[GeoNode-users] GeoNode-Project CenTOS7 Installation
1520 gis juliermeopensourcedeveloper at gmail.com
Wed Jul 17 10:19:30 PDT 2019
Hi Ran,
Thank you very much for your reply. Yes, I just installed a brand new
version of GeoNode-Project at 2.8 and updatelayers did not work. See the
response in [1]. I then ran
python manage.py makemigrations
python manage.py migrate
However, the problem remains. I am now asked for a superuser [2]. I did
create a superuser for GeoNode-Project in a CenTOS7, but did not solve the
problem. The issue also happens in GeoNode-Project at 2.10.
Any help would be appreciated.
Kind regards
Julierme
[1]
root at 2ff53eacb7e9:/usr/src/my_geonode# python manage.py updatelayers -s
metoc -f previsao_meteorologica_aml
JSONField implementation is: <class 'jsonfield.fields.JSONField'>
  File "manage.py", line 31, in <module>
    execute_from_command_line(sys.argv)
  File
"/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py",
line 354, in execute_from_command_line
    utility.execute()
  File
line 346, in execute
    self.fetch_command(subcommand).run_from_argv(self.argv)
  File
"/usr/local/lib/python2.7/site-packages/django/core/management/base.py",
line 394, in run_from_argv
    self.execute(*args, **cmd_options)
  File
line 445, in execute
    output = self.handle(*args, **options)
  File
"/usr/src/geonode/geonode/geoserver/management/commands/updatelayers.py",
line 98, in handle
    owner = get_valid_user(user)
  File "/usr/src/geonode/geonode/people/utils.py", line 44, in
get_valid_user
    theuser = get_default_user()
  File "/usr/src/geonode/geonode/people/utils.py", line 31, in
get_default_user
    if superusers.count() > 0:
  File "/usr/local/lib/python2.7/site-packages/django/db/models/query.py",
line 318, in count
    return self.query.get_count(using=self.db)
  File
"/usr/local/lib/python2.7/site-packages/django/db/models/sql/query.py",
line 466, in get_count
    number = obj.get_aggregation(using, ['__count'])['__count']
  File
line 447, in get_aggregation
    result = compiler.execute_sql(SINGLE)
  File
"/usr/local/lib/python2.7/site-packages/django/db/models/sql/compiler.py",
line 840, in execute_sql
    cursor.execute(sql, params)
  File
"/usr/local/lib/python2.7/site-packages/django/db/backends/utils.py", line
79, in execute
    return super(CursorDebugWrapper, self).execute(sql, params)
  File
64, in execute
    return self.cursor.execute(sql, params)
  File "/usr/local/lib/python2.7/site-packages/django/db/utils.py", line
98, in __exit__
    six.reraise(dj_exc_type, dj_exc_value, traceback)
  File
64, in execute
  File
"/usr/local/lib/python2.7/site-packages/django/db/backends/sqlite3/base.py",
line 318, in execute
    return Database.Cursor.execute(self, query, params)
django.db.utils.OperationalError: no such table: people_profile
[2]
root at 2ff53eacb7e9:/usr/src/my_geonode# python manage.py updatelayers -f
  File
    utility.execute()
  File
  File
  File
  File
line 98, in handle
get_valid_user
  File "/usr/src/geonode/geonode/people/utils.py", line 35, in
get_default_user
    raise GeoNodeException('You must have an admin account configured '
geonode.GeoNodeException: You must have an admin account configured before
importing data. Try: django-admin.py createsuperuser
On Wed, Jul 17, 2019 at 2:06 PM Ran L. <kula009 at gmail.com> wrote:
> Hello Julierme,
> I also had issues with the geonode "updatelayers" command yesterday, and
> might have found a possible solution for it:
> I'm also using geonode-project with docker on a Ubuntu machine. I couldn't
> run the command successfully after building the service. You can see the
> details here: https://github.com/GeoNode/geonode/issues/4650
> *A fix: *I took my own customized files (templates, python files,
> statics, etc.) and dump them into a newly created geonode-project. The
> command worked after that.
> My speculation is that the geonode-project files I had were not compatible
> with the current geonode, since I haven't updated them for a long while.
> Hope this provides some insights.
> Thanks!
> Ran
> On Wed, Jul 17, 2019 at 9:47 AM 1520 gis <
> juliermeopensourcedeveloper at gmail.com> wrote:
>> Dear users and developers,
>> I am not sure if it is on the scope of future work, but I have already
>> started a tutorial to install GeoNode-Project via Docker on a CentOS7
>> server. I got it installed, but not sure that I got all required geonode
>> packages on a CenTOS7. Also, I had an issue while using python manage.py
>> updatelayers.
>> I am making myself a volunteer to help on this theme. I would like to
>> share the command lines and have someones' contribution to improve what I
>> got so far.
>> Kind regards,
>> Julierme
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190717/2ab49f9c/attachment.html>
More information about the geonode-users mailing list
