[GeoNode-users] GeoNode-Project Docker Postgres Access
Francesco Bartoli
xbartolone at gmail.com
Mon Jan 14 07:22:02 PST 2019
Hi Julierme,
Where are you trying to run the test? Is the container related to the service “db” running? What’s the output of docker-compose ps?
Il 14 gen 2019, 16:09 +0100, Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com>, ha scritto:
> Trying to answer question 3, I ran a test:
> psql -h 172.21.14.02 -U geonode -d geonode
> psql: could not connect to server: No route to host
> Is the server running on host "172.21.14.02" and accepting
> TCP/IP connections on port 5432?
> Though /var/lib/postgresql/data/pg_hba.conf is set to trust (see bellow), I can not understand why the connection to postgres is not successful.
> local all all trust
> Any comment on this matter will be very appreciated.
> Kind regards
> Julierme
> > On Mon, Jan 14, 2019 at 12:30 PM Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com> wrote:
> > > Regarding my previous questions:
> > > 1 - When installing geonode-project via docker, is postgres configuration set automatically as in here?
> > > I think so. Because I found all the databases and user configured into db4my_geonode container.
> > > 2 - Could the error in the log file (geonode-project server 172.21.14.02) be related to pg_hba.conf file (local connections)?
> > > I do not think so. Because looking at /var/lib/postgresql/data/pg_hba.conf in db4my_geonode, the cofiguration is set as:
> > > local all all trust
> > > Within these two answers I should not have gotten any problem by configuring HOST: '172.21.14.02' in local_settings / DATABASES: {...}
> > > I am still thinking about question 3:
> > > Is there any postgres (db4my_geonode container) configuration in geonode-project server 172.21.14.02 that I must do, before using it as HOST value in local_settings / DATABASES = {...}?
> > > Thank you for your time in advance
> > > Kind regards
> > > Julierme
> > > > On Mon, Jan 14, 2019 at 12:01 PM Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com> wrote:
> > > > > Deal all,
> > > > > This is not an issue, but a question regarding postgres configuration in GeoNode-Project Docker installation.
> > > > > I have 2 servers and 1 client server.
> > > > > Server 1: postgres server - IP: 172.21.14.01
> > > > > I installed postgres in Server 1 (172.21.14.01) and I configured postgres as in here. I created in postgres:
> > > > > a user: geonode with password osgeo;
> > > > > a db: geonode owned by geonode user;
> > > > > a db: geonode_data owned by geonode user;
> > > > > and so on.
> > > > > Server 2 (CentOS7): geonode-project server - IP: 172.21.14.02
> > > > > I installed geonode-project at 2.8 via Docker in server 2 and changed localhost to 172.21.14.02 in docker-compose.override.yml file in order to access the geonode site from the client server.
> > > > > Client server: my_workstation - IP: 172.21.14.03
> > > > > GeoNode-Project installation via Docker is successful if I change localhost to 172.21.14.01 (postgres remote server) as in:
> > > > > # Backend
> > > > > DATABASES = {
> > > > > 'default': {
> > > > > 'ENGINE': 'django.db.backends.postgresql_psycopg2',
> > > > > 'NAME': 'geonode',
> > > > > 'USER': 'geonode',
> > > > > 'PASSWORD': 'geonode',
> > > > > 'HOST': '172.21.14.01',
> > > > > 'PORT': '5432',
> > > > > 'CONN_TOUT': 900,
> > > > > # vector datastore for uploads
> > > > > 'datastore': {
> > > > > 'ENGINE': 'django.contrib.gis.db.backends.postgis',
> > > > > # 'ENGINE': '', # Empty ENGINE name disables
> > > > > 'NAME': 'geonode_data',
> > > > > 'USER': 'geonode',
> > > > > 'PORT': '5432',
> > > > > 'CONN_TOUT': 900,
> > > > > However if I configure HOST:'172.21.14.02' or HOST: 'localhost', geonode-project django and celery container will not go up and the log file says respectively for HOST:'172.21.14.02' and HOST: 'localhost' configuration:
> > > > > django4my_geonode | Is the server running on host "172.21.14.45" and accepting
> > > > > django4my_geonode | TCP/IP connections on port 5432?
> > > > > django4my_geonode | Is the server running on host "localhost" (::1) and accepting
> > > > > Though geonode-project installation is successful, by using postgres remote server IP: 172.21.14.01, configured manually, I do not want to use it.
> > > > > I want to use geonode-project server IP:172.21.14.02. Said that, I came out with the following questions:
> > > > > 3 - Is there any postgres (geonode/postgis container) configuration in geonode-project server 172.21.14.02 that I must do, before using it as HOST value in local_settings / DATABASES = {...}?
> > > > > My apologies for the long e-mail and thank you very much for your time and patience.
> > > > > Kind regards
> > > > > Julierme
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190114/e32f6912/attachment.html>
More information about the geonode-users
