[GeoNode-users] First problems with docker compose demono runing as a sudo
Amedeo Fadini amefad at gmail.com
Thu Jun 20 04:26:14 PDT 2019
Hi Everybody, in my project I've already setup a customizede geonode-project
Now I'm trying to use docker compose as stated in the github
geonode-project readme
It seems that as the docker daemon is running as a service when I launche
docker-compose build --no-cache
It throws the errorr "Couldn't connect to Docker daemon"
If instead i Use
sudo docker-compose build --no-cache
It fails on compilation because the virtualenv is not setted up for sudp
What the correct way to launch docker-compose build for a geonode project?
I think it could work if I launch it by su after activatign Virtualenv for
su but i seems me a very bad Idea.
Thanks
Amefad
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190620/464d0d68/attachment-0001.html>
More information about the geonode-users mailing list
