[GeoNode-users] Trouble with AuthAdmin/UpdateLayers/SyncGeofence
    Alessio Fabiani
    alessio.fabiani at geo-solutions.it
    Wed Jun 12 05:55:34 PDT 2019
Hi, GeoNode 2.8.2 currently works only with GeoServer 2.14+
Il giorno lun 10 giu 2019 alle ore 16:47 Paige Lott <
paige.lott.gis at gmail.com> ha scritto:
> Geonode Version: 2.8.2
> Geoserver Version:  2.13-SNAPSHOT
> Hi Geonode Users,
> I'm extremely new to Geonode/Geoserver and I've been working on this
> problem for a while now and haven't been able to figure out what I'm doing
> wrong.  Thought I'd post to see if anyone else had run into this particular
> error.  My install was done following the install guide on the docs for Ubuntu
> 16.04
> <http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/#>.
> Thank you for any help you can provide.
> -Paige
> Whenever I login to Geoserver:
> WARN [geofence.cache] -
> org.geoserver.geofence.cache.CachedRuleReader$NoAuthException: Can't auth
> user [admin]
> Whenever I try and run updatelayers to make the layers added in geoserver
> visible in geonode, I get the error message below:
> Python:
> JSONField implementation is: <class 'jsonfield.fields.JSONField'>
> Inspecting the available layers in GeoServer ...
> Found 1 layers, starting processing
> Could not retrieve GeoFence Rules count.
> Stopping process because --ignore-errors was not set and an error was
> found.
> Traceback (most recent call last):
>   File "manage.py", line 31, in <module>
>     execute_from_command_line(sys.argv)
>   File
> "/home/geo/Envs/geonode/local/lib/python2.7/site-packages/django/core/management/__init__.py",
> line 354, in execute_from_command_line
>     utility.execute()
>   File
> line 346, in execute
>     self.fetch_command(subcommand).run_from_argv(self.argv)
>   File
> "/home/geo/Envs/geonode/local/lib/python2.7/site-packages/django/core/management/base.py",
> line 394, in run_from_argv
>     self.execute(*args, **cmd_options)
>   File
> line 445, in execute
>     output = self.handle(*args, **options)
>   File
> "/home/geo/Envs/geonode/src/geonode/geonode/geoserver/management/commands/updatelayers.py",
> line 124, in handle
>     execute_signals=True)
>   File "/home/geo/Envs/geonode/src/geonode/geonode/geoserver/helpers.py",
> line 630, in gs_slurp
>     layer.set_permissions(perm_spec)
>   File "/home/geo/Envs/geonode/src/geonode/geonode/security/models.py",
> line 205, in set_permissions
>     sync_geofence_with_guardian(self.layer, perms, user=geofence_user)
>   File "/home/geo/Envs/geonode/src/geonode/geonode/decorators.py", line
> 48, in wrapper
>     return func(*args, **kwargs)
>   File "/home/geo/Envs/geonode/src/geonode/geonode/security/utils.py",
> line 448, in sync_geofence_with_guardian
>     _update_geofence_rule(layer.name, layer.workspace, service,
> user=_user)
> line 592, in _update_geofence_rule
>     raise RuntimeError(msg)
> Exception: ('Failed to process fisheries_mgmt_points_evw',
> RuntimeError('Could not ADD GeoServer User \'admin_geonode\' Rule for Layer
> u\'agfc_fisheries_mgmt_points_evw\': \'u\'<!DOCTYPE
> html><html><head><title>Apache Tomcat/8.0.32 (Ubuntu) - Error
> report</title><style type="text/css">H1
> {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:22px;}
> H2
> {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:16px;}
> H3
> {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;font-size:14px;}
> BODY
> {font-family:Tahoma,Arial,sans-serif;color:black;background-color:white;} B
> {font-family:Tahoma,Arial,sans-serif;color:white;background-color:#525D76;}
> P
> {font-family:Tahoma,Arial,sans-serif;background:white;color:black;font-size:12px;}A
> {color : black;}A.name {color : black;}.line {height: 1px;
> background-color: #525D76; border: none;}</style> </head><body><h1>HTTP
> Status 404 - </h1><div class="line"></div><p><b>type</b> Status
> report</p><p><b>message</b> <u></u></p><p><b>description</b> <u>The
> requested resource is not available.</u></p><hr class="line"><h3>Apache
> Tomcat/8.0.32 (Ubuntu)</h3></body></html>\'\'',))
> Geoserver:
>  WARN [servlet.PageNotFound] - No mapping found for HTTP request with URI
> [/geoserver/rest/geofence/rules.json] in DispatcherServlet with name
> 'dispatcher'
>  WARN [geofence.rest] - INVALIDATING CACHE
>  WARN [geofence.cache] - Forcing cache invalidation
> 'dispatcher'
> [/geoserver/rest/geofence/rules/count.json] in DispatcherServlet with name
> 'dispatcher'
> 'dispatcher'
> [/geoserver/rest/geofence/rules] in DispatcherServlet with name 'dispatcher'
> I've tried running sync_geofence to see if that would resolve anything but
> I also receive an error when running that command.
> Python:
> Synchronizing permissions for layer 1/1:
> geonode:agfc_fisheries_mgmt_points_evw
> ('Unexpected error:', <type 'exceptions.RuntimeError'>)
> perm_spec is {u'users': {u'admin_geonode': [u'view_resourcebase',
> u'download_resourcebase', u'change_resourcebase_metadata',
> u'change_resourcebase', u'delete_resourcebase',
> u'change_resourcebase_permissions', u'publish_resourcebase',
> u'change_layer_data', u'change_layer_style']}, u'groups': {}}
> Geoserver:
> 'dispatcher'
> 'dispatcher'
> 'dispatcher'
> 'dispatcher'
> The url for my geoserver for the geofence rule is at
> /geoserver/geofence/rest/rules , does this mean I have the wrong version of
> geoserver installed with geonode or is there a way to change where this is
> pointing?  Any help is extremely appreciated.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190612/1dbf03e6/attachment-0001.html>
More information about the geonode-users
