[GeoNode-users] (no subject)
Naresh N naresh919 at gmail.com
Mon May 6 02:10:46 PDT 2019
Dear All,
Please help to enable https for GeoNode
Please find the details below in which GeoNdde deployed
*Server OS*: RHEL 7.2
*GeoNode Version*: 2.4
*Bits*:64 -bit machine.
Apache 2.4.6
Python:2.7.5
GeoServer :2.7.4
Tomcat Version:7.0.54
The following commands executed. (followed from
*http://docs.geonode.org/en/2.4.x/tutorials/advanced/geonode_production/ssl.html?highlight=ssl
<http://docs.geonode.org/en/2.4.x/tutorials/advanced/geonode_production/ssl.html?highlight=ssl>*
1. Copied the our SSL key and certificate to the following locations
   As, We are using WildCard.crt  The following were copied
    a. SSLcertificateFile  with    Wildcard.crt,
    b. SSLCertificateKeyFile  with server.key
    c. SSLCertificateChainFile  with Intermediate.crt
2.   Apache Configuration  as mentioned in above , I have modified in our
geonode.conf file
3.  Tomcat Configuration - Edited Server.xml and done required changes
4. GeoNode Configuration - Changed Site Url to https
5. GeoServer Configuration - Changed web.xml
After doing above and restarting tomcat,apache site was redirecting to
https, however when I am uploading data it is showing following error
*SSLHandshakeError:
[SSL: UNKNOWN_PROTOCOL] unknown protocol (_ssl.c:765)*
File "/home/geonode/geonode/layers/views.py", line 171, in layer_upload
[Mon May 06 10:34:55.699359 2019] [:error] [pid 39822]
 title=form.cleaned_data["layer_title"],
[Mon May 06 10:34:55.699361 2019] [:error] [pid 39822]   File
"/home/geonode/geonode/layers/utils.py", line 470, in file_upload
[Mon May 06 10:34:55.699363 2019] [:error] [pid 39822]     defaults=defaults
[Mon May 06 10:34:55.699365 2019] [:error] [pid 39822]   File
"/usr/lib/python2.7/site-packages/django/db/models/manager.py", line 154,
in get_or_create
[Mon May 06 10:34:55.699368 2019] [:error] [pid 39822]     return
self.get_queryset().get_or_create(**kwargs)
[Mon May 06 10:34:55.699370 2019] [:error] [pid 39822]   File
"/usr/lib/python2.7/site-packages/modeltranslation/manager.py", line 341,
in get_or_create
[Mon May 06 10:34:55.699372 2019] [:error] [pid 39822]     return
super(MultilingualQuerySet, self).get_or_create(**kwargs)
[Mon May 06 10:34:55.699375 2019] [:error] [pid 39822]   File
"/usr/lib/python2.7/site-packages/django/db/models/query.py", line 383, in
get_or_create
[Mon May 06 10:34:55.699377 2019] [:error] [pid 39822]
 obj.save(force_insert=True, using=self.db)
[Mon May 06 10:34:55.699384 2019] [:error] [pid 39822]   File
"/usr/lib/python2.7/site-packages/polymorphic/polymorphic_model.py", line
90, in save
[Mon May 06 10:34:55.699393 2019] [:error] [pid 39822]     return
super(PolymorphicModel, self).save(*args, **kwargs)
[Mon May 06 10:34:55.699395 2019] [:error] [pid 39822]   File
"/usr/lib/python2.7/site-packages/django/db/models/base.py", line 545, in
save
[Mon May 06 10:34:55.699397 2019] [:error] [pid 39822]
 force_update=force_update, update_fields=update_fields)
[Mon May 06 10:34:55.699399 2019] [:error] [pid 39822]   File
"/usr/lib/python2.7/site-packages/django/db/models/base.py", line 569, in
save_base
[Mon May 06 10:34:55.699401 2019] [:error] [pid 39822]
[Mon May 06 10:34:55.699403 2019] [:error] [pid 39822]   File
"/usr/lib/python2.7/site-packages/django/dispatch/dispatcher.py", line 185,
in send
[Mon May 06 10:34:55.699405 2019] [:error] [pid 39822]     response =
receiver(signal=self, sender=sender, **named)
[Mon May 06 10:34:55.699407 2019] [:error] [pid 39822]   File
"/home/geonode/geonode/geoserver/signals.py", line 74, in geoserver_pre_save
[Mon May 06 10:34:55.699409 2019] [:error] [pid 39822]
 charset=instance.charset)
[Mon May 06 10:34:55.699410 2019] [:error] [pid 39822]   File
"/home/geonode/geonode/geoserver/helpers.py", line 1053, in geoserver_upload
[Mon May 06 10:34:55.699412 2019] [:error] [pid 39822]     workspace =
cat.get_default_workspace()
[Mon May 06 10:34:55.699414 2019] [:error] [pid 39822]   File
"/usr/lib/python2.7/site-packages/geoserver/catalog.py", line 876, in
[Mon May 06 10:34:55.699416 2019] [:error] [pid 39822]     ws.fetch()
[Mon May 06 10:34:55.699418 2019] [:error] [pid 39822]   File
"/usr/lib/python2.7/site-packages/geoserver/support.py", line 174, in fetch
[Mon May 06 10:34:55.699420 2019] [:error] [pid 39822]     self.dom =
self.catalog.get_xml(self.href)
[Mon May 06 10:34:55.699425 2019] [:error] [pid 39822]   File
"/usr/lib/python2.7/site-packages/geoserver/catalog.py", line 211, in
get_xml
[Mon May 06 10:34:55.699428 2019] [:error] [pid 39822]     response,
content = self.http.request(rest_url)
[Mon May 06 10:34:55.699430 2019] [:error] [pid 39822]   File
"/usr/lib/python2.7/site-packages/httplib2/__init__.py", line 1572, in
request
[Mon May 06 10:34:55.699432 2019] [:error] [pid 39822]     (response,
content) = self._request(conn, authority, uri, request_uri, method, body,
headers, redirections, cachekey)
[Mon May 06 10:34:55.699434 2019] [:error] [pid 39822]   File
"/usr/lib/python2.7/site-packages/httplib2/__init__.py", line 1319, in
_request
[Mon May 06 10:34:55.699436 2019] [:error] [pid 39822]     (response,
content) = self._conn_request(conn, request_uri, method, body, headers)
[Mon May 06 10:34:55.699438 2019] [:error] [pid 39822]   File
"/usr/lib/python2.7/site-packages/httplib2/__init__.py", line 1254, in
_conn_request
[Mon May 06 10:34:55.699440 2019] [:error] [pid 39822]     conn.connect()
[Mon May 06 10:34:55.699442 2019] [:error] [pid 39822]   File
"/usr/lib/python2.7/site-packages/httplib2/__init__.py", line 1046, in
connect
[Mon May 06 10:34:55.699444 2019] [:error] [pid 39822]     raise
SSLHandshakeError(e)
[Mon May 06 10:34:55.699445 2019] [:error] [pid 39822] SSLHandshakeError:
Please help me to resolve the issue and let me know any other information
require further.
Thanks&Regards,
Naresh.N
Thanks&Regards,
Naresh
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190506/9bbc375a/attachment.html>
More information about the geonode-users mailing list
