[GeoNode-users] GeoNode-Project CenTOS7 Installation
1520 gis juliermeopensourcedeveloper at gmail.com
Wed Jul 17 11:46:52 PDT 2019
Yes, you are right. We got close, but still an issue. See bellow please
with django-admin and manage.py
root at bdeea2347fe6:/usr/src/my_geonode# django-admin updatelayers
  File "/usr/local/bin/django-admin", line 10, in <module>
    sys.exit(execute_from_command_line())
  File
"/usr/local/lib/python2.7/site-packages/django/core/management/__init__.py",
line 364, in execute_from_command_line
    utility.execute()
  File
line 356, in execute
    self.fetch_command(subcommand).run_from_argv(self.argv)
  File
"/usr/local/lib/python2.7/site-packages/django/core/management/base.py",
line 283, in run_from_argv
    self.execute(*args, **cmd_options)
  File
line 330, in execute
    output = self.handle(*args, **options)
  File
"/usr/local/lib/python2.7/site-packages/geonode/geoserver/management/commands/updatelayers.py",
line 98, in handle
    owner = get_valid_user(user)
  File "/usr/local/lib/python2.7/site-packages/geonode/people/utils.py",
line 44, in get_valid_user
    theuser = get_default_user()
line 31, in get_default_user
    if superusers.count() > 0:
  File "/usr/local/lib/python2.7/site-packages/django/db/models/query.py",
line 364, in count
    return self.query.get_count(using=self.db)
  File
"/usr/local/lib/python2.7/site-packages/django/db/models/sql/query.py",
line 499, in get_count
    number = obj.get_aggregation(using, ['__count'])['__count']
  File
line 480, in get_aggregation
    result = compiler.execute_sql(SINGLE)
  File
"/usr/local/lib/python2.7/site-packages/django/db/models/sql/compiler.py",
line 899, in execute_sql
    raise original_exception
django.db.utils.OperationalError: no such table: people_profile
root at bdeea2347fe6:/usr/src/my_geonode# python manage.py updatelayers
  File "manage.py", line 31, in <module>
    execute_from_command_line(sys.argv)
  File
    utility.execute()
  File
  File
  File
  File
line 98, in handle
line 364, in count
  File
  File
  File
On Wed, Jul 17, 2019 at 2:59 PM Ran L. <kula009 at gmail.com> wrote:
> But you are getting a different error message this time. Could you try the
> simple command:
> 'django-admin updatelayers'
> And see how it goes?
> Ran
> On Wed, Jul 17, 2019 at 10:30 AM 1520 gis <
> juliermeopensourcedeveloper at gmail.com> wrote:
>> Thank you very much Ran, but the issue remains.
>> mkdir -p /usr/src/app/; \
>> > source $HOME/.override_env; \
>> > echo DATABASE_URL=$DATABASE_URL; \
>> > echo GEODATABASE_URL=$GEODATABASE_URL; \
>> > echo SITEURL=$SITEURL; \
>> > echo ALLOWED_HOSTS=$ALLOWED_HOSTS; \
>> > echo GEOSERVER_PUBLIC_LOCATION=$GEOSERVER_PUBLIC_LOCATION;
>> DATABASE_URL=postgres://geonode:geonode@db:5432/geonode
>> GEODATABASE_URL=postgis://geonode_data:geonode_data@db:5432/geonode_data
>> SITEURL=http://cgticgeo.sipam.gov.br/
>> ALLOWED_HOSTS=['cgticgeo.sipam.gov.br', 'cgticgeo.sipam.gov.br', '
>> cgticgeo.sipam.gov.br:80', 'geonode', 'django']
>> GEOSERVER_PUBLIC_LOCATION=http://cgticgeo.sipam.gov.br/geoserver/
>> root at 2ff53eacb7e9:/usr/src/my_geonode# python manage.py updatelayers -w
>> geonode -f previsao_meteorologica_aml
>> JSONField implementation is: <class 'jsonfield.fields.JSONField'>
>> Inspecting the available layers in GeoServer ...
>> Found 1 layers, starting processing
>> Could not retrieve GeoFence Rules count.
>> ... Creating Thumbnail for Layer [geonode:previsao_meteorologica_aml]
>> Stopping process because --ignore-errors was not set and an error was
>> found.
>>   File
>> line 354, in execute_from_command_line
>>     utility.execute()
>>   File
>> line 346, in execute
>>   File
>> line 394, in run_from_argv
>>   File
>> line 445, in execute
>>   File
>> "/usr/src/geonode/geonode/geoserver/management/commands/updatelayers.py",
>> line 124, in handle
>>     execute_signals=True)
>>   File "/usr/src/geonode/geonode/geoserver/helpers.py", line 630, in
>> gs_slurp
>>     layer.set_permissions(perm_spec)
>>   File "/usr/src/geonode/geonode/security/models.py", line 205, in
>> set_permissions
>>     sync_geofence_with_guardian(self.layer, perms, user=geofence_user)
>>   File "/usr/src/geonode/geonode/decorators.py", line 48, in wrapper
>>     return func(*args, **kwargs)
>>   File "/usr/src/geonode/geonode/security/utils.py", line 448, in
>>     _update_geofence_rule(layer.name, layer.workspace, service,
>> user=_user)
>>   File "/usr/src/geonode/geonode/security/utils.py", line 592, in
>>     raise RuntimeError(msg)
>> Exception: ('Failed to process previsao_meteorologica_aml',
>> RuntimeError('Could not ADD GeoServer User \'admin\' Rule for Layer
>> u\'previsao_meteorologica_aml\': \'u\'<!doctype html><html
>> lang="en"><head><title>HTTP Status 404 \\u2013 Not Found</title><style
>> type="text/css">h1
>> {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:22px;}
>> h2
>> {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:16px;}
>> h3
>> {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:14px;}
>> body
>> {font-family:Tahoma,Arial,sans-serif;color:black;background-color:white;} b
>> {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;}
>> p
>> {font-family:Tahoma,Arial,sans-serif;background:white;color:black;font-size:12px;}
>> a {color:black;} a.name {color:black;} .line
>> {height:1px;background-color:#525D76;border:none;}</style></head><body><h1>HTTP
>> Status 404 \\u2013 Not Found</h1><hr class="line" /><p><b>Type</b> Status
>> Report</p><p><b>Description</b> The origin server did not find a current
>> representation for the target resource or is not willing to disclose that
>> one exists.</p><hr class="line" /><h3>Apache
>> Tomcat/9.0.19</h3></body></html>\'\'',))
>> Kind regards
>> Julierme
>> On Wed, Jul 17, 2019 at 2:23 PM Ran L. <kula009 at gmail.com> wrote:
>>> Hi Julierme,
>>> I had the problem you described before. The reason you are getting this
>>> is because the env variables are not set properly. Run this command before
>>> running any other commands:
>>> You should be able to run the commands then.
>>> I
>>> On Wed, Jul 17, 2019 at 10:19 AM 1520 gis <
>>>> Hi Ran,
>>>> Thank you very much for your reply. Yes, I just installed a brand new
>>>> version of GeoNode-Project at 2.8 and updatelayers did not work. See the
>>>> response in [1]. I then ran
>>>> python manage.py makemigrations
>>>> python manage.py migrate
>>>> However, the problem remains. I am now asked for a superuser [2]. I did
>>>> create a superuser for GeoNode-Project in a CenTOS7, but did not solve the
>>>> problem. The issue also happens in GeoNode-Project at 2.10.
>>>> Any help would be appreciated.
>>>> Kind regards
>>>> Julierme
>>>> [1]
>>>> -s metoc -f previsao_meteorologica_aml
>>>>   File
>>>>     utility.execute()
>>>>   File
>>>>   File
>>>>   File
>>>>   File
>>>> line 98, in handle
>>>>   File "/usr/src/geonode/geonode/people/utils.py", line 44, in
>>>> get_valid_user
>>>>   File "/usr/src/geonode/geonode/people/utils.py", line 31, in
>>>> get_default_user
>>>>   File
>>>> "/usr/local/lib/python2.7/site-packages/django/db/models/query.py", line
>>>> 318, in count
>>>>   File
>>>> line 466, in get_count
>>>>   File
>>>> line 447, in get_aggregation
>>>>   File
>>>> line 840, in execute_sql
>>>>     cursor.execute(sql, params)
>>>>   File
>>>> "/usr/local/lib/python2.7/site-packages/django/db/backends/utils.py", line
>>>> 79, in execute
>>>>     return super(CursorDebugWrapper, self).execute(sql, params)
>>>>   File
>>>> 64, in execute
>>>>     return self.cursor.execute(sql, params)
>>>>   File "/usr/local/lib/python2.7/site-packages/django/db/utils.py",
>>>> line 98, in __exit__
>>>>     six.reraise(dj_exc_type, dj_exc_value, traceback)
>>>>   File
>>>> 64, in execute
>>>>   File
>>>> "/usr/local/lib/python2.7/site-packages/django/db/backends/sqlite3/base.py",
>>>> line 318, in execute
>>>>     return Database.Cursor.execute(self, query, params)
>>>> [2]
>>>>   File
>>>>     utility.execute()
>>>>   File
>>>>   File
>>>>   File
>>>>   File
>>>> line 98, in handle
>>>> get_valid_user
>>>>   File "/usr/src/geonode/geonode/people/utils.py", line 35, in
>>>> get_default_user
>>>>     raise GeoNodeException('You must have an admin account configured '
>>>> geonode.GeoNodeException: You must have an admin account configured
>>>> before importing data. Try: django-admin.py createsuperuser
>>>> On Wed, Jul 17, 2019 at 2:06 PM Ran L. <kula009 at gmail.com> wrote:
>>>>> Hello Julierme,
>>>>> I also had issues with the geonode "updatelayers" command yesterday,
>>>>> and might have found a possible solution for it:
>>>>> I'm also using geonode-project with docker on a Ubuntu machine. I
>>>>> couldn't run the command successfully after building the service. You can
>>>>> see the details here: https://github.com/GeoNode/geonode/issues/4650
>>>>> *A fix: *I took my own customized files (templates, python files,
>>>>> statics, etc.) and dump them into a newly created geonode-project. The
>>>>> command worked after that.
>>>>> My speculation is that the geonode-project files I had were not
>>>>> compatible with the current geonode, since I haven't updated them for a
>>>>> long while.
>>>>> Hope this provides some insights.
>>>>> Thanks!
>>>>> Ran
>>>>> On Wed, Jul 17, 2019 at 9:47 AM 1520 gis <
>>>>>> Dear users and developers,
>>>>>> I am not sure if it is on the scope of future work, but I have
>>>>>> already started a tutorial to install GeoNode-Project via Docker on a
>>>>>> CentOS7 server. I got it installed, but not sure that I got all required
>>>>>> geonode packages on a CenTOS7. Also, I had an issue while using python
>>>>>> manage.py updatelayers.
>>>>>> I am making myself a volunteer to help on this theme. I would like to
>>>>>> share the command lines and have someones' contribution to improve what I
>>>>>> got so far.
>>>>>> Kind regards,
>>>>>> Julierme
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190717/fd5e8e3d/attachment-0001.html>
More information about the geonode-users mailing list
