[GeoNode-users] Proxy error with geoserver link in my profile
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu May 30 00:59:54 PDT 2019
Uhm, that's strange.
Could you also verify that your local_settings contains the following
statements
https://github.com/GeoNode/geonode/blob/master/geonode/local_settings.py.geoserver.sample#L101
If yes, please be sure you are running the correct settings and you are not
overriding somehow the variables.
Il giorno gio 30 mag 2019 alle ore 03:06 Maxime Audet-Roberge <
maximeaudetr at hotmail.com> ha scritto:
> Hi Alessio,
> First I want to thank you for your quick answer, I really appreciate!
> I looked at my local_config.py file and I already have a
> GEOSERVER_WEB_UI_LOCATION variable:
> GEOSERVER_WEB_UI_LOCATION = os.getenv(
> 'GEOSERVER_WEB_UI_LOCATION', GEOSERVER_LOCATION
> and my GEOSERVER_LOCATION variable is:
> GEOSERVER_LOCATION = os.getenv(
> 'GEOSERVER_LOCATION', 'http://localhost/geoserver/'
> I tried to set it with a value:
> GEOSERVER_WEB_UI_LOCATION = 'http://localhost/geoserver/'
> Without success. I still have the same issue.
> Do you have any idea what I should try next?
> Thanks for your help!
> Maxime
> *De :* Alessio Fabiani <alessio.fabiani at geo-solutions.it>
> *Envoyé :* 29 mai 2019 03:29
> *À :* Maxime Audet-Roberge
> *Cc :* geonode-users at lists.osgeo.org
> *Objet :* Re: [GeoNode-users] Proxy error with geoserver link in my
> profile
> Hello Maxime,
> define either an environment variable or set explicitly on your settings
> the following variable
> GEOSERVER_WEB_UI_LOCATION=http://<full_address_of_geoserver>/
> Il giorno mer 29 mag 2019 alle ore 03:32 Maxime Audet-Roberge <
> Hello GeoNode Users,
> I installed GeoNode 2.10 rc5 on a Ubuntu 18.04 VM following the guide
> written by GeoSolutions (
> https://docs.google.com/document/d/1jNg2BKn2H9Haoyqpe7XkK_Nj-siL7PUlhP40hGi9OZ8/edit).
> I also installed GeoServer 2.15.1. Almost everything is working fine so
> far, I have access to geoserver and the authentication works! However, I
> have some issues. Here is one: the link to geoserver in my profile is not
> working and I have a proxy error.
> When I click on the top left menu (I am logged as admin), the GeoServer
> link is localhost/geoserver. This link is workong fine when I click on it.
> However, if I open my profile (localhost/people/admin/), the link to
> geoserver will be localhost/proxy/?url=http://localhost/geoserver. When I
> click on this link, I have the following message in my browser : “The
> proxy service requires a URL-encoded URL as a parameter.” and the address
> is “localhost/proxy/web”.
> Do you have any idea how I can avoid this error?
> Thanks a lot!
> Maxime
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20190530/ae82dae8/attachment-0001.html>
More information about the geonode-users
