S.
> Italy
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190211/661ca62e/attachment-0001.html>
More information about the geonode-users mailing list
