[GeoNode-users] GeoNode Layer Style Weather Symbols and Web Links
Julierme Pinheiro juliermeopensourcedeveloper at gmail.com
Mon Jan 21 12:30:56 PST 2019
Hi Toni,
Regarding my previous email, GeoServer at 2.14.2 was causing the problem. I
removed GeoServer at 2.14.2 and installed GeoServer at 2.14.1 and issue is
solved. Find geo.sld bellow working smoothly on GeoServer at 2.14.1 and a
screenshot of tb_brasilia_weather layer. Now, I am doing the same thing in
my GeoNode at 2.8 in a CenTos7 Server installed via Docker and
GeoServer at 2-13-SNAPSHOT in geoserver4my_geonode container.
Using the same geo.sld file, I am having some problem trying to reach the
image files in geoserver4my_geonode container.  I tried  the settings
bellow without no success.
<sld:OnlineResource xlink:type="simple"
xlink:href="c3499bb0ae79:/usr/local/tomcat/weabapps/geoserver/data/day.svg"/>
xlink:href="geoserver4my_geonode:/usr/local/tomcat/weabapps/geoserver/data/day.svg"/>
<sld:OnlineResource xlink:type="simple" xlink:href="172.18.0.6:
Any suggestion or comment on this issue will be very appreciated.
I appreciated your time and help
Kind regards
Julierme
*geo.sld *
<?xml version="1.0" encoding="UTF-8"?><sld:StyledLayerDescriptor xmlns="
http://www.opengis.net/sld" xmlns:sld="http://www.opengis.net/sld"
xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc"
version="1.0.0" xsi:schemaLocation="http://www.opengis.net/sld
StyledLayerDescriptor.xsd" xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
  <sld:NamedLayer>
    <sld:Name>geo_sipam</sld:Name>
    <sld:UserStyle>
      <sld:FeatureTypeStyle>
        <sld:Rule>
          <ogc:Filter>
            <ogc:PropertyIsEqualTo>
              <ogc:PropertyName>weather</ogc:PropertyName>
              <ogc:Literal>0</ogc:Literal>
            </ogc:PropertyIsEqualTo>
          </ogc:Filter>
          <sld:PointSymbolizer>
            <sld:Graphic>
           <sld:ExternalGraphic>
             <sld:OnlineResource xlink:type="simple" xlink:href="day.svg"/>
             <sld:Format>image/svg+xml</sld:Format>
           </sld:ExternalGraphic>
           <sld:Size>100</sld:Size>
         </sld:Graphic>
          </sld:PointSymbolizer>
        </sld:Rule>
        <sld:Rule>
          <ogc:Filter>
              <ogc:Literal>1</ogc:Literal>
          </ogc:Filter>
            <sld:Graphic>
         </sld:Graphic>
        </sld:Rule>
        <sld:Rule>
        <ogc:Filter>
              <ogc:Literal>2</ogc:Literal>
        </ogc:Filter>
         <sld:Graphic>
xlink:href="thunder.svg"/>
         </sld:Graphic>
        </sld:Rule>
        <sld:Rule>
        <ogc:Filter>
              <ogc:Literal>3</ogc:Literal>
        </ogc:Filter>
         <sld:Graphic>
xlink:href="snowy-1.svg"/>
         </sld:Graphic>
        </sld:Rule>
        <sld:Rule>
        <ogc:Filter>
              <ogc:Literal>4</ogc:Literal>
        </ogc:Filter>
         <sld:Graphic>
xlink:href="rainy-1.svg"/>
         </sld:Graphic>
        </sld:Rule>
        <sld:VendorOption name="ruleEvaluation">first</sld:VendorOption>
      </sld:FeatureTypeStyle>
    </sld:UserStyle>
  </sld:NamedLayer>
</sld:StyledLayerDescriptor>
On Mon, Jan 21, 2019 at 3:18 PM Julierme Pinheiro <
juliermeopensourcedeveloper at gmail.com> wrote:
> Hi Toni,
> am I correct that you´re using the geoserver css extension?
> Yes. You are right. I am using css extension.
> Can you supply the generated sld?
> Yes. I am send it in attached.
> $ ll ./geoserver/data/styles/thunder.svg
> -rwxr-xr-x 1 tomcat8 tomcat8 1918 jan 21 10:52 ./thunder.svg*
> I changed geonode_css.css file as shown bellow and I am sending
> geonode_css.sld in attached. It still not working.
> * [weather = 4]{
>   mark: symbol('circle');
>   mark-size: 5;
> :mark {
>   fill: cyan;
>   stroke: darkblue;
> [weather = 0] {
>   mark: url(day.svg);
>   mark-mime: "image/svg";
>   mark-size: 100;
> I appreciated you help and time.
> Kind regards
> Julierme
> On Mon, Jan 21, 2019 at 2:08 PM Toni Schönbuchner <
> toni.schoenbuchner at csgis.de> wrote:
>> Hey Julierme,
>> Further the output of:
>> $ ll ./geoserver/data/styles/sunny.svg
>> Further I think the mime type in sld for svg is
>> <Format>image/svg+xml" </Format>
>> your could try
>> mark-mime: "image/svg+xml"
>> (unsure about this just a shot in the dark)
>> Cheers,
>> Toni
>> CSGIS
>> Kolonnadenstraße 1
>> 04109 Leipzig
>> Tel  +49/ (0) 341 24 04 738
>> Fax  +49/ (0) 341 24 04 739
>> Web http://csgis.de
>> Hinweis gemäß § 33 BDSG
>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
>> ausschließlich für den
>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
>> diese E-Mail versehentlich
>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
>> löschen Sie diese Nachricht
>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>> Vervielfältigung, Veränderung,
>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>> Am 21.01.2019 um 16:51 schrieb Julierme Pinheiro <
>> juliermeopensourcedeveloper at gmail.com>:
>> Dear Jorge and Toni,
>> Thank you very much for your reply.
>> I have a table (db_brasilia_weather) in postgis. The table
>> db_brasilia_weather has two attributes: weather and url_image. weather
>> attribute has integer values of weather status and url_image attribute: the
>> path for the weather images cloudy.svg, thunder.svg, sunny.svg, rainy.svg.
>> db_brasilia_weather
>> id     weather      url_image
>> 1          0             sunny.svg
>> 2          5             thunder.svg
>> 3          1             rainy.svg
>> *.svg images are stored in  /webapps/geoserver/data/styles
>> Based on the information, Creating Point Styles in [1] and Item 3.4.2
>> about Graphic in [2], I created the following CSS (geonode.css) file:
>>   mark-size: 5;
>> :mark {
>>   fill: cyan;
>>   stroke: darkblue;
>> [weather = 0] {
>>   mark: url(./geoserver/data/styles/sunny.svg);
>>   mark-size: 100;
>> I have tried mark: url(sunny.svg),
>> url("./geoserver/data/styles/sunny.svg"), but none of these configuration
>> have been successful.
>> Any additional comment on this matter will be very appreciated.
>> Thank you very much for your time in advance.
>> Kind Regards
>> Julierme
>> [1]
>> http://docs.geonode.org/en/master/tutorials/advanced/adv_data_mgmt/pretty_maps/css.html#creating-point-styles
>> [2]
>> https://docs.geoserver.org/stable/en/user/styling/workshop/css/point.html
>> On Sun, Jan 20, 2019 at 5:53 AM Toni Schönbuchner <
>>> Hi Julierme,
>>> I don´t think you can access a postgis entity  directly from SLD.
>>> The Point Symbolizer allows external graphics as mark or ressource.
>>> https://docs.geoserver.org/stable/en/user/styling/sld/reference/pointsymbolizer.html#externalgraphic
>>> Where an external ressource could also be identified as URL.
>>> Means you could add the SVG to your static root or in some other public
>>> directory or even dropbox and use it as symbol. As alternative it should
>>> work
>>> to specific a relative path outside of the data dir where tomcat is
>>> allowed to read
>>> from. With second linking to the file gets harder.
>>> May I ask you why the svg should be stored in the database? – unsure if
>>> there
>>> is some better way but for sure you could just create a django view to
>>> output
>>> the svg from postgres and use it like this in your sld.
>>> Cheers,
>>> Toni
>>> > Today's Topics:
>>> >   1. Re: GeoNode Layer Style Weather Symbols and Web  Links
>>> >      (Julierme Pinheiro)
>>> > Message: 1
>>> > Date: Fri, 18 Jan 2019 18:59:40 -0200
>>> > From: Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com>
>>> > To: geonode-users <geonode-users at lists.osgeo.org>
>>> > Subject: Re: [GeoNode-users] GeoNode Layer Style Weather Symbols and
>>> >       Web     Links
>>> > Message-ID:
>>> >       <CAKTKyJK9dtC9MX_QHHH+bJvswgBzcC=
>>> BPOwodR840KZLPoZ0aA at mail.gmail.com>
>>> > Content-Type: text/plain; charset="utf-8"
>>> > Hi GeoNode users,
>>> > Regarding my previous email, looking at GeoServer documentation
>>> https://docs.geoserver.org/stable/en/user/styling/sld/extensions/pointsymbols.html#external-graphics
>>> > I got the piece of SLD bellow, but burg02.svg is being retrieved from
>>> > $GEOSERVER_DATA_DIR/styles.
>>> > I would like to have:
>>> > 1 - burg02.svg being retrieved from a postgres table;
>>> > 2 - make a webpage link on burg02.svg through the  SLD file
>>> > <PointSymbolizer>
>>> >   <Graphic>
>>> >     <ExternalGraphic>
>>> >       <OnlineResource xlink:type="simple" xlink:href="burg02.svg" />
>>> >       <Format>image/svg+xml</Format>
>>> >     </ExternalGraphic>
>>> >     <Size>20</Size>
>>> >   </Graphic>
>>> > </PointSymbolizer>
>>> > Any hint on that will be very appreciated.
>>> > Kind regards
>>> > Julierme
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190121/1c577519/attachment-0001.html>
Name: Screenshot from 2019-01-21 18-17-29.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190121/1c577519/attachment-0001.png>
More information about the geonode-users mailing list
