[GeoNode-users] GeoNode-Project local_settings
Toni Schönbuchner toni.schoenbuchner at csgis.de
Thu Jan 10 07:39:14 PST 2019
– I falsely looked at master!
thanks Alessio!
> Am 10.01.2019 um 16:30 schrieb Alessio Fabiani <alessio.fabiani at geo-solutions.it>:
> Dear all,
> currently I guess Julierme is getting that error because the "local_settings.py.sample" of 2.8 branch is wrong (see this line here https://github.com/GeoNode/geonode-project/blob/2.8/project_name/local_settings.py.sample#L44 <https://github.com/GeoNode/geonode-project/blob/2.8/project_name/local_settings.py.sample#L44> )
> If you take a look at it, it tries to use SITE_HOST_NAME variable before it is actually defined.
> The version of "master" branch (aka 2.10) should be correct instead
> https://github.com/GeoNode/geonode-project/blob/master/project_name/local_settings.py.sample <https://github.com/GeoNode/geonode-project/blob/master/project_name/local_settings.py.sample>
> Il giorno gio 10 gen 2019 alle ore 16:23 Toni Schönbuchner <toni.schoenbuchner at csgis.de <mailto:toni.schoenbuchner at csgis.de>> ha scritto:
> Really strange Julierme,
> SITEURL should be set by this env var in docker context:
> https://github.com/GeoNode/geonode-project/blob/master/docker-compose.override.yml#L17 <https://github.com/GeoNode/geonode-project/blob/master/docker-compose.override.yml#L17>
> and then read by:
>> os.getenv('SITEURL'
> Let´s wait what the other "dockernistas" think.
> – Francesco ;) ?
> Cheers;
> Toni
>> Am 10.01.2019 um 15:34 schrieb Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com <mailto:juliermeopensourcedeveloper at gmail.com>>:
>> Hi Toni,
>> Thank you very much for your reply and wishes.
>> Everything works fine, if I set wsgi.py to settings and do not make a copy of local_settings.py.sample as local_settings.py. That is how I got here:
>> http://192.241.135.159/ <http://192.241.135.159/>
>> However, if I set wsgi.py to settings (default configuration) and make a copy of local_settings.py.sample as local_settings.py. The celery and django container error remains:
>> celery4my_geonode |     SITEURL = os.getenv('SITEURL', "http://%s:%s/ <http://%s:%s/>" % (SITE_HOST_NAME, SITE_HOST_PORT))
>> celery4my_geonode | NameError: name 'SITE_HOST_NAME' is not defined
>> django4my_geonode |     SITEURL = os.getenv('SITEURL', "http://%s:%s/ <http://%s:%s/>" % (SITE_HOST_NAME, SITE_HOST_PORT))
>> django4my_geonode | NameError: name 'SITE_HOST_NAME' is not defined
>> The reason I am changing the wsgi.py to local_settings when using local_settings.py is because there is a note on the guide <https://github.com/GeoNode/geonode-project/tree/2.8> that it says:
>> Remember to update "wsgi.py" in case you are using "local_settings" vim my_geonode/wsgi.py --> os.environ.setdefault("DJANGO_SETTINGS_MODULE", "my_geonode.local_settings")
>> Anyway, using local_settings.py and configuring wsgi.py to either "my_geonode.settings" or "my_geonode.local_settings", celery and django container will not go up and the log file will return:
>> If you consider that an issue, I will post it on github.
>> Kind regards and thank you mery much for your patience
>> Julierme
>> On Thu, Jan 10, 2019 at 10:46 AM Toni Schönbuchner <toni.schoenbuchner at csgis.de <mailto:toni.schoenbuchner at csgis.de>> wrote:
>> Hey Julierme,
>> first of all the same to you.  All the best for 2019.
>> Docker sets some env vars where I do not have a complete
>> overview. Other might guide you better here.
>> But look at settings.py:
>> https://github.com/GeoNode/geonode-project/blob/master/project_name/settings.py#L27 <https://github.com/GeoNode/geonode-project/blob/master/project_name/settings.py#L27>
>> it includes local_settings ...
>> So, what happens if you leave wsgi.py untouched (pointing to settings.py), rename
>> local_settings.py.sample to local_settings.py (already happend) and make your changes
>> there (local_settings). F.e. setup your smtp account or base layers etc.
>> Does this help?
>> Cheers,
>> Toni
>> CSGIS
>> Kolonnadenstraße 1
>> 04109 Leipzig
>> Mobil	+49/ (0) 176 6680 3198
>> Tel 		+49/ (0) 341 24 04 738
>> Fax 		+49/ (0) 341 24 04 73
>> Web		http://csgis.de <http://csgis.de/>
>> Hinweis gemäß § 33 BDSG
>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist ausschließlich für den
>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie diese E-Mail versehentlich
>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und löschen Sie diese Nachricht
>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung, Vervielfältigung, Veränderung,
>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>>> Am 10.01.2019 um 13:33 schrieb Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com <mailto:juliermeopensourcedeveloper at gmail.com>>:
>>> Hi Toni,
>>> Thank you very much for your reply.
>>> Find bellow the site working with wsgi.py configured to settings
>>> Now, going back to the issue related to wsgi.py configured to local_settings:
>>> Yes, checking the logs, I found out that there is an issue with SITEURL. Please see bellow:
>>> SITE_HOST_NAME is defined after SITEURL. I changed from:
>>> # we need hostname for deployed
>>> _surl = urlparse(SITEURL)
>>> HOSTNAME = _surl.hostname
>>> # per-deployment settings should go here
>>> SITE_HOST_NAME = os.getenv('SITE_HOST_NAME', HOSTNAME)
>>> SITE_HOST_PORT = os.getenv('SITE_HOST_PORT', "80")
>>> To:
>>> #SITEURL = os.getenv('SITEURL', "http://%s:%s/ <http://%s:%s/>" % (SITE_HOST_NAME, SITE_HOST_PORT))
>>> #_surl = urlparse(SITEURL)
>>> #HOSTNAME = _surl.hostname
>>> SITE_HOST_NAME = os.getenv('SITE_HOST_NAME', "172.21.5.187")
>>> But the django4my_geonode and celery4my_geonode container error remains the same:
>>> I appreciated your time and by the way, Happy 2019 for you all. I wish you all health and success in all life projects.
>>> Kind regards
>>> Julierme
>>> On Wed, Jan 9, 2019 at 6:18 PM Toni Schönbuchner <toni.schoenbuchner at csgis.de <mailto:toni.schoenbuchner at csgis.de>> wrote:
>>> Hey Julierme,
>>> have you checked the output of logs?
>>> $ docker-compose logs -f
>>> or
>>> $ docker-compose logs -f django
>>> or
>>> $ docker-compose logs -f celery
>>> Cheers,
>>> Toni
>>> > Message: 1
>>> > Date: Wed, 9 Jan 2019 11:27:59 -0200
>>> > From: Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com <mailto:juliermeopensourcedeveloper at gmail.com>>
>>> > To: geonode-users <geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>>
>>> > Subject: [GeoNode-users] GeoNode-Project local_settings
>>> > Message-ID:
>>> >       <CAKTKyJJ_6KV9d=zikW9SAj6bybDCD+p8-XT7OuDZL7QxGxVVzw at mail.gmail.com <mailto:zikW9SAj6bybDCD%2Bp8-XT7OuDZL7QxGxVVzw at mail.gmail.com>>
>>> > Content-Type: text/plain; charset="utf-8"
>>> > Dear all,
>>> > I am running an Ubuntu 18.04 LTS VM. I am trying to install
>>> > GeoNode-Project at 2.8 via Docker following the instructions in here.
>>> > <https://github.com/GeoNode/geonode-project/tree/2.8 <https://github.com/GeoNode/geonode-project/tree/2.8>>
>>> > By changing wsgi.py to local_settings, celery4my_geonode and
>>> > django4my_geonode won't start and I am always getting the *502 Bad Gateway*
>>> > response in the browser.
>>> > Has anyone faced the same issue and could guide me on how to solve it?
>>> > Thank you for your time in advance
>>> > Regards
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users <https://lists.osgeo.org/mailman/listinfo/geonode-users>
> GeoServer Professional Services from the experts! Visit http://goo.gl/it488V <http://goo.gl/it488V> for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it <http://www.geo-solutions.it/>
> http://twitter.com/geosolutions_it <http://twitter.com/geosolutions_it>
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190110/9dc0b2af/attachment-0001.html>
More information about the geonode-users mailing list
