[GeoNode-users] Print Map Preview
Julierme Pinheiro
juliermeopensourcedeveloper at gmail.com
Thu Feb 28 06:36:11 PST 2019
I got it, Alessio.
Thank you very much for ytour help.
Julierme
On Thu, Feb 28, 2019 at 6:00 AM Alessio Fabiani <alessio.fabiani at gmail.com>
wrote:
> Hi Julierme,
> indeed is possible to customize the printing module (see attached
> screenshots)
> [image: image.png]
> [image: image.png]
> Mostly you have to tweak the printing yaml file inside the GeoServer DATA
> DIR.
> Try to have a look at the following documentation
> https://docs.geoserver.org/latest/en/user/extensions/printing/index.html
> Il giorno mer 27 feb 2019 alle ore 16:07 Julierme Pinheiro <
> juliermeopensourcedeveloper at gmail.com> ha scritto:
>> Dear users,
>> I am running GeoNode-Project at 2.8 installed via Docker on an Ubuntu at 18.04
>> LTS server. I am in need to edit the default Print Preview map as adding a
>> logo and some text and date, information that is coming from Postgres
>> table. Said that:
>> 1 - I am searching for some documentation that could help me to achieve
>> that. I found this resource
>> <http://docs.geonode.org/en/master/tutorials/advanced/adv_data_mgmt/pretty_maps/map_decorations.html>
>> , but it seems to be actions on Layer preview and not a Print Preview.
>> 2 - There is something wrong with the default print preview map. The
>> print preview shows the layers over that map, but the saved pdf document
>> does not show the layers.
>> Any help on items 1 and 2 will be very appreciated.
>> Kind regards
>> Julierme
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190228/3131c051/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190228/3131c051/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190228/3131c051/attachment-0003.png>
More information about the geonode-users
