[GeoNode-users] GeoNode-Project Docker Postgres Access
Francesco Bartoli
xbartolone at gmail.com
Tue Jan 15 04:19:47 PST 2019
glad you solved
Ciao
Francesco
Il 15 gen 2019, 13:09 +0100, Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com>, ha scritto:
> Hi Francesco,
> I got it. I do not know if makes sense. GeoNode-Project at 2.7 had HOST:'db' in its local_settings. In my case, in order to have GeoNode -Project working after setting docker-compose.override.yml to 172.21.14.02, I had to change from HOST: 'localhost' to HOST: 'db'.Now, it is working.
> I appreciated your time and patience
> Kind regards
> Julierme
> > On Mon, Jan 14, 2019 at 7:46 PM Francesco Bartoli <xbartolone at gmail.com> wrote:
> > > Right but I believe that is optional, and if applied you have to make sure to understand what are the consequences in overriding some variables of base settings.
> > > Ciao
> > > Francesco
> > > Il 14 gen 2019, 22:35 +0100, Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com>, ha scritto:
> > > > Hi Francesco,
> > > > I went through step 4 and 5 because there is note on the guide(https://github.com/GeoNode/geonode-project/tree/2.8): that says:
> > > > Run docker-compose to start it up (get a cup of coffee or tea while you wait)
> > > > 2 - Remember to update "wsgi.py" in case you are using "local_settings" vim my_geonode/wsgi.py --> os.environ.setdefault("DJANGO_SETTINGS_MODULE", "my_geonode.local_settings")
> > > > Julierme
> > > > > On Mon, Jan 14, 2019 at 7:28 PM Francesco Bartoli <xbartolone at gmail.com> wrote:
> > > > > > Actually I don’t understand why you are doing steps 4. And 5.
> > > > > > Ciao
> > > > > > Francesco
> > > > > > Il 14 gen 2019, 22:05 +0100, Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com>, ha scritto:
> > > > > > > ... output for docker ps:
> > > > > > > 0edbae6e9989 geonode/nginx:geoserver "nginx -g 'daemon of…" 6 minutes ago Up 6 minutes 0.0.0.0:80->80/tcp nginx4my_geonode
> > > > > > > f71aed729615 my_geonode_django "/usr/src/my_geonode…" 6 minutes ago Restarting (1) 21 seconds ago django4my_geonode
> > > > > > > d1307b6eca5a my_geonode_celery "/usr/src/my_geonode…" 6 minutes ago Restarting (1) 59 seconds ago celery4my_geonode
> > > > > > > 9865b9317a98 geonode/geoserver:2.13.x "/usr/local/tomcat/t…" 6 minutes ago Up 6 minutes 8080/tcp geoserver4my_geonode
> > > > > > > b63b3eed5560 geonode/postgis:9.6 "docker-entrypoint.s…" 16 minutes ago Up 6 minutes 5432/tcp db4my_geonode
> > > > > > > c70325c1f57e elasticsearch:2.4.1 "/docker-entrypoint.…" 16 minutes ago Up 6 minutes 9200/tcp, 9300/tcp elasticsearch4my_geonode
> > > > > > > 4412fd012ca9 rabbitmq "docker-entrypoint.s…" 16 minutes ago Up 6 minutes 4369/tcp, 5671-5672/tcp, 25672/tcp rabbitmq4my_geonode
> > > > > > > and out put for docker-compose ps
> > > > > > > celery4my_geonode /usr/src/my_geonode/entryp ... Restarting
> > > > > > > db4my_geonode docker-entrypoint.sh postgres Up 5432/tcp
> > > > > > > django4my_geonode /usr/src/my_geonode/entryp ... Restarting
> > > > > > > elasticsearch4my_geonode /docker-entrypoint.sh elas ... Up 9200/tcp, 9300/tcp
> > > > > > > geoserver4my_geonode /usr/local/tomcat/tmp/entr ... Up 8080/tcp
> > > > > > > gsconf4my_geonode /bin/true Exit 0
> > > > > > > nginx4my_geonode nginx -g daemon off; Up 0.0.0.0:80->80/tcp
> > > > > > > rabbitmq4my_geonode docker-entrypoint.sh rabbi ... Up 25672/tcp, 4369/tcp, 5671/tcp, 5672/tcp
> > > > > > > Kind Regards
> > > > > > > Julierme
> > > > > > > > On Mon, Jan 14, 2019 at 7:02 PM Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com> wrote:
> > > > > > > > > Hi Francesco,
> > > > > > > > > Thank you very much for your reply. After our discussion in here. I started all over again and I will report the installation step by step.
> > > > > > > > > 1 - docker-compose down
> > > > > > > > > 2 - docker system prune -a
> > > > > > > > > 3 - docker-compose.override.yml is in its default pattern
> > > > > > > > > version: '2'
> > > > > > > > > services:
> > > > > > > > > django:
> > > > > > > > > environment:
> > > > > > > > > DEBUG: 'True'
> > > > > > > > > GEONODE_LB_HOST_IP: localhost
> > > > > > > > > GEONODE_LB_PORT: 80
> > > > > > > > > SITEURL: http://localhost/
> > > > > > > > > ALLOWED_HOSTS: "['localhost']"
> > > > > > > > > GEOSERVER_PUBLIC_LOCATION: http://localhost/geoserver/
> > > > > > > > > celery:
> > > > > > > > > environment:
> > > > > > > > > DEBUG: 'True'
> > > > > > > > > GEONODE_LB_PORT: 80
> > > > > > > > > geoserver:
> > > > > > > > > environment:
> > > > > > > > > GEONODE_LB_PORT: 80
> > > > > > > > > NGINX_BASE_URL:
> > > > > > > > > 4 - cp ...my_geonode/local_settings.py.sample my_geonode/local_settings.py
> > > > > > > > > 5 - vim ... my_geonode/wsgi.py
> > > > > > > > > 6 - docker-compose build --no-cache
> > > > > > > > > 7 - docker-compose up -d
> > > > > > > > > 8 - docker-compose stop
> > > > > > > > > 9 - vim docker-compose.override.yml
> > > > > > > > > version: '2'
> > > > > > > > > services:
> > > > > > > > > django:
> > > > > > > > > environment:
> > > > > > > > > DEBUG: 'True'
> > > > > > > > > GEONODE_LB_HOST_IP: 172.21.14.02
> > > > > > > > > GEONODE_LB_PORT: 80
> > > > > > > > > SITEURL: http://172.21.14.02/
> > > > > > > > > ALLOWED_HOSTS: "['172.21.14.02']"
> > > > > > > > > GEOSERVER_PUBLIC_LOCATION: http://172.21.14.02/geoserver/
> > > > > > > > > celery:
> > > > > > > > > environment:
> > > > > > > > > DEBUG: 'True'
> > > > > > > > > GEONODE_LB_PORT: 80
> > > > > > > > > geoserver:
> > > > > > > > > environment:
> > > > > > > > > GEONODE_LB_PORT: 80
> > > > > > > > > NGINX_BASE_URL:
> > > > > > > > > 10 - docker-compose up --build -d
> > > > > > > > > 11 - docker ps
> > > > > > > > > 12 - docker-compose ps
> > > > > > > > > 13 - docker-compose logs -f django
> > > > > > > > > django4my_geonode | django.db.utils.OperationalError: could not connect to server: Connection refused
> > > > > > > > > django4my_geonode | Is the server running on host "localhost" (127.0.0.1) and accepting
> > > > > > > > > django4my_geonode | TCP/IP connections on port 5432?
> > > > > > > > > django4my_geonode | could not connect to server: Network is unreachable
> > > > > > > > > django4my_geonode | Is the server running on host "localhost" (::1) and accepting
> > > > > > > > > 14 - docker-compose logs -f celery
> > > > > > > > > celery4my_geonode | django.db.utils.OperationalError: could not connect to server: Connection refused
> > > > > > > > > celery4my_geonode | Is the server running on host "localhost" (127.0.0.1) and accepting
> > > > > > > > > celery4my_geonode | TCP/IP connections on port 5432?
> > > > > > > > > celery4my_geonode | could not connect to server: Network is unreachable
> > > > > > > > > celery4my_geonode | Is the server running on host "localhost" (::1) and accepting
> > > > > > > > > I am still having the issue related to database connection.
> > > > > > > > > Kind regards
> > > > > > > > > Julierme
> > > > > > > > > > On Mon, Jan 14, 2019 at 3:51 PM Francesco Bartoli <xbartolone at gmail.com> wrote:
> > > > > > > > > > > Some questions inline to figure out your environment.
> > > > > > > > > > > Il 14 gen 2019, 18:26 +0100, Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com>, ha scritto:
> > > > > > > > > > > > Hi Francesco,
> > > > > > > > > > > > I changed the docker-compose.override.yml from localhost to 172.21.14.02 (Centos7 VM IP running GeoNode-Project installed via docker). After doing that, geonode django and celery container logs point to the error:
> > > > > > > > > > > > django4my_geonode | django.db.utils.OperationalError: could not connect to server: No route to host
> > > > > > > > > > > > Trying to solve this issue, as localhost corresponds to 172.21.14.02, I went to local_settings and changed from DATABASES: { HOST: 'localhost' , to DATABASES: { HOST: '172.21.14.02'}, geonode django and celery container logs point to the error:
> > > > > > > > > > > > django4my_geonode | Is the server running on host "172.21.14.02" and accepting
> > > > > > > > > > > > The error remains the same.
> > > > > > > > > > > > Yes. db4my_geonode is up and running. And find bellow the outcome for docker-compose ps:
> > > > > > > > > > > > In order to access geonode site from my workstation, I am supposed to configure DATABASES as HOST:'172.21.14.02'. Am I correct? If so, why the database connection has been refused?
> > > > > > > > > > > Just to avoid confusion here. If your host where you want to navigate GeoNode is 172.21.14.02 then your docker-compose override yaml file should look like:
> > > > > > > > > > > version: '2'
> > > > > > > > > > > services:
> > > > > > > > > > > django:
> > > > > > > > > > > environment:
> > > > > > > > > > > DEBUG: 'True'
> > > > > > > > > > > GEONODE_LB_PORT: 80
> > > > > > > > > > > celery:
> > > > > > > > > > > environment:
> > > > > > > > > > > DEBUG: 'True'
> > > > > > > > > > > GEONODE_LB_PORT: 80
> > > > > > > > > > > geoserver:
> > > > > > > > > > > environment:
> > > > > > > > > > > GEONODE_LB_PORT: 80
> > > > > > > > > > > NGINX_BASE_URL:
> > > > > > > > > > > > Talking to some IT colleagues, they said that I may be having problem because, the geonode server IP (172.21.14.02) is in our network, however db4my_geonode container IP 172.27.0.6 is out of our network. But as docker-compose ps showed the server 172.21.14.02, port 5432 is being used by db4my_geonode container. I can not really figure out what is going on!!!!
> > > > > > > > > > > Given that configuration the database container has a different network address because it is running on the internal network established by docker. Therefore from your host machine, I mean the CentOS, it is correct that you are not allowed to reach the db container. If you want to reach that you have to run your psql within the django container in such a way:
> > > > > > > > > > > psql -h db -U geonode -d geonode (please note that the hostname is right the service name given in the docker-compose file ;) )
> > > > > > > > > > > > Any help on that will be very appreciated.
> > > > > > > > > > > > Kind regards
> > > > > > > > > > > > Julierme
> > > > > > > > > > > Hope this helps
> > > > > > > > > > > > > On Mon, Jan 14, 2019 at 1:22 PM Francesco Bartoli <xbartolone at gmail.com> wrote:
> > > > > > > > > > > > > > Hi Julierme,
> > > > > > > > > > > > > > Where are you trying to run the test? Is the container related to the service “db” running? What’s the output of docker-compose ps?
> > > > > > > > > > > > > > Il 14 gen 2019, 16:09 +0100, Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com>, ha scritto:
> > > > > > > > > > > > > > > Trying to answer question 3, I ran a test:
> > > > > > > > > > > > > > > psql -h 172.21.14.02 -U geonode -d geonode
> > > > > > > > > > > > > > > psql: could not connect to server: No route to host
> > > > > > > > > > > > > > > Though /var/lib/postgresql/data/pg_hba.conf is set to trust (see bellow), I can not understand why the connection to postgres is not successful.
> > > > > > > > > > > > > > > local all all trust
> > > > > > > > > > > > > > > Any comment on this matter will be very appreciated.
> > > > > > > > > > > > > > > Kind regards
> > > > > > > > > > > > > > > Julierme
> > > > > > > > > > > > > > > > On Mon, Jan 14, 2019 at 12:30 PM Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com> wrote:
> > > > > > > > > > > > > > > > > Regarding my previous questions:
> > > > > > > > > > > > > > > > > 1 - When installing geonode-project via docker, is postgres configuration set automatically as in here?
> > > > > > > > > > > > > > > > > I think so. Because I found all the databases and user configured into db4my_geonode container.
> > > > > > > > > > > > > > > > > 2 - Could the error in the log file (geonode-project server 172.21.14.02) be related to pg_hba.conf file (local connections)?
> > > > > > > > > > > > > > > > > I do not think so. Because looking at /var/lib/postgresql/data/pg_hba.conf in db4my_geonode, the cofiguration is set as:
> > > > > > > > > > > > > > > > > local all all trust
> > > > > > > > > > > > > > > > > Within these two answers I should not have gotten any problem by configuring HOST: '172.21.14.02' in local_settings / DATABASES: {...}
> > > > > > > > > > > > > > > > > I am still thinking about question 3:
> > > > > > > > > > > > > > > > > Is there any postgres (db4my_geonode container) configuration in geonode-project server 172.21.14.02 that I must do, before using it as HOST value in local_settings / DATABASES = {...}?
> > > > > > > > > > > > > > > > > Thank you for your time in advance
> > > > > > > > > > > > > > > > > Kind regards
> > > > > > > > > > > > > > > > > Julierme
> > > > > > > > > > > > > > > > > > On Mon, Jan 14, 2019 at 12:01 PM Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com> wrote:
> > > > > > > > > > > > > > > > > > > Deal all,
> > > > > > > > > > > > > > > > > > > This is not an issue, but a question regarding postgres configuration in GeoNode-Project Docker installation.
> > > > > > > > > > > > > > > > > > > I have 2 servers and 1 client server.
> > > > > > > > > > > > > > > > > > > Server 1: postgres server - IP: 172.21.14.01
> > > > > > > > > > > > > > > > > > > I installed postgres in Server 1 (172.21.14.01) and I configured postgres as in here. I created in postgres:
> > > > > > > > > > > > > > > > > > > a user: geonode with password osgeo;
> > > > > > > > > > > > > > > > > > > a db: geonode owned by geonode user;
> > > > > > > > > > > > > > > > > > > a db: geonode_data owned by geonode user;
> > > > > > > > > > > > > > > > > > > and so on.
> > > > > > > > > > > > > > > > > > > Server 2 (CentOS7): geonode-project server - IP: 172.21.14.02
> > > > > > > > > > > > > > > > > > > I installed geonode-project at 2.8 via Docker in server 2 and changed localhost to 172.21.14.02 in docker-compose.override.yml file in order to access the geonode site from the client server.
> > > > > > > > > > > > > > > > > > > Client server: my_workstation - IP: 172.21.14.03
> > > > > > > > > > > > > > > > > > > GeoNode-Project installation via Docker is successful if I change localhost to 172.21.14.01 (postgres remote server) as in:
> > > > > > > > > > > > > > > > > > > # Backend
> > > > > > > > > > > > > > > > > > > DATABASES = {
> > > > > > > > > > > > > > > > > > > 'default': {
> > > > > > > > > > > > > > > > > > > 'ENGINE': 'django.db.backends.postgresql_psycopg2',
> > > > > > > > > > > > > > > > > > > 'NAME': 'geonode',
> > > > > > > > > > > > > > > > > > > 'USER': 'geonode',
> > > > > > > > > > > > > > > > > > > 'PASSWORD': 'geonode',
> > > > > > > > > > > > > > > > > > > 'HOST': '172.21.14.01',
> > > > > > > > > > > > > > > > > > > 'PORT': '5432',
> > > > > > > > > > > > > > > > > > > 'CONN_TOUT': 900,
> > > > > > > > > > > > > > > > > > > # vector datastore for uploads
> > > > > > > > > > > > > > > > > > > 'datastore': {
> > > > > > > > > > > > > > > > > > > 'ENGINE': 'django.contrib.gis.db.backends.postgis',
> > > > > > > > > > > > > > > > > > > # 'ENGINE': '', # Empty ENGINE name disables
> > > > > > > > > > > > > > > > > > > 'NAME': 'geonode_data',
> > > > > > > > > > > > > > > > > > > 'USER': 'geonode',
> > > > > > > > > > > > > > > > > > > 'PORT': '5432',
> > > > > > > > > > > > > > > > > > > 'CONN_TOUT': 900,
> > > > > > > > > > > > > > > > > > > However if I configure HOST:'172.21.14.02' or HOST: 'localhost', geonode-project django and celery container will not go up and the log file says respectively for HOST:'172.21.14.02' and HOST: 'localhost' configuration:
> > > > > > > > > > > > > > > > > > > django4my_geonode | Is the server running on host "172.21.14.45" and accepting
> > > > > > > > > > > > > > > > > > > Though geonode-project installation is successful, by using postgres remote server IP: 172.21.14.01, configured manually, I do not want to use it.
> > > > > > > > > > > > > > > > > > > I want to use geonode-project server IP:172.21.14.02. Said that, I came out with the following questions:
> > > > > > > > > > > > > > > > > > > 3 - Is there any postgres (geonode/postgis container) configuration in geonode-project server 172.21.14.02 that I must do, before using it as HOST value in local_settings / DATABASES = {...}?
> > > > > > > > > > > > > > > > > > > My apologies for the long e-mail and thank you very much for your time and patience.
> > > > > > > > > > > > > > > > > > > Kind regards
> > > > > > > > > > > > > > > > > > > Julierme
> > > > > > > > > > > > > > > _______________________________________________
> > > > > > > > > > > > > > > geonode-users mailing list
> > > > > > > > > > > > > > > geonode-users at lists.osgeo.org
> > > > > > > > > > > > > > > https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190115/fac998ee/attachment-0001.html>
More information about the geonode-users
