[GeoNode-users] GeoNode-Project Docker Postgres Access
Julierme Pinheiro
juliermeopensourcedeveloper at gmail.com
Mon Jan 14 06:30:49 PST 2019
Regarding my previous questions:
1 - When installing geonode-project via docker, is postgres configuration
set automatically as in here
<http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/create_geonode_db.html>
I think so. Because I found all the databases and user configured into
db4my_geonode container.
2 - Could the error in the log file (geonode-project server 172.21.14.02)
be related to pg_hba.conf file (local connections)?
I do not think so. Because looking at /var/lib/postgresql/data/pg_hba.conf
in db4my_geonode, the cofiguration is set as:
local all all trust
Within these two answers I should not have gotten any problem by
configuring HOST: '172.21.14.02' in local_settings / DATABASES: {...}
I am still thinking about question 3:
Is there any postgres (db4my_geonode container) configuration in
geonode-project server 172.21.14.02 that I must do, before using it as HOST
value in local_settings / DATABASES = {...}?
Thank you for your time in advance
Kind regards
Julierme
On Mon, Jan 14, 2019 at 12:01 PM Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> wrote:
> Deal all,
> This is not an issue, but a question regarding postgres configuration in
> GeoNode-Project Docker installation.
> I have 2 servers and 1 client server.
> Server 1: postgres server - IP: 172.21.14.01
> I installed postgres in Server 1 (172.21.14.01) and I configured postgres
> as in here
> <http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/create_geonode_db.html>.
> I created in postgres:
> a user: geonode with password osgeo;
> a db: geonode owned by geonode user;
> a db: geonode_data owned by geonode user;
> and so on.
> Server 2 (CentOS7): geonode-project server - IP: 172.21.14.02
> I installed geonode-project at 2.8 via Docker in server 2 and changed
> localhost to 172.21.14.02 in docker-compose.override.yml file in order to
> access the geonode site from the client server.
> Client server: my_workstation - IP: 172.21.14.03
> GeoNode-Project installation via Docker is successful if I change
> localhost to 172.21.14.01 (postgres remote server) as in:
> # Backend
> DATABASES = {
> 'default': {
> 'ENGINE': 'django.db.backends.postgresql_psycopg2',
> 'NAME': 'geonode',
> 'USER': 'geonode',
> 'PASSWORD': 'geonode',
> 'HOST': '172.21.14.01',
> 'PORT': '5432',
> 'CONN_TOUT': 900,
> # vector datastore for uploads
> 'datastore': {
> 'ENGINE': 'django.contrib.gis.db.backends.postgis',
> # 'ENGINE': '', # Empty ENGINE name disables
> 'NAME': 'geonode_data',
> 'USER': 'geonode',
> 'PORT': '5432',
> 'CONN_TOUT': 900,
> However if I configure HOST:'172.21.14.02' or HOST: 'localhost',
> geonode-project django and celery container will not go up and the log file
> says respectively for HOST:'172.21.14.02' and HOST: 'localhost'
> configuration:
> django4my_geonode | Is the server running on host "172.21.14.45" and
> accepting
> django4my_geonode | TCP/IP connections on port 5432?
> django4my_geonode | Is the server running on host "localhost" (::1)
> and accepting
> Though geonode-project installation is successful, by using postgres
> remote server IP: 172.21.14.01, configured manually, I do not want to use
> it.
> I want to use geonode-project server IP:172.21.14.02. Said that, I came
> out with the following questions:
> 3 - Is there any postgres (geonode/postgis container) configuration in
> My apologies for the long e-mail and thank you very much for your time and
> patience.
> Kind regards
> Julierme
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190114/79e7f114/attachment.html>
More information about the geonode-users
