[GeoNode-users] migration suggestions
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Sat Oct 26 13:07:58 PDT 2019
Hi Paolo,
any chance to update the official docs with your notes
http://docs.geonode.org/en/master/admin/upgrade/index.html#upgrade-from-2-4-x
Il giorno ven 25 ott 2019 alle ore 20:20 Paolo Corti <pcorti at gmail.com> ha
scritto:
> Hi Alessio and Eugenio
> I could recently update a GeoNode instance from 2.4 to master (2.10.1)
> with not too much effort. Here are few notes I created at the time:
> https://gist.github.com/capooti/32071c67fb2b40b7715256d287000155
> Try this method on a dev instance before applying it on production.
> Obviously, backup everything before doing it ;)
> ciao
> Paolo
> On Fri, Oct 25, 2019 at 11:26 AM Alessio Fabiani
> <alessio.fabiani at geo-solutions.it> wrote:
> > Hi Eugenio,
> > so, the thing is that GeoNode 2.4 and 2.10 are barely compatible.
> Upgrading the old version, even the look and feel, basically will require
> you to redo almost everything.
> > My suggestion was to basically update only GeoServer and the GeoServer
> db, start a GeoNode 2.10.x from scratch and apply the l&f customizations,
> then run the updatelayers command.
> > The updatelayers command will configure the layers into GeoNode and
> basically will update:
> > - title and abstract
> > - keywords
> > - style
> > All the other metadata fields must be set manually.
> > Trying to restore the databases is feasible, but requires a deep
> knowledge of Django, GeoNode model and how migration works.
> > In this latter case, you will need not only to patch the model, but also
> to update manually the "django_contentypes" in order to fixup the guardians
> rules, due to the model polymorphism implementation of GeoNode.
> > Il giorno ven 25 ott 2019 alle ore 16:58 Eugenio Trumpy <
> frippe12573 at hotmail.com> ha scritto:
> >> Hi Alessio,
> >> thank you for your prompt answer. However, I have a doubts(I apologise
> if it is stupid) about your hints:
> >> for metadata do you mean the postgresql db? in case of yes, what do you
> mean with 'no much', I have 42 layers in 'geonode_data' and 20 maps 116
> layers and a couple of users in 'geonode' pgsql dbs. So can I dump and
> restore both databases? or the db structure is changed, so that I need a
> special procedure?
> >> If I port the data only by geoserver, what I have after the
> updatelayers in the pgsql dbs? no metadata I presume, or only basic info
> taken from the old geoserver?
> >> What about the porting of the look and feel of the sites I have? just
> copy the codes?
> >> Thanks a lot,
> >> Eugenio
> >> ________________________________
> >> Da: Alessio Fabiani <alessio.fabiani at geo-solutions.it>
> >> Inviato: venerdì 25 ottobre 2019 16:27
> >> A: Eugenio Trumpy <frippe12573 at hotmail.com>
> >> Cc: geonode-users at lists.osgeo.org <geonode-users at lists.osgeo.org>
> >> Oggetto: Re: [GeoNode-users] migration suggestions
> >> Hello Eugenio,
> >> in the case you have no much metadata to configure and few users, my
> *hot* suggestion is to pass through GeoServer in order to port your
> datasets.
> >> So the steps would be the following ones:
> >> 1. Setup a new GeoServer 2.15.2 (
> https://build.geo-solutions.it/geonode/geoserver/latest/geoserver-2.15.2.war
> >> 2. Transfer the Data Dir from the old GeoServer to the new one (I
> strongly suggest to backport **only** the workspace, datasets and styles,
> not the security subsystem)
> >> 3. Setup the new GeoNode instance
> >> 4. Run the "updatelayers" management command (see
> http://docs.geonode.org/en/master/admin/mgmt_commands/index.html#management-command-updatelayers
> >> 5. Update manually the missing permissions and metadata
> >> Il giorno ven 25 ott 2019 alle ore 16:08 Eugenio Trumpy <
> >> Dear all,
> >> I have a running geonode at version 2.4 dev20160525015826 configured as
> multisite in a ubuntu server 16.04.6 LTS.
> >> The system administrator suggested me to update the server OS to
> 18.04.3 LTS for many reasons that are not the topic of this email.
> >> I would like to know if there are suggested procedures to migrate my
> multisite project, data, ... to a newer version of geonode
> >> (the most update seems to be the vs.2.10).
> >> Just to let you know, for the previous installation I followed the
> custom installation,
> >> because in the server were already running postgresql, tomcat, and so
> on...
> >> Moreover, as said, I set the project to be used as multi-sites.
> >> So I need:
> >> to install a fresh geonode version
> >> set-up the multi-sites
> >> dump the data from version 2.4
> >> load the data in the new version
> >> Any hints or recommendations?
> >> Thanks,
> >> Eugenio
> >> _______________________________________________
> >> geonode-users mailing list
> >> https://lists.osgeo.org/mailman/listinfo/geonode-users
> >> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> >> Ing. Alessio Fabiani
> >> @alfa7691
> >> Founder/Technical Lead
> >> GeoSolutions S.A.S.
> >> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> >> phone: +39 0584 962313
> >> fax: +39 0584 1660272
> >> mob: +39 331 6233686
> >> http://www.geo-solutions.it
> >> http://twitter.com/geosolutions_it
> >> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> >> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> > @alfa7691
> > GeoSolutions S.A.S.
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
> #drt3jc1
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20191026/203fd32f/attachment-0001.html>
More information about the geonode-users
