[GeoNode-users] Error on updatelayers
Abel Quesi aquesi at itssaconsulting.com
Fri Jan 4 10:48:46 PST 2019
Hi!
I created  a layer in geoserver from postgis. And it's work.
But when I execute python manage.py updatelayers  I have  this error
geo at geonode-ubuntu:~/geonode$ python manage.py updatelayers
Inspecting the available layers in GeoServer ...
Found 1 layers, starting processing
Could not retrieve GeoFence Rules count.
Stopping process because --ignore-errors was not set and an error was found.
  File "manage.py", line 29, in <module>
    execute_from_command_line(sys.argv)
  File
"/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py",
line 354, in execute_from_command_line
    utility.execute()
  File
line 346, in execute
    self.fetch_command(subcommand).run_from_argv(self.argv)
  File
"/usr/local/lib/python2.7/dist-packages/django/core/management/base.py",
line 394, in run_from_argv
    self.execute(*args, **cmd_options)
  File
line 445, in execute
    output = self.handle(*args, **options)
  File
"/home/geo/geonode/geonode/geoserver/management/commands/updatelayers.py",
line 124, in handle
    execute_signals=True)
  File "/home/geo/geonode/geonode/geoserver/helpers.py", line 632, in
gs_slurp
    "srid": resource.projection
  File "/usr/local/lib/python2.7/dist-packages/django/db/models/manager.py",
line 127, in manager_method
    return getattr(self.get_queryset(), name)(*args, **kwargs)
  File "/usr/lib/python2.7/dist-packages/modeltranslation/manager.py", line
389, in get_or_create
    return super(MultilingualQuerySet, self).get_or_create(**kwargs)
  File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py",
line 407, in get_or_create
    return self._create_object_from_params(lookup, params)
line 439, in _create_object_from_params
    obj = self.create(**params)
381, in create
    return super(MultilingualQuerySet, self).create(**kwargs)
line 348, in create
    obj.save(force_insert=True, using=self.db)
  File "/usr/lib/python2.7/dist-packages/polymorphic/models.py", line 74, in
save
    return super(PolymorphicModel, self).save(*args, **kwargs)
  File "/usr/local/lib/python2.7/dist-packages/django/db/models/base.py",
line 734, in save
    force_update=force_update, update_fields=update_fields)
line 771, in save_base
    update_fields=update_fields, raw=raw, using=using)
  File
"/usr/local/lib/python2.7/dist-packages/django/dispatch/dispatcher.py", line
189, in send
    response = receiver(signal=self, sender=sender, **named)
  File "/home/geo/geonode/geonode/catalogue/models.py", line 60, in
catalogue_post_save
    record = catalogue.get_record(instance.uuid)
  File "/home/geo/geonode/geonode/catalogue/backends/pycsw_local.py", line
75, in get_record
    results = self._csw_local_dispatch(identifier=uuid)
174, in _csw_local_dispatch
    response = csw.dispatch()
  File "/usr/lib/python2.7/dist-packages/pycsw/server.py", line 577, in
dispatch
    self.response = self.iface.getrecordbyid()
  File "/usr/lib/python2.7/dist-packages/pycsw/ogc/csw/csw2.py", line 1042,
in getrecordbyid
    results = self.parent.repository.query_ids(self.parent.kvp['id'])
Exception: ('Failed to process v_inmuebles', AttributeError("'Csw' object
has no attribute 'repository'",))
How can I solve it?
Thank you!
Abel Quesi
[its] Information Technology & Services
Mariano Moreno 746 Cuerpo 2 1° “A”– Lujan (CP: 6700)  Buenos Aires –
Argentina
+54-2323-435160 / 61 – Fax: +54-2323-435161
 <mailto:aquesi at itssaconsulting.com> aquesi at itssaconsulting.com -
www.itssaconsulting.com
Descripción: Descripción: C:\Users\aquesi\Documents\ISO_veritas_1.jpg
  _____
Este mensaje y sus adjuntos son confidenciales y de uso exclusivo para el
usuario de la dirección de correo electrónico a quien esta dirigido. Puede
contener información amparada por el secreto profesional. Si hubiese
recibido este mensaje por error, por favor informe tal situación al emisor,
devolviéndole el correo electrónico y eliminándolo de su sistema, no
pudiendo en tal caso copiar, enviar, revelar el contenido o utilizar alguna
parte de este mensaje o de sus adjuntos. No se garantiza la seguridad o la
exactitud de las comunicaciones por Internet debido a que la información
puede ser interceptada, modificada, perdida, llegar tarde o contener virus.
El emisor, por lo tanto, no acepta responsabilidad por errores u omisiones
en el texto de este mensaje que surjan a partir de una transmisión por
Internet.
  _____
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190104/4099eb75/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190104/4099eb75/attachment-0001.jpg>
More information about the geonode-users mailing list
