[GeoNode-users] Unexpected error when uploading
    Andres Juarez
    albertoandres.juarez at gmail.com
    Sat Feb 23 16:16:32 PST 2019
Hello everyone
I have the same problem but I can not apply the change, and the loading of
layers continues without working.
I rebuilt Geonode with
docker-compose stop
docker-compose up -d --build
Is this the right way? or in what way should I rebuild it?
Thanks in advance
El mar., 12 feb. 2019 a las 9:38, Paolo Pasquali (<paolo.pasquali at gmail.com>)
escribió:
> I can confirm the issue is not occurring anymore.
> Thank you all  for your help.
> Ciao
> P.
> On Mon, Feb 11, 2019 at 10:00 PM Paolo Pasquali <paolo.pasquali at gmail.com>
> wrote:
>> Thank you so much.
>> Tomorrow I’ll try it.
>> Ciao
>> P.
>> On 11 Feb 2019, 20:21 +0100, Francesco Bartoli <xbartolone at gmail.com>,
>> wrote:
>> Paolo,
>> with the last revert on geonode repo the issue looks like solved for the
>> upload, I’m still seeing the 404 errors on layer and style from geoserver
>> log though.
>> @Alessio do you think it is worth to keep these errors traced?
>> Il 11 feb 2019, 14:25 +0100, G. Allegri <
>> giovanni.allegri at geo-solutions.it>, ha scritto:
>> I would like to dig into this more because haystack supports related
>> data, even if "preparing" the data (or denormalizing them) is suggested.
>> The issue aslo highlights that some tests for haystack should be added.
>> Giovanni
>> Il giorno lun 11 feb 2019 alle ore 14:00 Francesco Bartoli <
>> xbartolone at gmail.com> ha scritto:
>>> What can we do? I’d go with reverting it and asking the developer to
>>> come up with a solution. This is gone to block geonode-project at all
>>> Il 11 feb 2019, 13:48 +0100, Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it>, ha scritto:
>>> Given the stacktrace below, it seems to me a regression caused by this PR
>>> https://github.com/GeoNode/geonode/pull/4209
>>>   File "/usr/local/lib/python2.7/site-packages/haystack/signals.py",
>>> line 52, in handle_save
>>>     index.update_object(instance, using=using)
>>>   File "/usr/local/lib/python2.7/site-packages/haystack/indexes.py",
>>> line 284, in update_object
>>>     backend.update(self, [instance])
>>>   File
>>> "/usr/local/lib/python2.7/site-packages/haystack/backends/elasticsearch_backend.py",
>>> line 168, in update
>>>     prepped_data = index.full_prepare(obj)
>>> line 208, in full_prepare
>>>     self.prepared_data = self.prepare(obj)
>>> line 199, in prepare
>>>     self.prepared_data[field.index_fieldname] = field.prepare(obj)
>>>   File "/usr/local/lib/python2.7/site-packages/haystack/fields.py", line
>>> 206, in prepare
>>>     return self.convert(super(CharField, self).prepare(obj))
>>> 88, in prepare
>>>     values = self.resolve_attributes_lookup(current_objects, attrs)
>>> 115, in resolve_attributes_lookup
>>> values.extend(self.resolve_attributes_lookup(current_objects_in_attr,
>>> attributes[1:]))
>>> 107, in resolve_attributes_lookup
>>>     for current_object in current_objects:
>>>   File
>>> "/usr/local/lib/python2.7/site-packages/django/utils/functional.py", line
>>> 239, in inner
>>>     return func(self._wrapped, *args)
>>> TypeError: 'Profile' object is not iterable
>>> Il giorno lun 11 feb 2019 alle ore 13:40 Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it> ha scritto:
>>>> Does not seem to be a GeoServer <--> GeoNode issue, but just a GeoNode
>>>> one
>>>> {"errors": ["Unexpected exception 'Profile' object is not iterable"],
>>>> "success": false}
>>>> Il giorno lun 11 feb 2019 alle ore 11:51 Alessio Fabiani <
>>>>> At a first glance, GeoFence rules seem to be good to me.
>>>>> In that case it could be some REST specific security rule, which is
>>>>> strange in any case.
>>>>> Il giorno lun 11 feb 2019 alle ore 11:47 Paolo Pasquali <
>>>>> paolo.pasquali at gmail.com> ha scritto:
>>>>>> Hi all,
>>>>>> These are the GeoFence rules after uploading 3 layers:
>>>>>> <Screenshot 2019-02-11 at 11.45.58.png>
>>>>>> On Mon, Feb 11, 2019 at 10:51 AM Alessio Fabiani <
>>>>>> alessio.fabiani at geo-solutions.it> wrote:
>>>>>>> Dear all,
>>>>>>> I'm going to make a test also myself.
>>>>>>> From the logged report my guess is that, somehow, the GeoFence rules
>>>>>>> are not correctly set after the upload.
>>>>>>> Il giorno lun 11 feb 2019 alle ore 10:39 Dimitris Karakostis <
>>>>>>> karakostis.dimitris at gmail.com> ha scritto:
>>>>>>>> Hello Paolo,
>>>>>>>> I am not sure if this helps but, I had the same error sometime ago
>>>>>>>> and it was related to folder permissions and ownership. I fixed by
>>>>>>>> assigning the right permissions to the following folders:
>>>>>>>> $ sudo chown -Rf geonode /home/geonode/my_geonode/
>>>>>>>> $ sudo chown -Rf geonode:www-data /home/geonode/my_geonode/my_geonode/static/
>>>>>>>> $ sudo chown -Rf geonode:www-data /home/geonode/my_geonode/my_geonode/uploaded/
>>>>>>>> $ chmod -Rf 777 /home/geonode/my_geonode/my_geonode/uploaded/thumbs
>>>>>>>> $ chmod -Rf 777 /home/geonode/my_geonode/my_geonode/uploaded/layers
>>>>>>>> $ sudo chown www-data:www-data /home/geonode/my_geonode/my_geonode/static_root/
>>>>>>>> From here:
>>>>>>>> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/setup_configure_httpd.html
>>>>>>>> On Fri, Feb 8, 2019 at 4:49 PM Paolo Pasquali <
>>>>>>>> paolo.pasquali at gmail.com> wrote:
>>>>>>>>> Dear all,
>>>>>>>>> I have installed a GeoNode 2.10.x (master) with Docker and using
>>>>>>>>> the geonode-project and following this documentation: [1]
>>>>>>>>> The issue I have is an Unespected error! when I try to upload a
>>>>>>>>> layer. So in GeoNode the layer is not present.
>>>>>>>>> But when I double check I find the layer in GeoServer with no
>>>>>>>>> apparent issue and if I run updatelayers the layer appear in the django db
>>>>>>>>> and of course in GeoNode.
>>>>>>>>> I have found these errors in the log:
>>>>>>>>> 08 Feb 15:38:06 ERROR [geoserver.rest] - No such layer:
>>>>>>>>> ne_10m_geography_regions_polys
>>>>>>>>> geoserver4fabspace | org.geoserver.rest.ResourceNotFoundException
>>>>>>>>> 404 NOT_FOUND: No such layer: ne_10m_geography_regions_polys
>>>>>>>>> 08 Feb 15:38:15 ERROR [geoserver.rest] - No such style
>>>>>>>>> ne_10m_geography_regions_polys in workspace geonode
>>>>>>>>> org.geoserver.rest.ResourceNotFoundException 404 NOT_FOUND: No
>>>>>>>>> such style ne_10m_geography_regions_polys in workspace geonode
>>>>>>>>> Your help would be much appreciated.
>>>>>>>>> Thanks!
>>>>>>>>> Paolo
>>>>>>>>> [1] https://github.com/GeoNode/geonode-project#start-your-server
>>>>>>>>> _______________________________________________
>>>>>>>>> geonode-users mailing list
>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>>> http://goo.gl/it488V for more information.
>>>>>>> Ing. Alessio Fabiani
>>>>>>> @alfa7691
>>>>>>> Founder/Technical Lead
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>>>>>> phone: +39 0584 962313
>>>>>>> fax: +39 0584 1660272
>>>>>>> mob: +39 331 6233686
>>>>>>> http://www.geo-solutions.it
>>>>>>> http://twitter.com/geosolutions_it
>>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>>> This email is intended only for the person or entity to which it is
>>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>>> notify us immediately by telephone or e-mail.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> @alfa7691
>>> GeoSolutions S.A.S.
>> Giovanni Allegri
>> GeoSolutions S.A.S.
>> <https://maps.google.com/?q=Via+di+Montramito+3/A%0D+55054+%C2%A0Massarosa&entry=gmail&source=g>
>> 55054  Massarosa
>>  (LU)
>> Italy
>> phone: +39 0584 962313 <+39%200584%20962313>
>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
   Andrés Juarez
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190223/86b599da/attachment-0001.html>
More information about the geonode-users
