[GeoNode-users] Show Layers on Layer view page (Jose Cáceres)
Toni Schönbuchner toni.schoenbuchner at csgis.de
Sun Mar 31 12:51:51 PDT 2019
Wonderful Jose,
even better!
Best regards,
Toni
> Am 31.03.2019 um 17:10 schrieb Jose Cáceres <jose.atyus at gmail.com>:
> Hi everyone,
> Just as a followed up on my previous issue, I found that the DEFAULT_MAP_CRS = "EPSG:900913" on my local_settings.py, so I changed that to "EPSG:3857", also I noticed that the EPSG in which most of my layers are defined (EPSG:32616) wasn't on the 'SUPPORTED_CRS' list, so I added that as well.
> And now the layers are showing as expected, showing the full extent of each layer on the preview window.
> Thanks to Toni and to everyone else for your help.
> Kind regards,
> José
>   <https://mailtrack.io/?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&>	Remitente notificado con
> Mailtrack <https://mailtrack.io/?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5&> 31/03/19 09:08:36
> On Sun, Mar 31, 2019 at 8:31 AM Toni Schönbuchner <toni.schoenbuchner at csgis.de <mailto:toni.schoenbuchner at csgis.de>> wrote:
> Dear Jose,
>> To update to Master, Do I need another machine or it can be done on the same server? The problem is I just have the one server to get it done,  and is not particular powerful (2 cores, 4GB memory, 60GB on disk).
> I understand your problem with having only one server. For every option I can think of this
> guide from Oliver should give you an idea of what to backup first and how:
> https://github.com/olivierdalang/SPCgeonode#how-to-migrate-from-an-existing-standard-geonode-install <https://github.com/olivierdalang/SPCgeonode#how-to-migrate-from-an-existing-standard-geonode-install>
> A) Backup -> test locally -> reset your VM ->  import / migrate all data live again
> This might be one of the cleanest but also work intense solutions.
>     - Backup your live data
>     - Test the installation/migration locally (you could use vagrant for spinning an Ubuntu instance in seconds)
>     - Create a snapshot of your live VM (!!!)
>     - Reset your live instance to a fresh state
>     - Repeat the install with your production VM and migrate/import your data as you did locally.
> B) Use GeoServer and Postgresql install from apt -> manually install the core.
> Again a snapshot gives you safety. Don´t miss to make use of it if you can!
>     - Clone geonode-project master branch https://github.com/GeoNode/geonode-project <https://github.com/GeoNode/geonode-project>
>     - Follow the README to create a virtualenv which will isolate python packages from globally installed by apt
>     - Enable the geoserver boilerplate settings file https://github.com/GeoNode/geonode-project/blob/master/project_name/local_settings.py.sample <https://github.com/GeoNode/geonode-project/blob/master/project_name/local_settings.py.sample>
>       and add your credentials/path for PostgreSQL and geoserver.
>     - Update Apache conf that it´s pointing to your new Geonode install (backup the conf file!)
>     - Migrate your database as mentioned in Olivier's readme and if needed upgrade geoserver to a newer version.
> C) Install geonode docker -> and migrate your apt setup
> This might be the most secure solution as you can always easily uninstall docker again and restart your
> stack. Be prepared that docker install might need some more knowledge regarding its configuration.
>     - Backup all your data,
>     - Shut down the current Postgres, Geoserver, Apache, etc setup
>     - Install the docker stack
>     - Migrate your data and continue using docker
> Find here a good writeup where to start with docker:
> https://docs.google.com/document/d/1S0ac9IR9IW9tUjMu7JETPLUjnfQ6P87m1PKNko8IPWY <https://docs.google.com/document/d/1S0ac9IR9IW9tUjMu7JETPLUjnfQ6P87m1PKNko8IPWY>
> (credits: https://geo-solutions.it <https://geo-solutions.it/>)
>>  I try once before following the instructions provided here https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit <https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit> for Ubuntu 18.04, but I don't know if this update can be done in Ubuntu 16.04 as well.
> For all options you could use Ubuntu Bionic or Xenial.
> With A) and B) the install differs a bit  (different package Versions) but the migration steps are the same.
> If you´re familiar with Docker and your server resources suffice I would suggest Option C.
> If you new to Docker at all I would go with B)
> ( A) would be the last I would do )
> These are all just rough ideas which might need fine tuning here and there but I hope
> you get the ideas. If you need more insights don´t hesitate to ask.
> And,
>      ⚠️ don´t forget backups, backups, backups ;)
> Best regards,
> Toni
>> Am 31.03.2019 um 15:08 schrieb Jose Cáceres <jose.atyus at gmail.com <mailto:jose.atyus at gmail.com>>:
>> Hi,
>> One more thing I forgot to mention, I don't know if is relevant, if I load any layers on the geoexplorer client on /maps/new, it does show the extent of the layers automatically as I load them, the problem is just on the preview of the layer on the /layers/layer_name page.
>> Kind regards,
>> José
> José David Cáceres
> Ingeniero Ambiental
> Máster en Tecnologías de la Información Geográfica
> e-mail: jose.atyus at gmail.com <mailto:jose.atyus at gmail.com>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190331/c95cd9e3/attachment.html>
More information about the geonode-users mailing list
