[GeoNode-users] [GeoNode 3.0] Remove Geo-EXT and Print custom GeoServer plugin wrapper from GeoNode
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu Feb 6 04:17:09 PST 2020
Dear all,
currently the old GeoEXT dependency on GeoNode is preventing master branch
(aka GeoNode 3.0) to build correctly.
Moreover this package still requires a custom plugin on GeoServer build for
GeoNode.
Last but not least, there are plenty of customizations both on Python and
HTML code on GeoNode in order to fit the old GeoExplorer stuff around the
repo.
My proposal is to get rid definitely of this obsolete client form the 3.0
train an above.
Any comment?
Alessio.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200206/f90c43dc/attachment.html>
More information about the geonode-users
