[GeoNode-users] Error Updating GeoNode ip
Amedeo Fadini
amefad at gmail.com
Sat Feb 22 04:28:16 PST 2020
Hi sara it seems that geonode can't find the django_site table in
database...
I assume that you're still using SQLite database and that the services
successfully started in debug mode...
Check if You are able to find the SQLIte fb file in your installation
directory.
you can try to repeat The
paver setup
paver sync
step and check If there is Some kind of errors...
Amedeo
Il Ven 21 Feb 2020, 19:25 Sara Ahmadi <ziba.ahmadi at gmail.com> ha scritto:
> I am installing Geonode 2.10.1 following the instruction in the link below:
> http://docs.geonode.org/en/2.10.1/install/core/index.html
> I faced several errors (mostly apps version) and solved them until I
> wanted to Update the GeoNode ip or hostname:
> `sudo PYTHONWARNINGS=ignore VIRTUAL_ENV=$VIRTUAL_ENV
> DJANGO_SETTINGS_MODULE=geonode.local_settings GEONODE_ETC=/opt/geonode
> GEOSERVER_DATA_DIR=/opt/data/geoserver_data TOMCAT_SERVICE="service tomcat"
> APACHE_SERVICE="service nginx" geonode_updateip -p localhost
> where I get the following error:
> PUBLIC_IP http://localhost
> LOCAL_IP http://localhost
> Replacing SITEURL value with 'http://localhost' in /opt/geo
> node/local_settings.py ... done.
> Adding entry for 'localhost' in /opt/data/geoserver_data/pr
> inting/config.yaml ... done.
> Traceback (most recent call last):
> File "/usr/local/bin/django-admin", line 11, in <module>
> sys.exit(execute_from_command_line())
> File "/home/geonode/.local/lib/python2.7/site-packages/djang
> o/core/management/__init__.py", line 364, in execute_from_comm and_line
> utility.execute()
> o/core/management/__init__.py", line 356, in execute
> self.fetch_command(subcommand).run_from_argv(self.argv)
> o/core/management/base.py", line 283, in run_from_argv
> self.execute(*args, **cmd_options)
> o/core/management/base.py", line 330, in execute
> output = self.handle(*args, **options)
> File "/opt/geonode/geonode/base/management/commands/fixsiten ame.py",
> line 39, in handle
> site = Site.objects.get_current()
> o/contrib/sites/models.py", line 63, in get_current
> return self._get_site_by_id(site_id)
> o/contrib/sites/models.py", line 35, in _get_site_by_id
> site = self.get(pk=site_id)
> o/db/models/manager.py", line 85, in manager_method
> return getattr(self.get_queryset(), name)(*args, **kwargs)
> o/db/models/query.py", line 374, in get
> num = len(clone)
> o/db/models/query.py", line 232, in __len__
> self._fetch_all()
> o/db/models/query.py", line 1121, in _fetch_all
> self._result_cache = list(self._iterable_class(self))
> o/db/models/query.py", line 53, in __iter__
> results = compiler.execute_sql(chunked_fetch=self.chunked_ fetch)
> o/db/models/sql/compiler.py", line 899, in execute_sql
> raise original_exception
> django.db.utils.ProgrammingError: relation "django_site" does not exist
> LINE 1: ..."django_site"."domain", "django_site"."name" FROM " django_si...
> Setting up oauth
> Waiting Tomcat Service to Restart...
> Waiting Apache HTTPD Service to Restart...
> utility.execute()
> File "/opt/geonode/geonode/geoserver/management/commands/upd
> atelayers.py", line 98, in handle
> owner = get_valid_user(user)
> File "/opt/geonode/geonode/people/utils.py", line 44, in get _valid_user
> theuser = get_default_user()
> File "/opt/geonode/geonode/people/utils.py", line 31, in get
> _default_user
> if superusers.count() > 0:
> o/db/models/query.py", line 364, in count
> return self.query.get_count(using=self.db)
> o/db/models/sql/query.py", line 499, in get_count
> number = obj.get_aggregation(using, ['__count'])['__count' ]
> I could not figure out the problem. Any helps are appreciated. especially
> if any up-to-date installation is available for Geonode 2.10.x on Ubuntu.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20200222/aae2a53f/attachment.html>
More information about the geonode-users
