[GeoNode-users] geonode devmode python virtualenv installation (Paulo Frias)
Francesco Bartoli
xbartolone at gmail.com
Sat Mar 16 13:37:55 PDT 2019
Hi Toni,
there is something which I don’t understand:
• Here https://github.com/GeoNode/geonode/blob/master/geonode/templates/base.html#L252 the link for getting the web admin page of GeoServer
• Its default value https://github.com/GeoNode/geonode/blob/master/geonode/templates/base.html#L252 comes from here https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L752
• The possible values have always a /gs location which isn’t a route allowed by neither any django urls nor Jetty
I guess there is a regression here at least for the default value which should affect development mode.
I’d like if @afabiani could confirm the issue and maybe give the rationale and how to get rid of it.
Il 16 mar 2019, 20:16 +0100, Toni Schönbuchner <toni.schoenbuchner at csgis.de>, ha scritto:
> Hello you two,
> let me sugest to use the master branch has it has some important bugfixes which are missing in 2.8 branch.
> 1) have a look where this link comes from:
> in master: {{ OGC_SERVER.default.WEB_UI_LOCATION }}
> in 2.8: {{ OGC_SERVER.default.LOCATION }}
> https://github.com/GeoNode/geonode/blob/929265975816af0c08199e47e05f8be3c93f5477/geonode/templates/base.html#L252
> https://github.com/GeoNode/geonode/blob/2.8.x/geonode/templates/base.html#L216
> Make sure to set those vars correctly in your local_settings..py
> 2) please use verbose geoserver logging (in gs Gui I think it´s under general)
> Watch log output while uploading layer with:
> $ sudo tail -f /var/log/tomcat8/catalina.out
> and maybe in some second terminal
> $ sudo tail -f /var/log/apache2/error.log
> As far as I remember this error can be solved when correctly setup your geoserver settings in local_settings
> and further to correctly setup oauth2 settings on both sides Geonode/geoserver.
> Hope this helps,
> cheers,
> Toni
> > Am 16.03.2019 um 20:00 schrieb geonode-users-request at lists.osgeo.org:
> > Send geonode-users mailing list submissions to
> > geonode-users at lists.osgeo.org
> > To subscribe or unsubscribe via the World Wide Web, visit
> > https://lists.osgeo.org/mailman/listinfo/geonode-users
> > or, via email, send a message with subject or body 'help' to
> > You can reach the person managing the list at
> > geonode-users-owner at lists.osgeo.org
> > When replying, please edit your Subject line so it is more specific
> > than "Re: Contents of geonode-users digest..."
> > Today's Topics:
> > 1. geonode devmode python virtualenv installation (Julierme Pinheiro)
> > 2. Re: geonode devmode python virtualenv installation (Paulo Frias)
> > Message: 1
> > Date: Fri, 15 Mar 2019 16:50:50 -0300
> > From: Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com>
> > To: geonode-users <geonode-users at lists.osgeo.org>, geonode-devel
> > <geonode-devel at lists.osgeo.org>
> > Subject: [GeoNode-users] geonode devmode python virtualenv
> > installation
> > Message-ID:
> > <CAKTKyJKbAbggkwsSQ_d_1Afs9-ABQm1e_mNCb2eVwBjRLzC5wg at mail.gmail.com>
> > Content-Type: text/plain; charset="utf-8"
> > Dear all,
> > I have tried to install geonode devmode vs 2.8 via python virtualenv in a
> > 16.04LTS Ubuntu server. I am following the guide in here [1].
> > I am using custom local_settings.py. Everything works fine, except:
> > 1 - geoserver url. The link for Geoserver on GeoNode site points to
> > localhost:8000/proxy/?url=http:localhost:8080/geoserver/, however when
> > clicking on it, the site opens localhost:8000/geoserver/index.html.
> > 2 - Upload layers - while uploading a layer, we hit " Unespected error"
> > Geoserver port number should be 8080. Thinking about that, I went to [2]
> > which says to comment the lines:
> > ...# SITEURL = 'http://localhost'...#GEOSERVER_LOCATION = os.getenv(#
> > 'GEOSERVER_LOCATION', '{}/geoserver/'.format(SITEURL)#)
> > #GEOSERVER_PUBLIC_LOCATION = os.getenv(#
> > 'GEOSERVER_PUBLIC_LOCATION', '{}/gs/'.format(SITEURL)#)...
> > Besides of that, I set GEOSERVER_PUBLIC_PORT = '8080', but the issues remains.
> > GEOSERVER_PUBLIC_PORT = os.getenv(
> > 'GEOSERVER_PUBLIC_PORT', '8080'
> > If anyone else has faced these problems and could share any hint, it will
> > be very appreciated.
> > Kind regards
> > Julierme
> > [1]
> > https://github.com/GeoNode/geonode-project/tree/06602d424a3779a636bcc78bc1d50c83ba980bad
> > [2]
> > http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/create_geonode_db.html
> > -------------- next part --------------
> > An HTML attachment was scrubbed...
> > URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190315/4f1769b2/attachment-0001.html>
> > Message: 2
> > Date: Sat, 16 Mar 2019 08:33:41 +0000
> > From: Paulo Frias <pfrias82 at gmail.com>
> > To: Julierme Pinheiro <juliermeopensourcedeveloper at gmail.com>
> > Cc: geonode-users <geonode-users at lists.osgeo.org>, geonode-devel
> > Subject: Re: [GeoNode-users] geonode devmode python virtualenv
> > installation
> > Message-ID:
> > <CA+PD0U2bGP8NGbWPEVYR1ar-NA2KeU=SnyoLZdJ0M_7TKgLOyA at mail.gmail.com>
> > Hi Julierme,
> > I have the exact same problem running Geonode, same installation procedure,
> > on my Mac. But I didn't found any solution yet. :(
> > Regards,
> > Paulo
> > On Fri, 15 Mar 2019 at 19:51, Julierme Pinheiro <
> > juliermeopensourcedeveloper at gmail.com> wrote:
> > > Dear all,
> > > ...# SITEURL = 'http://localhost'...#GEOSERVER_LOCATION = os.getenv(# 'GEOSERVER_LOCATION', '{}/geoserver/'.format(SITEURL)#)
> > > #GEOSERVER_PUBLIC_LOCATION = os.getenv(# 'GEOSERVER_PUBLIC_LOCATION', '{}/gs/'.format(SITEURL)#)...
> > > Kind regards
> > > Julierme
> > > [1]
> > > [2]
> > > _______________________________________________
> > URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190316/4a801d6a/attachment-0001.html>
> > Subject: Digest Footer
> > End of geonode-users Digest, Vol 50, Issue 12
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190316/2bc01b35/attachment-0001.html>
More information about the geonode-users
