[GeoNode-users] Feed geonode metadata from geonetwork
XAVIER RAYO SARRIAS xrayo at utm.csic.es
Fri Oct 11 06:27:40 PDT 2019
I have changed the configuration file settings.py to point to my
geonetwork server but I can't figure to use the metadata hosted in
geonetwork with the layers in geonode.
When I use localhost:80000/catalogue/csw? in the geonode server,  I get an
xml from my geonetwork so I understand I modified correctly the settings in
settings.py . But then when I load a layer in geonode I don't know how to
point it to the geonetwork server.
Any idea what I'm doing wrong or what should I do?
Thanks you very much in advance!
El vie., 4 oct. 2019 a las 14:07, XAVIER RAYO SARRIAS (<xrayo at utm.csic.es>)
escribió:
> Hi,
> I'm trying to feed my geonode application with a geonetwork already
> working so that I don't have to run into duplication of metadata.
> I've seen It can be done but I can't find If I need to modify first my
> geonetwork or I can do it directly from the geonode. Anybody knows a step
> by step manual or something like this?
> Thank you very much!
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191011/95bc0f2e/attachment.html>
More information about the geonode-users mailing list
