[GeoNode-users] GeoNode-Project Docker Postgres Access
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Mon Jan 14 13:44:37 PST 2019
... Regarding my previous email, I configured wsgi.py as
"my_geonode.settings", though I am using local_settings and the issue
remains.
Kind regards
Julierme
On Mon, Jan 14, 2019 at 7:35 PM Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> wrote:
> Hi Francesco,
> I went through step 4 and 5 because there is note on the guide(
> https://github.com/GeoNode/geonode-project/tree/2.8): that says:
> Run docker-compose to start it up (get a cup of coffee or tea while you
> wait)
> *2 - Remember to update "wsgi.py" in case you are using "local_settings"
> vim my_geonode/wsgi.py --> os.environ.setdefault("DJANGO_SETTINGS_MODULE",
> "my_geonode.local_settings")*
> I appreciated your time
> Julierme
> On Mon, Jan 14, 2019 at 7:28 PM Francesco Bartoli <xbartolone at gmail.com>
> wrote:
>> Actually I don’t understand why you are doing steps 4. And 5.
>> Ciao
>> Francesco
>> Il 14 gen 2019, 22:05 +0100, Julierme Pinheiro <
>> juliermeopensourcedeveloper at gmail.com>, ha scritto:
>> ... output for docker ps:
>> 0edbae6e9989        geonode/nginx:geoserver    "nginx -g 'daemon of…"   6
>> minutes ago       Up 6 minutes                    0.0.0.0:80->80/tcp
>> nginx4my_geonode
>> f71aed729615        my_geonode_django          "/usr/src/my_geonode…"   6
>> minutes ago       Restarting (1) 21 seconds
>> ago                                        django4my_geonode
>> d1307b6eca5a        my_geonode_celery          "/usr/src/my_geonode…"   6
>> minutes ago       Restarting (1) 59 seconds
>> ago                                        celery4my_geonode
>> 9865b9317a98        geonode/geoserver:2.13.x   "/usr/local/tomcat/t…"   6
>> 8080/tcp                             geoserver4my_geonode
>> b63b3eed5560        geonode/postgis:9.6        "docker-entrypoint.s…"
>> 16 minutes ago      Up 6 minutes
>> 5432/tcp                             db4my_geonode
>> c70325c1f57e        elasticsearch:2.4.1        "/docker-entrypoint.…"
>> 16 minutes ago      Up 6 minutes                    9200/tcp,
>> 9300/tcp                   elasticsearch4my_geonode
>> 4412fd012ca9        rabbitmq                   "docker-entrypoint.s…"
>> 16 minutes ago      Up 6 minutes                    4369/tcp,
>> 5671-5672/tcp, 25672/tcp   rabbitmq4my_geonode
>> and out put for docker-compose ps
>> celery4my_geonode          /usr/src/my_geonode/entryp ...
>> Restarting
>> db4my_geonode              docker-entrypoint.sh postgres    Up
>> 5432/tcp
>> django4my_geonode          /usr/src/my_geonode/entryp ...
>> Restarting
>> elasticsearch4my_geonode   /docker-entrypoint.sh elas ...   Up
>> 9200/tcp, 9300/tcp
>> geoserver4my_geonode       /usr/local/tomcat/tmp/entr ...   Up
>> 8080/tcp
>> gsconf4my_geonode          /bin/true                        Exit
>> 0
>> nginx4my_geonode           nginx -g daemon off;             Up
>> 0.0.0.0:80->80/tcp
>> rabbitmq4my_geonode        docker-entrypoint.sh rabbi ...   Up
>> 25672/tcp, 4369/tcp, 5671/tcp, 5672/tcp
>> Kind Regards
>> Julierme
>> On Mon, Jan 14, 2019 at 7:02 PM Julierme Pinheiro <
>>> Hi Francesco,
>>> Thank you very much for  your reply. After our discussion in here. I
>>> started all over again and I will report the installation step by step.
>>> 1 - docker-compose down
>>> 2 - docker system prune -a
>>> 3 - docker-compose.override.yml is in its default pattern
>>> version: '2'
>>> services:
>>>   django:
>>>     environment:
>>>       DEBUG: 'True'
>>>       GEONODE_LB_HOST_IP: localhost
>>>       GEONODE_LB_PORT: 80
>>>       SITEURL: http://localhost/
>>>       ALLOWED_HOSTS: "['localhost']"
>>>       GEOSERVER_PUBLIC_LOCATION: http://localhost/geoserver/
>>>   celery:
>>>     environment:
>>>       DEBUG: 'True'
>>>       GEONODE_LB_PORT: 80
>>>   geoserver:
>>>     environment:
>>>       GEONODE_LB_PORT: 80
>>>       NGINX_BASE_URL:
>>> 4 - cp ...my_geonode/local_settings.py.sample my_geonode/local_settings.py
>>> 5 - vim ... my_geonode/wsgi.py
>>> os.environ.setdefault("DJANGO_SETTINGS_MODULE", "my_geonode.local_settings")
>>> 6 - docker-compose build --no-cache
>>> 7 - docker-compose up -d
>>> 8 - docker-compose stop
>>> 9 - vim docker-compose.override.yml
>>> version: '2'
>>> services:
>>>   django:
>>>     environment:
>>>       DEBUG: 'True'
>>>       GEONODE_LB_HOST_IP: 172.21.14.02
>>>       GEONODE_LB_PORT: 80
>>>       SITEURL: http://172.21.14.02/
>>>       ALLOWED_HOSTS: "['172.21.14.02']"
>>>       GEOSERVER_PUBLIC_LOCATION: http://172.21.14.02/geoserver/
>>>   celery:
>>>     environment:
>>>       DEBUG: 'True'
>>>       GEONODE_LB_PORT: 80
>>>   geoserver:
>>>     environment:
>>>       GEONODE_LB_PORT: 80
>>>       NGINX_BASE_URL:
>>> 10 - docker-compose up --build -d
>>> 11 - docker ps
>>> 12 - docker-compose ps
>>> 13 - docker-compose logs -f django
>>> django4my_geonode | django.db.utils.OperationalError: could not connect to server: Connection refused
>>> django4my_geonode |  Is the server running on host "localhost" (127.0.0.1) and accepting
>>> django4my_geonode |    TCP/IP connections on port 5432?
>>> django4my_geonode | could not connect to server: Network is unreachable
>>> django4my_geonode |      Is the server running on host "localhost" (::1) and accepting
>>> 14 - docker-compose logs -f celery
>>> celery4my_geonode | django.db.utils.OperationalError: could not connect to server: Connection refused
>>> celery4my_geonode |   Is the server running on host "localhost" (127.0.0.1) and accepting
>>> celery4my_geonode |    TCP/IP connections on port 5432?
>>> celery4my_geonode | could not connect to server: Network is unreachable
>>> celery4my_geonode |      Is the server running on host "localhost" (::1) and accepting
>>> I am still having the issue related to database connection.
>>> Kind regards
>>> Julierme
>>> On Mon, Jan 14, 2019 at 3:51 PM Francesco Bartoli <xbartolone at gmail.com>
>>> wrote:
>>>> Some questions inline to figure out your environment.
>>>> Il 14 gen 2019, 18:26 +0100, Julierme Pinheiro <
>>>> Hi Francesco,
>>>> I changed the docker-compose.override.yml from localhost to
>>>> 172.21.14.02 (Centos7 VM IP running GeoNode-Project installed via docker).
>>>> After doing that, geonode django and celery container logs point to the
>>>> error:
>>>> to server: No route to host
>>>> and accepting
>>>> Trying to solve this issue, as localhost corresponds to 172.21.14.02, I
>>>> went to local_settings and changed from DATABASES: { HOST: 'localhost' ,
>>>> to  DATABASES: { HOST: '172.21.14.02'}, geonode django and celery container
>>>> logs point to the error:
>>>> django4my_geonode |     Is the server running on host "172.21.14.02"
>>>> and accepting
>>>> The error remains the same.
>>>> Yes. db4my_geonode is up and running. And find bellow the outcome for
>>>> docker-compose ps:
>>>> Restarting
>>>> Up           5432/tcp
>>>> Restarting
>>>> Up           9200/tcp, 9300/tcp
>>>> Up           8080/tcp
>>>> 0
>>>> Up           0.0.0.0:80->80/tcp
>>>> Up           25672/tcp, 4369/tcp, 5671/tcp, 5672/tcp
>>>> In order to access geonode site from my workstation, I am supposed to
>>>> configure DATABASES as HOST:'172.21.14.02'. Am I correct? If so, why the
>>>> database connection has been refused?
>>>> Just to avoid confusion here. If your host where you want to navigate
>>>> GeoNode is 172.21.14.02 then your docker-compose override yaml file should
>>>> look like:
>>>> version: '2'
>>>> services:
>>>> django:
>>>> environment:
>>>> DEBUG: 'True'
>>>> GEONODE_LB_PORT: 80
>>>> celery:
>>>> environment:
>>>> DEBUG: 'True'
>>>> GEONODE_LB_PORT: 80
>>>> geoserver:
>>>> environment:
>>>> GEONODE_LB_PORT: 80
>>>> NGINX_BASE_URL:
>>>> Talking to some IT colleagues, they said that I may be having problem
>>>> because, the geonode server IP (172.21.14.02) is in our network, however
>>>> db4my_geonode container IP 172.27.0.6 is out of our network. But as
>>>> docker-compose ps showed the server 172.21.14.02, port 5432 is being used
>>>> by db4my_geonode container. I can not really figure out what is going
>>>> on!!!!
>>>> Given that configuration the database container has a different network
>>>> address because it is running on the internal network established by
>>>> docker. Therefore from your host machine, I mean the CentOS, it is correct
>>>> that you are not allowed to reach the db container. If you want to reach
>>>> that you have to run your psql within the django container in such a way:
>>>> psql -h db -U geonode -d geonode (please note that the hostname is
>>>> right the service name given in the docker-compose file ;) )
>>>> Any help on that will be very appreciated.
>>>> Kind regards
>>>> Julierme
>>>> Hope this helps
>>>> On Mon, Jan 14, 2019 at 1:22 PM Francesco Bartoli <xbartolone at gmail.com>
>>>> wrote:
>>>>> Hi Julierme,
>>>>> Where are you trying to run the test? Is the  container related to the
>>>>> service “db” running? What’s the output of docker-compose ps?
>>>>> Il 14 gen 2019, 16:09 +0100, Julierme Pinheiro <
>>>>> Trying to answer question 3, I ran a test:
>>>>> psql -h 172.21.14.02 -U geonode -d geonode
>>>>> psql: could not connect to server: No route to host
>>>>>     Is the server running on host "172.21.14.02" and accepting
>>>>> Though /var/lib/postgresql/data/pg_hba.conf is set to trust (see
>>>>> bellow), I can not understand why the connection to postgres is not
>>>>> successful.
>>>>> local   all             all                                     trust
>>>>> Any comment on this matter will be very appreciated.
>>>>> Kind regards
>>>>> Julierme
>>>>> On Mon, Jan 14, 2019 at 12:30 PM Julierme Pinheiro <
>>>>>> Regarding my previous questions:
>>>>>> 1 - When installing geonode-project via docker, is postgres
>>>>>> configuration set automatically as in here
>>>>>> <http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/create_geonode_db.html>
>>>>>> I think so. Because I found all the databases and user configured
>>>>>> into db4my_geonode container.
>>>>>> 2 - Could the error in the log file (geonode-project server
>>>>>> 172.21.14.02) be related to  pg_hba.conf file (local connections)?
>>>>>> I do not think so. Because looking at
>>>>>> /var/lib/postgresql/data/pg_hba.conf  in db4my_geonode, the cofiguration is
>>>>>> set as:
>>>>>> local   all             all                                     trust
>>>>>> Within these two answers I should not have gotten any problem by
>>>>>> configuring HOST: '172.21.14.02' in local_settings / DATABASES: {...}
>>>>>> I am still thinking about question 3:
>>>>>> Is there any postgres (db4my_geonode container) configuration in
>>>>>> geonode-project server 172.21.14.02 that I must do, before using it as HOST
>>>>>> value in local_settings / DATABASES = {...}?
>>>>>> Thank you for your time in advance
>>>>>> Kind regards
>>>>>> Julierme
>>>>>> On Mon, Jan 14, 2019 at 12:01 PM Julierme Pinheiro <
>>>>>>> Deal all,
>>>>>>> This is not an issue, but a question regarding postgres
>>>>>>> configuration in GeoNode-Project Docker installation.
>>>>>>> I have 2 servers and 1 client server.
>>>>>>> Server 1: postgres server - IP: 172.21.14.01
>>>>>>>  I installed postgres in Server 1 (172.21.14.01) and I configured
>>>>>>> postgres as in here
>>>>>>> <http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/create_geonode_db.html>.
>>>>>>> I created in postgres:
>>>>>>> a user: geonode with password osgeo;
>>>>>>> a db: geonode owned by geonode user;
>>>>>>> a db: geonode_data owned by geonode user;
>>>>>>> and so on.
>>>>>>> Server 2 (CentOS7): geonode-project server - IP: 172.21.14.02
>>>>>>> I installed geonode-project at 2.8 via Docker in server 2 and changed
>>>>>>> localhost to 172.21.14.02 in docker-compose.override.yml file in order to
>>>>>>> access the geonode site from the client server.
>>>>>>> Client server: my_workstation - IP: 172.21.14.03
>>>>>>> GeoNode-Project installation via Docker is successful if I change
>>>>>>> localhost to 172.21.14.01 (postgres remote server) as in:
>>>>>>> # Backend
>>>>>>> DATABASES = {
>>>>>>>     'default': {
>>>>>>>         'ENGINE': 'django.db.backends.postgresql_psycopg2',
>>>>>>>         'NAME': 'geonode',
>>>>>>>         'USER': 'geonode',
>>>>>>>         'PASSWORD': 'geonode',
>>>>>>>         'HOST': '172.21.14.01',
>>>>>>>         'PORT': '5432',
>>>>>>>         'CONN_TOUT': 900,
>>>>>>>     # vector datastore for uploads
>>>>>>>     'datastore': {
>>>>>>>         'ENGINE': 'django.contrib.gis.db.backends.postgis',
>>>>>>>         # 'ENGINE': '', # Empty ENGINE name disables
>>>>>>>         'NAME': 'geonode_data',
>>>>>>>         'USER': 'geonode',
>>>>>>>         'PORT': '5432',
>>>>>>>         'CONN_TOUT': 900,
>>>>>>> However if I configure HOST:'172.21.14.02' or HOST: 'localhost',
>>>>>>> geonode-project django and celery container will not go up and the log file
>>>>>>> says respectively for HOST:'172.21.14.02' and HOST: 'localhost'
>>>>>>> configuration:
>>>>>>> django4my_geonode |     Is the server running on host "172.21.14.45"
>>>>>>> and accepting
>>>>>>> (::1) and accepting
>>>>>>> Though geonode-project installation is successful, by using postgres
>>>>>>> remote server IP: 172.21.14.01, configured manually, I do not want to use
>>>>>>> it.
>>>>>>> I want to use geonode-project server IP:172.21.14.02.  Said that, I
>>>>>>> came out with  the following questions:
>>>>>>> 3 - Is there any postgres (geonode/postgis container) configuration
>>>>>>> in geonode-project server 172.21.14.02 that I must do, before using it as
>>>>>>> HOST value in local_settings / DATABASES = {...}?
>>>>>>> My apologies for the long e-mail and thank you very much for your
>>>>>>> time and patience.
>>>>>>> Kind regards
>>>>>>> Julierme
>>>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190114/f7ec2fef/attachment-0001.html>
More information about the geonode-users mailing list
