[GeoNode-users] Updatelayers failed
Florian Hoedt
florian.hoedt at thuenen.de
Mon Feb 10 00:15:02 PST 2020
Hello José,
The line: " Could not ADD GeoServer User 'admin' Rule for Layer 'termicas': ''Duplicate Rule Rule[id:null pri:3742 user:admin srv:WPS ws:geonode l:termicas acc:ALLOW]'' "
means there was already a rule with the same content in place. There shouldn´t be any upcoming issues.
MSc Florian Hoedt
Coordinator Geoinformatics | OpenData Representative
Thünen Institute, Centre for Information Management
Bundesallee 44
38116 Braunschweig
Tel: +49 531 596-1428
Fax: +49 531 596-1499
Mail: florian.hoedt at thuenen.de
Web: www.thuenen.de
The Johann Heinrich von Thünen Institute, Federal Research Institute for Rural Areas, Forestry and Fisheries – Thünen Institute in brief – consists of 14 specialized institutes that carry out research and provide policy advice in the fields of economy, ecology and technology.
Von: "Jose Cáceres" <jose.atyus at gmail.com>
An: "geonode-users" <geonode-users at lists.osgeo.org>
Gesendet: Freitag, 7. Februar 2020 23:50:37
Betreff: Re: [GeoNode-users] Updatelayers failed
Hi again,
Sorry but just as a followed up, I did the following lines as suggested here [ http://osgeo-org.1560.x6.nabble.com/Command-updatelayers-and-createsuperuser-in-docker-compose-td5393949.html | http://osgeo-org.1560.x6.nabble.com/Command-updatelayers-and-createsuperuser-in-docker-compose-td5393949.html ] :
mkdir -p /usr/src/app/; \
source $HOME/.override_env; \
echo DATABASE_URL=$DATABASE_URL; \
echo GEODATABASE_URL=$GEODATABASE_URL; \
echo SITEURL=$SITEURL; \
echo ALLOWED_HOSTS=$ALLOWED_HOSTS; \
echo GEOSERVER_PUBLIC_LOCATION=$GEOSERVER_PUBLIC_LOCATION; \
django-admin createsuperuser
Then I created the superuser and ran again:
BQ_BEGIN
DJANGO_SETTINGS_MODULE=geonode.settings python manage.py updatelayers -w geonode
BQ_END
This time it ran ok, although for every layer I got the following message:
BQ_BEGIN
BQ_END
But in the end it showed as expected:
BQ_BEGIN
113 Created layers
1 Updated layers
0 Failed layers
10.98 seconds per layer
BQ_END
I can see my layers just fine in Geonode, but I'm not sure if the error that I got is gonna mess everything, so I would like to know why was that about.
Again thanks for your help.
Kind regards,
José
[ https://mailtrack.io/?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5& |
] Remitente notificado con
[ https://mailtrack.io/?utm_source=gmail&utm_medium=signature&utm_campaign=signaturevirality5& | Mailtrack ] 07/02/20 16:48:26
On Fri, Feb 7, 2020 at 1:42 PM Jose Cáceres < [ mailto:jose.atyus at gmail.com | jose.atyus at gmail.com ] > wrote:
BQ_BEGIN
Hi everyone,
Hope everything is well.
I'm running geonode 2.10 using docker instance as per this instructions: [ http://docs.geonode.org/en/2.10.x/install/core/#docker | http://docs.geonode.org/en/2.10.x/install/core/#docker ]
I'm running it on a local IP, not localhost directly, but I thought everything went well with the installation since I could load the page, load geoserver, uploading a layer using the upload function form the site, I could dump me own database into geonode_data and I could see my layers in geoserver, all as shown in the screenshots attached.
However, when I try to import my data to geonode from geoserver, using the updatelayers command I get the following error message.
So I enter the container running:
BQ_BEGIN
docker exec -it geoserver4geonode /bin/bash
BQ_END
The I ran:
BQ_BEGIN
python manage.py makemigrations
python manage.py migrate
python manage.py migrate --run-syncdb
BQ_END
Everything went without any issues. Then I tried:
BQ_BEGIN
DJANGO_SETTINGS_MODULE=geonode.settings python manage.py updatelayers -w geonode --skip-geonode-registered
BQ_END
And got the following error:
BQ_BEGIN
File "manage.py", line 29, in <module>
execute_from_command_line(sys.argv)
File "/usr/local/lib/python3.7/site-packages/django/core/management/__init__.py", line 381, in execute_from_command_line
utility.execute()
File "/usr/local/lib/python3.7/site-packages/django/core/management/__init__.py", line 375, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File "/usr/local/lib/python3.7/site-packages/django/core/management/base.py", line 323, in run_from_argv
self.execute(*args, **cmd_options)
File "/usr/local/lib/python3.7/site-packages/django/core/management/base.py", line 364, in execute
output = self.handle(*args, **options)
File "/usr/src/app/geonode/geoserver/management/commands/updatelayers.py", line 98, in handle
owner = get_valid_user(user)
File "/usr/src/app/geonode/people/utils.py", line 46, in get_valid_user
theuser = get_default_user()
File "/usr/src/app/geonode/people/utils.py", line 37, in get_default_user
raise GeoNodeException('You must have an admin account configured '
geonode.GeoNodeException: You must have an admin account configured before importing data. Try: django-admin.py createsuperuser
BQ_END
Then I tried passing the flag user to the previous command, like this:
BQ_BEGIN
DJANGO_SETTINGS_MODULE=geonode.settings python manage.py updatelayers -u admin -w geonode --skip-geonode-registered
utility.execute()
File "/usr/src/app/geonode/people/utils.py", line 48, in get_valid_user
theuser = get_user_model().objects.get(username=user)
File "/usr/local/lib/python3.7/site-packages/django/db/models/manager.py", line 82, in manager_method
return getattr(self.get_queryset(), name)(*args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/django/db/models/query.py", line 408, in get
self.model._meta.object_name
geonode.people.models.DoesNotExist: Profile matching query does not exist.
BQ_END
No luck either, I can log to the site using the default credentials, but I haven't created any other users, is that necesary in order to use the updatelayers?
Thanks in advance for all your help!
José
José David Cáceres
Ingeniero Ambiental
Máster en Tecnologías de la Información Geográfica
e-mail: [ mailto:jose.atyus at gmail.com | jose.atyus at gmail.com ]
BQ_END
José David Cáceres
Ingeniero Ambiental
geonode-users mailing list
https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200210/a1385628/attachment.html>
More information about the geonode-users
