[GeoNode-users] Migrating from GeoNode 2.4.1 to 2.10.x
Francesco Bartoli
xbartolone at gmail.com
Mon Jan 14 13:38:57 PST 2019
It sounds strange but something definitively to figure out what is responsible of this weird behavior. I guess the source epsg was different.
Can you check if the same behavior would happen by using only the pg_dump utility?
Ciao
Francesco
Il 14 gen 2019, 22:08 +0100, Paolo Pasquali <paolo.pasquali at gmail.com>, ha scritto:
> Ciao Francesco,
> The upload works.
> But I've found a clue.
> If I try to manually publish from GeoServer each layer that needs to migrated it seems that all have a weird EPSG (EPSG:404000).
> I've used pg_dumpall. Is it possible that something went wrong? The postgis version?
> Thanks!
> P.
> > On Mon, Jan 14, 2019 at 9:46 PM Francesco Bartoli <xbartolone at gmail.com> wrote:
> > > Ciao Paolo,
> > > Apart the data you are trying to migrate does the normal upload form work if you try with a shapefile?
> > > Francesco
> > > Il 14 gen 2019, 18:41 +0100, Paolo Pasquali <paolo.pasquali at gmail.com>, ha scritto:
> > > > Dear all,
> > > > I'm trying to migrate my data from an old 2.4.1 to the latest GeoNode.
> > > > I've followed the documentation by Olivier Dalang (very helpful, thanks!) [1] and adapted to my docker installation [2].
> > > > I'm almost there, but while all my raster layers are ok (except some minor issue), the vector layers are present in GeoNode but not published by GeoServer. Although the datastore in GeoServer seems properly configured to connect to PostGIS no vector layer is published.
> > > > I'm missing something...
> > > > Thanks for your help!
> > > > Best,
> > > > Paolo
> > > > [1] https://github.com/olivierdalang/SPCgeonode#how-to-migrate-from-an-existing-standard-geonode-install
> > > > [2] https://github.com/ppasq/masdap/wiki/Migration
> > > > _______________________________________________
> > > > geonode-users mailing list
> > > > geonode-users at lists.osgeo.org
> > > > https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190114/5784f118/attachment.html>
More information about the geonode-users
